Change plugin directory! [message #208131] |
Mon, 30 April 2007 07:14  |
Originally posted by: martin.lindblad.gmail.com
Is there a way to change the directory from where eclipse loads the
plugins?
I need this because now we are running eclipse remote and that makes it
very slow during startup. So if there is a way to change the plugin
directory to a local one it would be great. To run eclipse completly
local is not an option.
Re: Change plugin directory! [message #208342 is a reply to message #208334] |
Tue, 01 May 2007 10:20   |
--------------030906040302090507050302
Martin,
Eclipse supports a links folder, just like the plugins folder, and it
can contain .link files that look like this:
path=<path-to-folder-containing-an-eclipse-folder>
The path must point to a folder that contains
eclipse/plugins/<additional-plugins> where the additional plugins will
be treated as if they appeared in the original/main eclipse's plugins
folder itself.
Martin wrote:
> Thanks for the answer, Dave!
> Ok, but don't you think eclipse will run a little bit faster if all
> the plugins are read locally instead of getting all the needed info
> remote? (we will have over 1500 plugins soon). The reason that we
> don't want to run everything locally is that we then can't have
> control over which version everyone are using.
> Do you have a suggestion how we could increase the startup time for
> eclipse?
> Thanks
> Dave Wegener skrev:
>> Is this on a *nix system? If so, you could copy the Eclipse plugins
>> locally
>> and create a symlink to the remote eclipse executable. Now your Eclipse
>> will use the local directory to load the plugins. This setup doesn't
>> make
>> much sense though. Eclipse is almost entirely plugins so having them
>> local
>> and leaving the few remaining pieces remote would'nt seem to buy you
>> anything.
>> "Martin" <martin.lindblad@gmail.com> wrote in message
>> news:f14j2s$ch2$1@build.eclipse.org...
>>> Hi,
>>> plugins?
>>> Thanks
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Martin,<br>
<br>
can contain .link files that look like this:<br>
<blockquote> path=<path-to-folder-containing-an-eclipse-folder& ;gt; <br>
</blockquote>
will be treated as if they appeared in the original/main eclipse's
plugins folder itself.<br>
<br>
<br>
Martin wrote:
<blockquote cite="midf17hlo$25r$1@build.eclipse.org" type="cite">Thanks
<br>
<br>
Ok, but don't you think eclipse will run a little bit faster if all the
plugins are read locally instead of getting all the needed info remote?
(we will have over 1500 plugins soon). The reason that we don't want to
run everything locally is that we then can't have control over which
<br>
<br>
eclipse?
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dave Wegener skrev:
<br>
<blockquote type="cite">Is this on a *nix system? If so, you could
copy the Eclipse plugins locally
<br>
Eclipse
<br>
make
<br>
local
<br>
<br>
anything.
<br>
<br>
"Martin" <a class="moz-txt-link-rfc2396E" href="mailto:martin.lindblad@gmail.com"><martin.lindblad@gmail.com></a> wrote in message
<br>
<a class="moz-txt-link-freetext" href="news:f14j2s$ch2$1@build.eclipse.org">news:f14j2s$ch2$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
plugins?
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------030906040302090507050302--
Re: Change plugin directory! [message #208459 is a reply to message #208334] |
Tue, 01 May 2007 16:35  |
Originally posted by: wegener.cboenospam.com
Your statement is confusing. Plugins define what version you are running.
Outside of plugins, there is only a small executable that starts up a jvm
which runs a startup class that then begins loading plugins. If everyone
copies plugins locally, then there is nothing left on the remote location
that effects versions.
news:f17hlo$25r$1@build.eclipse.org...
eclipse?
> Thanks
locally
make
local
> > anything.
> >> Hi,
> >> plugins?
> >> Thanks
FUDForum. Page generated in 0.09896 seconds
