Home » Archived » OHF » Installation Directions for OHF Bridge
Installation Directions for OHF Bridge [message #19265] Fri, 18 August 2006 17:55 Go to next message
I'd like to announce the initial set of instructions for installing the
OHF Bridge. Please note that this works with code checked in as of August
16th. There has been one code check in since then, and there are some
integration kinks being worked out. It is possible within CVS to check out
code only checked in by a certain date, and I would suggest this technique
until all of the kinks are ironed out. I will announce when this happens,
and update the install instructions accordingly. The link is here:
http://wiki.eclipse.org/index.php/Ohf_bridge#Bridge_Install_ Steps
Melih
Re: Installation Directions for OHF Bridge [message #20722 is a reply to message #19265] Wed, 04 October 2006 06:38 Go to previous messageGo to next message
Originally posted by: Martin.Ahrer.gmx.at
I'd like to set up a local OHF bridge. Is there an updated version of
the installation instructions. I'm trying to set up with a current CVS
version and I have figured that the procedure from
http://wiki.eclipse.org/index.php/Bridge_Install_Steps does not quite fit!
I'm getting some errors while exporting the eclipse plugins...
org.eclipse.ohf.ihe.xds.consumer does not find
org.eclipse.ohf.ihe.xds.soap.* classes while I feel that I have followed
the instructions!
Is there any timeline as when pre-built binaries will be posted to some
download server?
Martin
> August 16th. There has been one code check in since then, and there are
> some integration kinks being worked out. It is possible within CVS to
> check out code only checked in by a certain date, and I would suggest
> this technique until all of the kinks are ironed out. I will announce
> when this happens, and update the install instructions accordingly. The
> link is here:
> Melih
Re: Installation Directions for OHF Bridge [message #20751 is a reply to message #20722] Wed, 04 October 2006 19:13 Go to previous message
Originally posted by: eishays.us.ibm.com
We can't publish the link yet. Should be public after some legal process
is over.
You may get the PHP client app from the CVS (nothing to compile there).
Its available at:
http://ibmod235.dal-ebis.ihost.com:8080
You may also just use the public installation we have. We are updating
it with bugfix and there are few ISVs that use it:
http://ibmod235.dal-ebis.ihost.com:8090/bridge/services/ohf- bridge?wsdl
--eishay
> the instructions!
> download server?
> Thanks
> Martin
>> the OHF Bridge. Please note that this works with code checked in as of
>> are some integration kinks being worked out. It is possible within CVS
>> to check out code only checked in by a certain date, and I would
>> suggest this technique until all of the kinks are ironed out. I will
>> announce when this happens, and update the install instructions
>> Melih
Re: Installation Directions for OHF Bridge [message #570910 is a reply to message #19265] Wed, 04 October 2006 06:38 Go to previous message
the instructions!
download server?
Martin
> link is here:
> Melih
Re: Installation Directions for OHF Bridge [message #570996 is a reply to message #20722] Wed, 04 October 2006 19:13 Go to previous message
is over.
Its available at:
--eishay
> the instructions!
> download server?
> Thanks
> Martin
>> Melih
Previous Topic:FYI - Remaking American Medicine
Next Topic:XDS Metadata Model refactored .. please update.
Current Time: Sat Jul 19 11:23:13 EDT 2025
Powered by FUDForum. Page generated in 0.25942 seconds
