How to sort bars in bar chart by Y value? [message #210634] |
Thu, 11 January 2007 10:37  |
Originally posted by: vgryn.yahoo.com
Hi!
Using BIRT version 2.2M2
I created bar chart with the parameter - data set field binding name, so I
can specify row[parameter] for Y axis (values).
Question is: how to make proper sorting of bars from left to right in
descending order in simple bar chart?
I know I can sort the data set, but here it is not an option - in my case I
cannot sort data set because the field displayed by bar chart is a parameter
in report.
I also know I can pass another parameter for data set for sorting, but the
same data set is used for 2 charts and another sorting is already needed for
another chart on the same report.
So, is there any BIRT feature to sort bars in bar chart (much the same way
as sort data in data table)? If not, it would be really good to add one.
Suggestions?
WBR,
Vlad Grynchyshyn
Re: How to sort bars in bar chart by Y value? [message #210650 is a reply to message #210634] |
Thu, 11 January 2007 10:50  |
You can only sort the categories by the categories values now, not by a given
Y series or other value. It's proably a good feature to add in to support
Pareto charts, so you can go ahead and file a bugzilla enhancement. We'll
see if we can implement it in 2.2.
I suggest you simply duplicate your dataset, sort it for the chart you need,
and not for the other chart. I know it's not ideal, but that's the only solution
as for now.
David
> Hi!
> so I can specify row[parameter] for Y axis (values).
> case I
> parameter
> in report.
> the
> needed for
> way as sort data in data table)? If not, it would be really good to
> add one.
> Suggestions?
FUDForum. Page generated in 0.14198 seconds
