Home » Language IDEs » Java Development Tools (JDT) » ant build, go to line of error
ant build, go to line of error [message #207716] Thu, 23 June 2005 16:11 Go to next message
Originally posted by: none.not.no
It appears that eclipse doesn't allow me to go to the line of the next
build error, if I use ant, is that right? I can go to the line in the
build.xml file, but that doesn't help me when the error is in a java
file.
Re: ant build, go to line of error [message #207733 is a reply to message #207716] Thu, 23 June 2005 16:33 Go to previous messageGo to next message
This would be incorrect on the latest 3.1 builds...attached picture shows
the linkage for a simple test build
Clicking on the link for the Testing.java compile error will take you to
line 10 in that file.
What build are you using?
Darins
"Frank Fredstone" <none@not.no> wrote in message
news:874qboal57.fsf@not.no...
> file.
  • Attachment: antLinks.PNG
    (Size: 15.15KB, Downloaded 134 times)
Re: ant build, go to line of error [message #207757 is a reply to message #207733] Thu, 23 June 2005 20:28 Go to previous messageGo to next message
I was using 3.0, I get the same result with 3.1 RC2, but it's actually
only errors from checkstyle that are not being clickable. I see now
that something like a syntax error is clickable. It would be nice if
variations on filename:line were matched in the console output, and
made clickable.
"Darin Swanson" <Darin_Swanson@us.ibm.com> writes:
> Darins
>> file.
Re: ant build, go to line of error [message #207840 is a reply to message #207757] Fri, 24 June 2005 10:12 Go to previous message
Please log a bug report against Platform Ant with full details so we can
consider this enhancement for post 3.1
Darins
news:87aclgfvii.fsf@not.no...
> made clickable.
>> Darins
>>> file.
Previous Topic:How to ensure consistent code format on CVS
Next Topic:A dummy's question
Current Time: Sat Jul 19 06:33:07 EDT 2025
Powered by FUDForum. Page generated in 1.08120 seconds
