Home » Modeling » GMF (Graphical Modeling Framework) » Why a popmenu appear?
Why a popmenu appear? [message #209989] Thu, 30 October 2008 09:27 Go to next message
I have added a new mapping for a link. I generate the code. A new button
appear in the palette. When I choose this palette element and then I click
on the diagram, a popup appears in order to choose between two elements.
I dont know why I have this behavior. This is a problem of visual ID?
I have attached the screenshot of the the popup.
Patrick
Re: Why a popmenu appear? [message #210018 is a reply to message #209989] Thu, 30 October 2008 11:02 Go to previous messageGo to next message
but i could not see your picture,there is only lots of codes.....
Re: Why a popmenu appear? [message #210093 is a reply to message #210018] Fri, 31 October 2008 04:39 Go to previous message
Hi Patrick,
I also can't see your picture but...
Are you using two linkMappings for the same domain metaElement? Have your
domain metaElements a generalization relation?
If it is so, I think it could be working bad because the linkmapping needs
a constraint (if your links are typed based links).
Cheers!
Previous Topic:how get connection from editparts?
Next Topic:Hide unnecessary attributes in Property view
Current Time: Sun Jul 20 07:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.02829 seconds
