Home » Modeling » GMF (Graphical Modeling Framework) » Why Notification.getOldValue() don't contains any children
Why Notification.getOldValue() don't contains any children [message #208027] |
Wed, 08 October 2008 05:28  |
Hi gmf guys,
I would like to ask a question. please see the following code:
public class MyEditPart extends DiagramEditPart {
protected void handleNotificationEvent(Notification event) {
Component component = (Component) event.getOldValue();
//why list.size=0? infact the component contains some children
EList<Component> list=component.getChildern();
When I delete a EObject (that is Component) from the generated diagram
editor, why cannot I retrive any children of the EObject?
Thanks in advance.
Feng
Re: Why Notification.getOldValue() don't contains any children [message #208089 is a reply to message #208027] |
Wed, 08 October 2008 08:50   |
Originally posted by: cdamus.zeligsoft.com
Hi, Feng,
When GMF deletes an object from the model, it doesn't just remove its
sub-tree of EObjects from its container, but applies that process
recursively. The Delete{EObject,Element}Command completely
disaggregates the the deleted object and removes all cross-references,
even those within the deleted sub-tree.
So, your deleted object's children must be found by scanning the
Notifications for events indicating objects removed from it. These
*were* its children.
HTH,
Christian
Feng(Marvin) Wang wrote:
> Hi gmf guys,
> @Override
> Thanks in advance.
> Feng
Re: Why Notification.getOldValue() don't contains any children [message #208128 is a reply to message #208089] |
Wed, 08 October 2008 22:29   |
Hi Christian,
Thank you for you kindly answer. How can I get ResourceSetChangeEvent and
scanning it? My scenario is that, when I delete a model in the diagram
editor, I will do something in the handleNotificationEvent method of the
according EditPart.
protected void handleNotificationEvent(Notification notification) {
super.handleNotificationEvent(notification);
But if I delete a parent model, its children's EditPart will not be
notified.
I find that DiagramEventBroker will not fireNotification if the model is
deleted by deleting its parent model.
Feng
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:gcia9t$1k2$1@build.eclipse.org...
> Hi, Feng,
> recursively. The Delete{EObject,Element}Command completely disaggregates
> the the deleted object and removes all cross-references, even those within
> Notifications for events indicating objects removed from it. These *were*
> its children.
> HTH,
> Christian
>> Hi gmf guys,
>> @Override
>> Thanks in advance.
>> Feng
Re: Why Notification.getOldValue() don't contains any children [message #208173 is a reply to message #208128] |
Thu, 09 October 2008 10:56  |
Hi, Feng,
Sorry, I'm not sufficiently familiar with the diagram framework's
handling of events to be able to answer usefully.
Perhaps an expert from the GMF run-time team will respond.
Christian
> Hi Christian,
> according EditPart.
> @Override
> notified.
> Feng
>> Hi, Feng,
>> its children.
>> HTH,
>> Christian
>>> Hi gmf guys,
>>> @Override
>>> Thanks in advance.
>>> Feng
Current Time: Sat Jul 19 13:32:39 EDT 2025
Powered by FUDForum. Page generated in 0.03672 seconds
