Custom figures with external labels and compartment [message #208759] |
Wed, 15 October 2008 11:39  |
Originally posted by: rivera.lcc.uma.es
Hi all,
I'm trying to create a custom figure (svg or jpg image) with several
labels and a compartment, i.e., it can contain other objects. To add
external labels I have follow the post
news://news.eclipse.org:119/c5b37adf7c1477bd4e6fb2f736844a93 $1@www.eclipse.org
on which basically it says that the label must be contained itself in a
Figure descriptor and not inside the custom figure. That works fine.
The problem is that I need three labels (not one) and in the same line.
For this purpose I create in the Figure descriptor instead of a single
label a Rectangule with a Flow layout (force single line = true) and the
three labels (each one having its corresponding Diagram Label). Then I
proceed in the same way as before, adding in the Node mapping the
corresponding label mappings. But in this case it does not work (when i
draw the first custome figure no other object can be drawn after, i.e.,
it gets blocked). How can I get it? (If it can be done not
programatically it will be wonderful)
Then I have got the problem with compartment. I though that custom
figures could be handled in the same way as rectangules are: including
(in gmfmap) a compartment mapping and its corresponding child references
inside the node mapping of the custom figure (in gmfgraph I included the
compartment as well). But again it does not work. Is there any
non-programatically solution?Otherwise, how can I get it programatically?
Thanks in advance,
Eduardo
Re: Custom figures with external labels and compartment [message #208894 is a reply to message #208759] |
Thu, 16 October 2008 13:02   |
I know that the example in http://www.eclipsecon.org/2008/?page=sub/&id=337
is supposed to adress a similar problem, but I just can find the
presentation, not the GMF project I have read in another post that is
supposed to be uploaded...
Jose E. Rivera escribió:
> Hi all,
> Thanks in advance,
> Eduardo
FUDForum. Page generated in 0.04952 seconds
