Showing a view twice in same window [message #206740] |
Fri, 05 March 2004 15:37  |
Originally posted by: igor.noemail.com
is it possible to show the same view twice in the same window?
What I want is to see the problems view in the Java perspective twice:
one view with the problems of the current class, the other one with
the problems of the whole current project.
Does that work?
Igor
Re: Showing a view twice in same window [message #212182 is a reply to message #212167] |
Tue, 16 March 2004 20:04  |
Originally posted by: news-reply-200403.iclipse.org
John Arthorne <John_Arthorne@oti.com_> wrote:
>Ah, sorry, I thought you were asking from an API perspective. This is
>not (and probably never will), be possible for a user to do directly.
>The problem is that if a programmatic user of a view is not expecting
>that there may be multiple copies, then it would not act correctly if
>the user opened multiple copies. Each view implementor needs to decide
>if they want to support multiple view instances, and I believe this is
>not planned for the problems view.
Thanks for explaining me.
Do you think, it is possible to create a kind of copy of the problems
view from inside a plugin?
Igor
FUDForum. Page generated in 0.04918 seconds
