Home » Archived » BIRT » same report but not the same result
same report but not the same result [message #212339] Thu, 18 January 2007 08:57 Go to next message
Originally posted by: alice.mange.gmail.com
Hi community !
I download the example org.eclipse.birt.examples.rcpengine and I use the
code from the method previewReport from View.java, to integrate my report
in my application.
If I executed the example org.eclipse.birt.examples.rcpengine and I
choosed a report A, it is nearly ok, but I have a result.
(When I talk about result it is an html code which was return by bos :
ByteArrayOutputStream bos = new ByteArrayOutputStream();
options.setOutputStream(bos);
options.setOutputFormat("html");
task.setRenderOption(options);
-> I can see a html code with a title for example
Now I use the same code but from my application, I open the same report A,
and now I haven't result.
->the html code contains a table with nothing, no title nothing.
Do you know what could be a source of this problem ?
Thank you
Re: same report but not the same result [message #212396 is a reply to message #212339] Thu, 18 January 2007 11:45 Go to previous messageGo to next message
Did you enable logging?
Do you have your db driver installed on both?
Jason
"Alilou" <alice.mange@gmail.com> wrote in message
news:993a6b7f60dca6822a1ef47b24aa5658$1@www.eclipse.org...
> Hi community !
> in my application.
> Thank you
Re: same report but not the same result [message #212754 is a reply to message #212396] Fri, 19 January 2007 10:10 Go to previous messageGo to next message
Hi Jason and thank you for your answer...
To be easier, I tried to open the report hello_world.rptdesign, and it was
OK. I have a visual result.
So I did a new report with just a static text and It was OK too. I added
to the reoprt a dataSource for my data base Oracle but I have the
following error :
at
org.eclipse.birt.report.model.elements.OdaDataSource.setIntr insicProperty(OdaDataSource.java:201)
at
org.eclipse.birt.report.model.core.DesignElement.setProperty (DesignElement.java:1218)
at
org.eclipse.birt.report.model.parser.DesignParseState.setPro perty(DesignParseState.java:99)
at
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eODADataSourceExtensionID(OdaDataSourceState.java:167)
at
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eAttrs(OdaDataSourceState.java:82)
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unk nown
Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:90)
at
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:90)
at
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:278)
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:263)
at ui.MView.previewReport(MView.java:278)
I see already this error on article, but I didn't succed to resolve it. I
check the db driver : (I add them to my classPath)
birt_runtime/birt-runtime-2_1_0/ReportEngine/plugins/org.ecl ipse.birt.report.data.oda.jdbc_2.1.1.v20060922-1058/drivers/ ojdbc14.jar
(I have an Oracle db).
But I have always this error....
Re: same report but not the same result [message #212762 is a reply to message #212754] Fri, 19 January 2007 10:44 Go to previous messageGo to next message
Can you try the sampledb?
Also I noticed 2_1_0 in the runtime folder referencing a 2.1.1 plugin. Was
this just a typo?
If you are running this through a debugger, make sure you have the jdbc
plugin selected in
your launch configuration.
Jason
news:c702b8247798c1e73b719ef25313a49c$1@www.eclipse.org...
> following error :
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> at
> at
> at
Re: same report but not the same result [message #212836 is a reply to message #212396] Fri, 19 January 2007 11:34 Go to previous messageGo to next message
Hi Jason,
To began more easier, I began to open with my application the report
hello_world.rptdesign, So all it is ok.
I do a report with just a static text, it is fine too.
Now I add a datasource for my oracle dataBase, and I have the following
error :
at
at
org.eclipse.birt.report.model.core.DesignElement.setProperty (DesignElement.java:1188)
at
at
at
org.eclipse.birt.report.model.parser.ModuleParserHandler.sta rtElement(ModuleParserHandler.java:145)
at
Source)
at
Source)
at
at
So i check all by bd driver was in my classPath, there are :
C:\birt_runtime\birt-runtime-2_1_0\ReportEngine\plugins\org. eclipse.birt.report.data.oda.jdbc_2.1.1.v20060922-1058\drive rs\ojdbc14.jar
I check also that all my library are from
C:\birt_runtime\birt-runtime-2_1_0\ReportEngine... and they are !!
I am deseperate...
Re: same report but not the same result [message #212849 is a reply to message #212762] Fri, 19 January 2007 11:43 Go to previous messageGo to next message
You are right i download birt-runtime-2_1_1, so it is ok.
And I am not running through a debugger, so how I can sure the jdbc plugin
was selected ?
and it is maybe a stupid question, but to be sure : wath do you mean with
'jdbc plugin' ?
Re: same report but not the same result [message #213048 is a reply to message #212849] Mon, 22 January 2007 11:02 Go to previous messageGo to next message
Hi...
I saw in a post, to try with birt-2.2 version, so I try, And I haven't yet
the error, but I have a new error lol...
So before, I just have a label and a dataSource and I have the previously
error. Now with birt-2.2M2 I haven't error, so I add a dataSet very simple
and that all, I didn't add a table in my report to view the result. And
now I hae the error (like previously):
at
org.eclipse.birt.report.model.elements.OdaDataSet.setIntrins icProperty(OdaDataSet.java:205)
at
org.eclipse.birt.report.model.core.DesignElement.setProperty (DesignElement.java:1193)
at
org.eclipse.birt.report.model.core.DesignElement.setProperty (DesignElement.java:1163)
at
so I didn't understand what I forgot ?
Re: same report but not the same result [message #213055 is a reply to message #213048] Mon, 22 January 2007 12:24 Go to previous messageGo to next message
I have not updated rthat example for 2.2 yet, but this looks like a version
mismatch.
How are you debugging this?
Jason
news:73e6b1310a813b73540d63d2b0ba324b$1@www.eclipse.org...
> Hi...
> at
> at
> at
> at
Re: same report but not the same result [message #213569 is a reply to message #213055] Wed, 24 January 2007 03:11 Go to previous messageGo to next message
> mismatch.
> Jason
Hi Jason,
I stay with the BIRT version 2.1.1, so I keep my error.
And check all my jar file, and all are from the reportEngine_2.1.1. I
don't what can be the problem... I look the version of Birt Ressource
plugin with eclipse it is : 2.1.1 v200060825-0630 like my reportEngine
version...
I didn't understand you question : "how are you debugging ?"
-> I just run my application whith my main... It is the good answer ?
Re: same report but not the same result [message #213717 is a reply to message #213569] Wed, 24 January 2007 11:57 Go to previous messageGo to next message
A couple of things to look at:
Try the sampledb that comes with BIRT.
If this works verify that you have copied your JDBC driver to the jdbc
plugin.
This will be located in the drivers directory under the
org.eclipse.birt.report.data.oda.jdbc plugin.
Jason
news:770c9b68acc6120c2fb3135ef3ab9b8b$1@www.eclipse.org...
>> version mismatch.
>> Jason
> Hi Jason,
> version...
Re: same report but not the same result [message #213968 is a reply to message #213717] Thu, 25 January 2007 04:26 Go to previous messageGo to next message
I have the same error with th data base sample.In my report i have just a
the
org.eclipse.birt.report.data.oda.sampledb.Driver (Classic Models Inc.
SampleDB Driver).
So in my build path I add the corresponding jar file :
C:\birt-runtime-2_1_1\ReportEngine\plugins\org.eclipse.birt. report.data.oda.sampledb_2.1.1.v20060922-1058\sampledb.jar
and BirtSample.jar....
And I have the error :
at
Re: same report but not the same result [message #214102 is a reply to message #213968] Thu, 25 January 2007 11:18 Go to previous messageGo to next message
Here is a screenshot of my workspace.
Can you launch the debugger with all workspace and external plugins enabled?
Make sure you have copied all the BIRT plugins to your plugins folder.
Jason
news:5466c0628ceac60f943c4f9bbfb964cf$1@www.eclipse.org...
> the
> SampleDB Driver).
> at
  • Attachment: workspace.PNG
    (Size: 170.58KB, Downloaded 128 times)
Re: same report but not the same result [message #214964 is a reply to message #214102] Tue, 30 January 2007 03:12 Go to previous messageGo to next message
Hi Jason,
I think you didn't understand my problem (or i didn't understand your
answer lol).
Because if i open a report with the example
org.eclipse.birt.examples.rcpengine, my report have no problem, no error
with dataSource.
But If I want to open my report with my java application I have the error
I explain you... In my java application I didn't use a Plug-in
dependencies, I add library in my classPath :
here is an extract of my classPath :
<classpathentry kind="lib"
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.model_2.1.1. v20060926-0959.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.core_2.1.1.v2006092 6-0959.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.data.oda.xml _2.1.1.v20060926-0959.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.engine.emitt er.html_2.1.1.v20060926-0959.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.engine.emitt er.pdf_2.1.1.v20060926-0959.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.engine_2.1.1 .v20060926-0959.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.core.contenttype_3.2.0.v 20060601a.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.core.jobs_3.2.0.v2006060 1a.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.core.runtime.compatibili ty_3.1.100.v20060601a.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.core.runtime_3.2.0.v2006 0601b.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.datatools.connectivity.o da.consumer_3.0.2.200608301.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.datatools.connectivity.o da.flatfile_3.0.2.200608311.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.datatools.connectivity.o da_3.0.2.200608301.jar "/>
<... path=" C:/brt-2_1_1/RE/plugins/org.eclipse.osgi_3.2.0.v20060601.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.apache.batik.pdf/lib/pdf-transco der.jar "/>
<... path="C:/brt-2_1_1/RE/lib/com.ibm.icu_3.4.4.1.jar"/>
<... path="C:/brt-2_1_1/RE/lib/commons-cli-1.0.jar"/>
<... path="C:/brt-2_1_1/RE/lib/commons-codec-1.3.jar"/>
<... path="C:/brt-2_1_1/RE/lib/coreapi.jar"/>
<... path="C:/brt-2_1_1/RE/lib/dataadapterapi.jar"/>
<... path="C:/brt-2_1_1/RE/lib/dteapi.jar"/>
<... path="C:/brt-2_1_1/RE/lib/engineapi.jar"/>
<... path="C:/brt-2_1_1/RE/lib/flute.jar"/>
<... path="C:/brt-2_1_1/RE/lib/itext-1.3.jar"/>
<... path="C:/brt-2_1_1/RE/lib/js.jar"/>
<... path="C:/brt-2_1_1/RE/lib/modelapi.jar"/>
<... path="C:/brt-2_1_1/RE/lib/sac.jar"/>
<... path="C:/brt-2_1_1/RE/lib/scriptapi.jar"/>
<... path="C:/brt-2_1_1/RE/lib/Tidy.jar"/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.data.oda.jdb c_2.1.1.v20060922-1058/drivers/postgresql-8.0-310.jdbc3.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.data.oda.jdb c_2.1.1.v20060922-1058/drivers/ojdbc14.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.birt.data.oda_2.1.1.v2 0060922-1058/oda.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity _0.9.1.20060831/connectivity.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .ui_0.9.1.200608251/connectivityui.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .ui.dse_0.9.1.200608251/dse.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .oda.design.ui_3.0.2.200609201.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .oda.design_3.0.2.200608301.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .oda.designer.finfo_0.9.1.200609191.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .oda.finfo_0.9.1.200609191.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .oda.flatfile.ui_3.0.2.200608301.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.datatools.connectivity .oda.profile_3.0.2.200608301.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.apache.derby.core_10.1.2.1/der by.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.apache.xerces_2.8.0.v200606131 651/resolver.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.apache.xerces_2.8.0.v200606131 651/xercesImpl.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.apache.xerces_2.8.0.v200606131 651/xml-apis.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.core.runtime.compatibi lity.registry_3.2.0.v20060602/runtime_registry_compatibility .jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.birt.data.oda.adapter. dtp_2.1.1.v20060922-1058.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.birt.report.data.oda.j dbc.ui_2.1.1.v20060922-1058.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.birt.report.data.oda.x ml.ui_2.1.1.v20060922-1058.jar "/>
path=" C:/PgmFile/Ecp3.2/plugins/org.eclipse.birt.report.data.adapt er_2.1.1.v20060922-1058.jar "/>
<... path="C:/PgmFile/Ecp3.2/plugins/org.junit_3.8.1/junit.jar"/ >
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.data_2.1.1.v2006092 2-1058.jar "/>
path=" C:/brt-2_1_1/RE/plugins/org.eclipse.birt.report.data.oda.jdb c_2.1.1.v20060922-1058/oda-jdbc.jar "/>
Re: same report but not the same result [message #215302 is a reply to message #214964] Tue, 30 January 2007 16:25 Go to previous message
Now it is somewhat clear to me :>
If you are building it this way, you need to add the libs in the Runtime
download( ReportEngine/lib) and set a BIRT home to the report engine
directory.
The RCP example assumes all the BIRT plugins are installed in your
application. If you just want to use the engine download the runtime, unzip
and
set appropriate values. ie
http://wiki.eclipse.org/index.php/Simple_Execute
Jason
news:c7dcdd66138e92caf45b9472c98c4818$1@www.eclipse.org...
> Hi Jason,
> answer lol).
> with dataSource.
Previous Topic:Parent_Last class loading scheme in WAS
Next Topic:Integrating Birt Web Viewer
Current Time: Sun Jul 20 16:42:07 EDT 2025
Powered by FUDForum. Page generated in 0.04685 seconds
