Home » Language IDEs » ServerTools (WTP) » Struts 2 in Eclipse
Struts 2 in Eclipse [message #209748] Wed, 05 March 2008 23:03 Go to next message
Originally posted by: tomsattler.gmail.com
Greetings. I am trying to set up a Struts 2 project in Eclipse, and I
can't seem to do so. I have installed the Webtools project, as well as
the Graphical Editor Framework, the Eclipse Modeling Framework, and the
Java EMF Model, just like the instructions say. All the tutorials I have
found say "From File->New->Other menu, select Dynamic Web Project". I see
nothing even remotely close to "Dynamic Web Project" in that list. Could
someone let me know what I am doing wrong here?
Thanks very much in advance,
Tom
Re: Struts 2 in Eclipse [message #209756 is a reply to message #209748] Thu, 06 March 2008 00:01 Go to previous messageGo to next message
> have found say "From File->New->Other menu, select Dynamic Web
> Project". I see nothing even remotely close to "Dynamic Web Project" in
> that list. Could someone let me know what I am doing wrong here?
> Tom
Just get the Project Explorer view, right-click in the white space,
choose New->Project... Then click on Web near the bottom and you'll see
it there. Now, from your description, I couldn't tell if you downloaded
Eclipse JEE--that's the one you want.
Russ
Re: Struts 2 in Eclipse [message #209801 is a reply to message #209748] Thu, 06 March 2008 10:12 Go to previous messageGo to next message
Is it possible that you're not running with a 1.5 or higher
supported JRE?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Struts 2 in Eclipse [message #209869 is a reply to message #209756] Thu, 06 March 2008 22:41 Go to previous messageGo to next message
Hello Russ,
Thanks very much for the answer. Yes, you were absolutely correct, I was
not working with the JEE version of Eclipse. I was working with the
"classic" version. Once I downloaded and configured the JEE version, it
worked great.
Thanks again. I don't think I would have figured this out on my own.
--Tom
Re: Struts 2 in Eclipse [message #209874 is a reply to message #209801] Thu, 06 March 2008 22:43 Go to previous message
Nitin,
I am running with a 1.6 JRE. The problem was solved by the first poster;
I was not running with the JEE version of Eclipse, and once I switched
over to that, everything works. Thank you for your insight and assistance.
--Tom
Previous Topic:JULI Logging on Apache Tomcat 5.5 from WTP
Next Topic:JBoss and Dynamic Web Project (Mac OSX)
Current Time: Sun Jul 20 18:38:28 EDT 2025
Powered by FUDForum. Page generated in 0.04468 seconds
