Home » Modeling » GMF (Graphical Modeling Framework) » How to remove Properties menu item from popup menu and Sort/Filter Compartment Items also?
How to remove Properties menu item from popup menu and Sort/Filter Compartment Items also? [message #208294] |
Fri, 10 October 2008 11:41  |
Originally posted by: mklinchin.yahoo.com
When I right click on an object in a diagram I have two arate menu items:
"Show Properties View" which is always enables and "Properties" which is
always disabled. How can I get rid of "Properties" menu item there?
Also, How can I remove menu item "Filters => Sort/Filter Compartment
Items"? I can remove the whole Filter item in popup menu by adding these
lines in plugin.xml:
<popupPredefinedItem id="filtersMenu" remove="true"/>
<popupPredefinedItem id="filtersGroup" remove="true"/>
But I cannot remove it from main menu Diagram => Filters. I would like to
remove only Sort/Filter Compartment Items and leave Filter menu but even
with Filter it would be fine.
Thank you,
Igor
Re: How to remove Properties menu item from popup menu and Sort/Filter Compartme [message #208581 is a reply to message #208548] |
Tue, 14 October 2008 18:34   |
Hello Ajay,
It works great. I can filter out here both menus and cool bar too. Now I
need to figure out how to remove Proprties menu item in popup menu for
EditParts.
Thank you for your answer!
Igor
On Tue, 14 Oct 2008 13:27:47 +0000, Ajay wrote:
> Hello,
> There is a class extending the DiagramActionBarContributor ,in the init
> method you can remove the menus
> public void init(IActionBars bars, IWorkbenchPage page) {
> super.init(bars, page);
> // To remove the submenus from Diagram Menu
> if (bars instanceof EditorActionBars) {
> IMenuManager iMenuManager = ((EditorActionBars) bars).getMenuManager();
> if (iMenuManager instanceof SubMenuManager) {
> IContributionItem[] iContributionItems =
> ((SubMenuManager)iMenuManager).getParent().getItems();
> for (IContributionItem contributionItem : iContributionItems) {
> if (contributionItem instanceof SubContributionItem) {
> SubContributionItem subContributionItem =
> (SubContributionItem)contributionItem; IContributionItem
> innerContributionItem = subContributionItem.getInnerItem();
> if (innerContributionItem.getId().equalsIgnoreCase("diagramMenu ")) {
> IMenuManager menuManager = (IMenuManager) innerContributionItem;
> menuManager.remove("filterGroup");
> menuManager.remove("filtersMenu");
> menuManager.remove("expandFilterGroup");
> menuManager.remove("alignMenu");
> menuManager.remove("arrangeMenu");
> menuManager.remove("copyAppearanceGroup");
> menuManager.remove("copyAppearancePropertiesAction");
> menuManager.remove("autoSizeAction");
> menuManager.remove("lineColorContributionItem");
> menuManager.remove("routerMenu");
> menuManager.remove("fillColorContributionItem");
> Hope this helps you .....
> Regards,
> Ajay Kemparaj
> Igor Klinchin wrote:
>> Hello,
>> Thank you,
>> Igor
Re: How to remove Properties menu item from popup menu and Sort/Filter Compartme [message #208604 is a reply to message #208548] |
Wed, 15 October 2008 02:49   |
Originally posted by: manojm.blr.interrasystems.com
I have modifide the file accordingly, but it still showing the context menu
Manoj
Ajay wrote:
> Hello,
> Regards,
> Ajay Kemparaj
>> Hello,
>> Thank you,
>> Igor
Re: How to remove Properties menu item from popup menu and Sort/Filter Compartme [message #208769 is a reply to message #208604] |
Wed, 15 October 2008 18:34   |
Hi Manoj,
What are you trying to remove?
Igor
> Regards,
> Manoj
> Ajay wrote:
>> Hello,
>> Regards,
>> Ajay Kemparaj
>>> Hello,
>>> Thank you,
>>> Igor
Re: How to remove Properties menu item from popup menu and Sort/Filter Compartme [message #208777 is a reply to message #208769] |
Thu, 16 October 2008 00:19   |
Hi! Igor,
I want to remove few context menu item from diagram editor.
Manoj
> Hi Manoj,
> Igor
>>Regards,
>>Manoj
>>Ajay wrote:
>>>Hello,
>>>Regards,
>>>Ajay Kemparaj
>>>>Hello,
>>>>Thank you,
>>>>Igor
Re: How to remove Properties menu item from popup menu and Sort/Filter Compartme [message #208811 is a reply to message #208777] |
Thu, 16 October 2008 05:22   |
Hi Manoj ,
The code i had posted was to remove the diagram Menus ,To Remove a Context
menu for a Particular EditPart(in my case its
com.test.gmf.OutPortEditPart) you can use the following snippet .
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria
objectClass="com.test.gmf.OutPortEditPart"></popupStructuredContributionCriteria >
<popupPredefinedItem id="deleteFromDiagramAction"
remove="true"></popupPredefinedItem>
<popupPredefinedItem id="deleteFromModelAction"
id="formatMenu"
path="/filterFormatGroup"
remove="true">
id="filtersMenu"
path="/filterGroup"
remove="true">
id="editMenu"
path="/editGroup"
remove="true">
id="navigateMenu"
path="/navigateGroup"
remove="true">
id="properties"
remove="true">
</popupContribution>
</extension>
Manoj Mitra wrote:
> Hi! Igor,
> Regards,
> Manoj
>> Hi Manoj,
>> Igor
>>>Regards,
>>>Manoj
>>>Ajay wrote:
>>>>Hello,
>>>>Regards,
>>>>Ajay Kemparaj
>>>>>Hello,
>>>>>Thank you,
>>>>>Igor
Re: How to remove Properties menu item from popup menu and Sort/Filter Compartme [message #208842 is a reply to message #208811] |
Thu, 16 October 2008 07:20  |
Thank You Ajay,
I will try that & let you know.
Manoj
Ajay wrote:
> Hi Manoj ,
> Context menu for a Particular EditPart(in my case its
> <extension
> <popupContribution
> id="formatMenu"
> remove="true">
> id="filtersMenu"
> path="/filterGroup"
> remove="true">
> id="editMenu"
> path="/editGroup"
> remove="true">
> id="navigateMenu"
> remove="true">
> id="properties"
> remove="true">
> </extension>
> Manoj Mitra wrote:
>> Hi! Igor,
>> Regards,
>> Manoj
>>> Hi Manoj,
>>> Igor
>>>> context menu
>>>> Regards,
>>>> Manoj
>>>> Ajay wrote:
>>>>> Hello,
>>>>> init method you can remove the menus public void init(IActionBars
>>>>> IContributionItem innerContributionItem =
>>>>> Regards,
>>>>> Ajay Kemparaj
>>>>>> Hello,
>>>>>> items:
>>>>>> which is
>>>>>> these
>>>>>> like to
>>>>>> but even
>>>>>> Thank you,
>>>>>> Igor
Current Time: Sat Jul 19 13:27:04 EDT 2025
Powered by FUDForum. Page generated in 0.04008 seconds
