Home » Eclipse Projects » GEF » How to control the primary selection
How to control the primary selection [message #211553] Mon, 13 March 2006 21:03 Go to next message
Originally posted by: java.freshman.cx.gmail.com
Hi, all,
I encountered a tough trouble. When I select multiple nodes by dragging a
area, I cannot control the primary selected node whose selection handlers
are solid, while others with hollow ones. Because I find that when mutiple
selection, content displayed in the Property view are out of control.
I am wondering how can I specify which one will be the primary selected
node and how can I control what will be displayed in the Property view?
Thanks.
Re: How to control the primary selection [message #211561 is a reply to message #211553] Mon, 13 March 2006 23:01 Go to previous messageGo to next message
Originally posted by: ytgyazilim.gmail.com
Shawn Chen wrote:
> Hi, all,
> a area, I cannot control the primary selected node whose selection
> handlers are solid, while others with hollow ones. Because I find that
> when mutiple selection, content displayed in the Property view are out
> of control.
> Thanks.
AFAIK properties view will display the common properties across the
selection. So if you keep a common IDing strategy for your model objects
user can - by selecting multitudes of them - change the same properties
for all of them at once.
This also the desired functionality in almost all platforms.
If the user wants to deal with one object's properties alone,
then should select one and one only. If wants to change something like a
color property should select the one he is interested in then make the
change on the property which in turn changes all the selected element
color at once.
H.Ceylan
Re: How to control the primary selection [message #211950 is a reply to message #211553] Thu, 16 March 2006 15:31 Go to previous message
There is a bug open requesting that the properties view display the
properties for the last object in the selection.
"Shawn Chen" <java.freshman.cx@gmail.com> wrote in message
news:c430e893686e48c9063855d0b3caa9cf$1@www.eclipse.org...
> Hi, all,
> Thanks.
Previous Topic:Selection and drag connection tool
Next Topic:Serial Version InvalidClassException
Current Time: Sat Jul 19 09:08:59 EDT 2025
Powered by FUDForum. Page generated in 0.03824 seconds
