Home » Modeling » GMF (Graphical Modeling Framework) » Additional view initialization
Additional view initialization [message #208274] |
Fri, 10 October 2008 09:50  |
Originally posted by: xxx.xxxxxxxx.xxx
if I want to additionally initialize each node/edge when opening the
diagram, which is the best place to do this?
Kind regards,
Iliyana
Re: Additional view initialization [message #209001 is a reply to message #208461] |
Mon, 20 October 2008 03:38   |
Originally posted by: xxx.xxxxx.xxx
Hallo Tatiana,
thanks a lot for the hint. I couldn't quite get it how XViewFactory works,
but I also found that the XFigure, contained in the XEditPart, contains
some view info.
Regarding the XViewFactory, I guess I need to do some more reading on the
ViewService- do you know where I can find good documentation about it?
Kind regards,
Iliyana
Tatiana Fesenko wrote:
> Hello Iliyana,
> <Element>ViewFactory class is a place where properties of View/Node/Edge
> are set.
> Each EditPart has its own ViewFactory. For example, ClassEditPart has
ClassViewFactory.
> ViewFactories define Color, Font, whether to show name of compartment and
> other presentation properties.
> Best wishes,
> Tatiana.
>> Hello,
>> Kind regards,
>> Iliyana
Re: Additional view initialization [message #209110 is a reply to message #209001] |
Tue, 21 October 2008 13:12  |
Hello Iliyana,
> the ViewService- do you know where I can find good documentation about
> it?
Unfortunately, I don't know about any documentation.
If I needed additional info about working with ViewServices I would start
with general View, Node, Edge documentation, because XViewService and XViewFactories
operate with them ( http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/notati on/class-use/Node.html,
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/notati on/class-use/View.html)
What particular feature you want to change? Maybe I or other people from
the newsgroup can help you.
Best wishes,
Tatiana.
>> Hello Iliyana,
>> View/Node/Edge are set. Each EditPart has its own ViewFactory. For
> ClassViewFactory.
>> and other presentation properties.
>> Best wishes,
>> Tatiana.
>>> Hello,
>>> Kind regards,
>>> Iliyana
Current Time: Sun Jul 20 08:03:47 EDT 2025
Powered by FUDForum. Page generated in 0.03658 seconds
