Border Item Rectilinear router with nested EditParts [message #207042] |
Thu, 25 September 2008 07:54  |
Originally posted by: uwe.suedbeck.koeln.de
--------------000006060407040805030604
Hello Mohammed, hello GMF-Group,
I want to create an Editor that displays the Routing for a specified
Network component. The example below displays the Routing-Informations
for a Networkcard which is instaled in a PC. The NC has a Container that
contains 2 connectors. One ISA to the PC and one Lan-Connector. The PC
also has a Container containing the NC.
Picture BorderItem-/RectilinearRouter
I tried the RectilinearRouter for the Routing of the Connections and
wasn't very happy with the result. Then i found the
BorderItemRectilinearRouter and thought this would be exactly what i need.
After i followed Sandip's instructions how to set up the
EditPartProvider i finally got it workin, but there seems to be no
difference between these both routers.
I read the Diagram-Informations from a file. Is this a Problem? I am not
sure but maybe the Positions of the EditParts aren't set when the Router
tries to route the Connections? Can this be a Problem? Or is it because
the Connector-Editparts reside in a Container?
Picture CollapsedAndMoved:
I can collapse some of my Containers and in this case all Connections
that leave this Container are switched to the TopLevelEditPart. Then the
Routing seems to follow the features explained in the New and
Noteworthy, at least for the side connected to the TopLevel-Editpart:
http://wiki.eclipse.org/GMF_2.0_New_and_Noteworthy
Thank you, Uwe
Content-Type: image/jpeg;
name="RectilinearRouter.jpg"
Content-Disposition: inline;
filename="RectilinearRouter.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAYEBQYFBAYGBQYHBwYIChAKCgkJ ChQODwwQFxQY
GBcUFhYaHSUfGhsjHBYWICwgIyYnKSopGR8tMC0oMCUoKSj/2wBDAQcHBwoI ChMKChMoGhYa
KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCj/wAAR
CAFKAwgDASIAAhEBAxEB/8QAHAABAQACAwEBAAAAAAAAAAAAAAMEBwIFBgEI /8QAWBAAAQMC
AQYJBggJCgUDBQEAAAECAwQRBRITFCFTcgYxM0FRkZOy0QciNJKx0hUyVWFx gZShFzVCUmJ0
lcHTFiMkNjdUVnOztHWkwtTxQ4KiJURjhKPh/8QAGwEBAQACAwEAAAAAAAAA AAAAAAEFBgID
BwT/xABAEQEAAQMCBQIBCAYJBAMAAAAAAQIDEQQhBRIxQVEGYRMUIjKBkaGx 0RUWUlNxwSM0
QmJygpKi8CQzsvHS4eL/2gAMAwEAAhEDEQA/AP1SAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAABVREVV4kBKr9Fm3HewsRmQRZZERzMhjV4spFVfagyZ9pF2a +8VAyMaofPDT
yy5cS5DVdbIXXZPpPCu8ozWyPYtNdzFyXZEcrkRei6Nse7xH8X1P+U72Kafw L4td+su7rRke
l/CO3+6P7Cb3DtODfC9cdxDRYYmRqiLlK5r0Vq2vxORDzJXgL/Xas+hP9NBk bLyZ9pF2a+8c
JHyxqiOkZdbqiJC5fYvzmQRla9aiNY1RLNddVbdONvzlid9xwWSRGoudYt+J Eicq9Vzkqyoz
LWWNE+eJb9Vz4xujyOc7Kcjk42tVdd1VdSfSfZke5mUiorLtcjclcrUqKv79 Vi9xwzr7KudZ
9Cwuv1Xv/wCBnX2Rc6z6Ehdfqvf/AMnxyq6oSZGvyG2v5q34nc3HzoGqrahZ la/Ide3mrfib
zcfMpcI+rK9ES0rFvzNhcqp9Nl1DPO48/Fk/nZpcnrvY+QqsT3ue19n8Vmqv 5Tl5uLUqEoUd
FRMidG9ZGORyojVXidfj4uIuBkMfK9bJIxF47Ohc32qc8mfaRdmvvHGF2XJl PystEsiZDmoi
fSvHzdXEXOEzhUsmfaRdmvvDJn2kXZr7xUEyJK6SPXJkOZzq1LW+oqSq/RZt x3sKiemQABAA
AAAAfHuRjbqTypl4omIn6T7L9yKJ+UgTpf8A9KlS9BLKn2cXaL7phYvia4XS LU1MLVjRyN8x
+vX9KIdkeZ8ov9WJt5PYoz7DA/CNg+0i+0R+I/CNg+0i+0R+J5HCoY1wyjVY 2XzLPyU/NQys
zFs2eqgz7DYOB44zGoXy0UTc2xUTKdIllv0KiKdnlT7OLtF908T5IfxFL9Lf 3nuxn2GPnn5z
ItBl/m53X1WGefnMi0GX+bndfVY45aMfkNex6Zd82qedrW9+Pm4+Li6zjlN0 PM5SZ/Jtk387
L6evXf6zniPCLPklY1XPZC1qc6yKn7jis70Yj1zCMXUjs7qX7hM5yPjdIjWs a/42VzZKpr1a
uYmx7EqnSq5qRrlIj1XUupnP9S9QiI8Cjp3tRquzDUdrRVltf7g6Z7Xo1yQI 5eJFl1r9xOne
yOR7pHNa12tquWyL5zl1dadZONUZRyxvVGyOYiNaupV8xE1J9OovLHgZCTvV XImYu3WqZ3i+
nUfY58pLqjMm9spj8pEUx87G2ClRytVY7ZTbpdq5Kpr6NduM5vc2SnqZEexz 83ZUY66JZFt+
8nLHgZgAOtQAAAAAOMj0YialVV1Iic5yJP8ASo9xy/e0sBlT80cf1vXwGVPs 4u0X3SoGfYdP
jmOMwWFktbE3NvVUymyJZLdKqiHRfhGwfaRfaI/Ej5XvxDH9Lv3HQ5mLZs9V Bn2HpPwjYPtI
vtEfiejwjE1xSkSppoWpGrlb579er6EU1fikMaYZVqkbORf+Sn5qnvPJz/Vi DeX2IM+w9DlT
7OLtF904JO9VciZi7dapneL6dRkGLC9EdFG17JGt1IiJ5zLJxrr+riTjLGJ7 AlUqrZFpl59U
3/8AhyjmfJfNpA63Hky3t9xxl5Gu+vuIUyZVekitYjmtVETKXXdU57fMcpiB xdM9r0a5IEcv
Eiy61+4Z5+cyLQZf5ud19VicrkSOqY9Wtkf8Vt9a+aiaunWTqlR1FNCiosqv VUYnxvj34vo1
limEXSocrVci06tbxrnuL7gtQ5Go5Vp0a7iXPcf3E5pGOq6Z7XtVjMrKci6m 3TVdeY+tlYj5
nNliYrnIqPcl0cmSnEt0vruTljwMlkiq7Je3JdxpruinMxmpZlGllbrRLLxp 5i6jJOEwoACA
AAAAA4PkVHZLG5TuO17WOOVPs4u0X3RDys++if8AxQqXoJZU+zi7RfdOgxvh bSYNVLBXMaxy
Ii5Syta1bpfUq2PSGreHjUdw1o0ciKll1Kn/AONRn2He/hGwfaRfaI/E5R+U LCpXoyJWPevE
1s7FVfoS55nMxbNnqodbjcbGpRK1jUXSW60T5nDPsNxwzTTQskbFHkvajkvI vEv1HJ8krGq5
7IWtTnWRU/cccO/F9N/lN9iHKrvmUsqIuWy195CxiZBkkr2o5jIXNXnSRV/c cc8/OZFoMv8A
NzuvqsIstucREa6XKu665KWtqVOPo67k8pubzeUmcz18i+u2Xfi+jWcsQKNm e56takCuTjRJ
dafcGzvcjlbmHI3WqpLe33GPIqPo4o2KjpGsVHNTWqeYqa0+nUUqHskkY6Nz XNbrcrVuiec1
dfUvUXljwiiTvVivTMKxNSuzupPuPi1DkajlWnRruJc9x/ccHvYtU2VHNWNM lFei6k1P5/rT
rOLX5E80rHRuSRURt3WvZE4rIt+McseBk5U+zi7RfdGVPs4u0X3T7TtVlPE1 yWc1qIqfUUOu
ZhUsqfZxdovujKn2cXaL7pUDPsJZU+zi7RfdGVMnHExU/Rfr+9EKgZ9h8Y5H tun/AIPpKHlJ
9/8A6UKiQABAJVfos2472FSVX6LNuO9haesCoAIOs4QYjTUFC9tS5yOmY9rE axzrrb5kXpNN
089dSPqEgpmSRySrIivbK1UuiJayRr0GwvKjSTVuFwQ08bnudlJqaqp+Tx6l 6DW/wBWfJ6di
z+EBmfCWJf3KH/8At/DOz4FVuhcIJq3E2uibIn/pxSORLNtxq1DhgtHUUeGx wSwSo9rnrZsa
2RFcqpxInMvQVSCsSqme7Oup3NRGRZh12rzre2sDbUMjZomSRrdj2o5q2tdF ORjYYitw2kRy
KipExFRebUhkgAAAAAAAAAAAAAEqv0Wbcd7CpKr9Fm3HewqXsAAIAAAAACU3 KQb691xUlNyk
G+vdcVLPYDyPlGraVMDlpXVMDahXJ/NukRHa0XmPXGp/KUlQvCG1O6RES2Wj Hqn5KWvZzV+8
g6CixrMUcELqRVdHG1iqlRDa6Jb88t8Pp/dHfaIffOrnZXLDIkTqlJMlclc6 9Nf1zL7FPW52
PaM60A7byUVdNBhj6aapgZUuc1EjzrVVV16ksuv6jYRqvg3LM/EqHS1gSXSE skTrpa+r6zag
AAAAAAAAAlV+izbjvYVJVfos2472Fp6wKgAgAAAAABJ3pUe472tKknelR7jv a0sCoAINe+Ve
rpp8MbTQ1MD6lrnIsedaiourUt11fWeQ+H0/ujvtEPvmRwzSpXhLVZl0uaRz 0VGPcnnZXQj2
8x1ETa1KiBUdUIiSsVyrI+2TlJe95VTivzAZNbjWfo54W0io6SNzEVaiG2tL fnmyfJzW0q4H
DStqYHVCOX+bbIiu1InMeTkmbm3Zt8avsuTd2q/Nc7PgTJI/GKLSFiz+Q/LS NbtRcleIDY4A
AAAAAAAAAlNykG+vdcVJTcpBvr3XFSz2AAEAAAAABKHlJ99O60qSh5SffTut KlkfHuaxjnvc
jWtS6qq2RENR8PMRgfwogqqSSGqZGnnJHMxONludUQ2pin4sq/8AJf3VNEzp WLUzrlTqxXqr
MmR9snmtaVqfcQZ3w+n90d9oh98xqzE0rX0rcykLY5kkc988SoiIi9DlXnKY NpLMRyp3ypBm
nIuckcqZV221K93NfoO3rJpUjboboHSZSXzjtWTz8XOBtDBKymq8Ph0Woimy I2I7NvR2Stue
xnnk+ATmuSvVqoqXZxL8ynrAAAAAAAAAAAAAAAAAJQ8pPvp3WlSUPKT76d1p UsgACASq/RZt
x3sKkqv0Wbcd7C09YFQAQAAAAAAAAAAAAAAAAAAAAAEqv0Wbcd7CpKr9Fm3H ewqXsAAIAAAA
ACU3KQb691xUlNykG+vdcVLPYCb4IZHZT4o3O6VaiqUBBHRafYReog0Wn2EX qIWAEm00DXI5
sMaOTiVGoVAAAAAAAAAAEqv0Wbcd7CpKr9Fm3HewtPWBUAEAAAAAAJO9Kj3H e1pUk70qPcd7
WlgVABBJ1NA5yudDGrl41VqHzRafYReohYAR0Wn2EXqIcmQQxuymRRtd0o1E UoAAAAAAAAAA
AAlNykG+vdcVJTcpBvr3XFSz2AAEAAAAABKHlJ99O60qSh5SffTutKlkFRFR UVLovMR0Wn2E
XqIWBBHRafYReog0Wn2EXqIWAHGOKOJFzbGsvx5KWOQAAAAAAAAAAAAAAAAA EoeUn307rSpK
HlJ99O60qWQABAJVfos2472FSVX6LNuO9haesBnX7CXrb4jOv2EvW3xKgZ9h LOv2EvW3xGdf
sJetvicnyxx/Hexv0rY46TBtovXQv1BnX7CXrb4jOv2EvW3xGkwbaL10Gkwb aL10GJ8BnX7C
Xrb4jOv2EvW3xGkwbaL10GkwbaL10GJ8BnX7CXrb4jOv2EvW3xGkwbaL10Gk wbaL10GJ8BnX
7CXrb4jOv2EvW3xGkwbaL10GkwbaL10GJ8BnX7CXrb4jOv2EvW3xGkwbaL10 GkwbaL10GJ8B
nX7CXrb4jOv2EvW3xGkwbaL10GkwbaL10GJ8BnX7CXrb4jOv2EvW3xOTJY5P iSMd9C3OZPqG
LVSPWmlRYZE8xdaq3Vq+kyiVX6LNuO9hUs9AABxAAAAABGpcjXQKt7I/mRVX 4q9B90hnRL2b
vATcpBvr3XFTltgS0hnRL2bvAaQzol7N3gVBNhLSGdEvZu8BpDOiXs3eBUDY S0hnRL2bvAaQ
zol7N3gVA2EtIZ0S9m7wGkM6Jezd4FQNhLSGdEvZu8BpDOiXs3eBUDYS0hnR L2bvAaQzol7N
3gVA2EtIZ0S9m7wJVU7FppURJNbF443JzfQZRKr9Fm3HewsYyKgA4gAAAAAE JnoypiVUcvmO
4mqvO3oLknelR7jva0sdQ0hnRL2bvAaQzol7N3gVA2EtIZ0S9m7wGkM6Jezd 4FQNhLSGdEvZ
u8BpDOiXs3eBUDYS0hnRL2bvAaQzol7N3gVA2EtIZ0S9m7wGkM6Jezd4FQNh LSGdEvZu8BpD
OiXs3eBUDYS0hnRL2bvAaQzol7N3gVA2GO+Vr5oERHp56/GYqfkr0oZBKblI N9e64qJ7AACA
AAAAAx2StZNOio9fPT4rFX8lOhDnpDOiXs3eAh5SffTutKnKcCWkM6Jezd4D SGdEvZu8CoJs
JaQzol7N3gNIZ0S9m7wKgbCWkM6Jezd4DSGdEvZu8CoGwlpDOiXs3eA0hnRL 2bvAqBsJaQzo
l7N3gNIZ0S9m7wKgbCWkM6Jezd4DSGdEvZu8CoGwlpDOiXs3eA0hnRL2bvAq BsJaQzol7N3g
NIZ0S9m7wKgbCWkM6Jezd4DSGdEvZu8CoGwjTORzp1S9lfzoqL8VOksSh5Sf fTutKirqAAIB
Kr9Fm3HewqSq/RZtx3sLT1gVOEz83DI9PyWqpzJVfos2472COo5RRoxur43O vOpzAIMfEfxf
U/5TvYppWjhqax9S5K6SFscyxtYyKNUREROlqrzm6sR/F9T/AJTvYppzBJGN SuRz2ouku41/
RaBy+Dan5Un7GL3Tt/J8szOFc8E07p0iTzXOY1q2Vl/yUQjnY9ozrQvwDcju GtYrVRUsmtP8
tANomO+RzKpbr/NI1MpOi6rr+77zIOKxtV7nLrymo1UXitr8Sx7iET3yuczL VuSqrdES6+c5
ETX9BzllRrchsiLIitRdaXS6ol7fWGU6MYiMkejkv52pVXXfXdPnPlXJHDTK 6dzslFamUjVV
b3REsiJrW9uY5TMZHBzpGzJDnHLlW85US6anfNb8noDXSOmWHOOTJv5yIl11 N+a35XQY2l06
rlLpyv1Wfokl04/0Lc69Y0unRcpNOR+u79EkuvF+hbmTqGYGUjnLGjnSPREc rfMZdVsqpddS
9B8c+TNMfnUSRzUVsbbWctvv19C8XWY+mQIiIxa9vTakk16731s+deI+JVwN X+bWvYlkSyUk
i2RE+dgzAyXMV0qNzmW78rUnmauNOdNducvA9ZIY3rxuai/cYEVbDHZEWvVq cy0kmv8A+B9p
cSgSmhRWVepicVLKvNuknoMyr9Fm3HewqddVYlAtNMiMq9bF46WVObdKfCcG zq/skvuk7DNB
hfCcGzq/skvuj4Tg2dX9kl90gzQYXwnBs6v7JL7o+E4NnV/ZJfdAzQYXwnBs 6v7JL7o+E4Nn
V/ZJfdAyJuUg317rjB4UYn8CcGsWxXIR+g0k1VkL+VkMV1vuOU2JQLJD5lXq f/dZfzV/RPO+
U/EqdfJtwraqVLcrCqpqK+mkal1icia1bZNandYoi5dooq6TMR96VdJaXqcP Zi0ml8IWtxSv
kTKkkqkziI7nRrVujWpxIiImol/JzBPkbDfsrPAz6p07YHLSxxyzaslkkisa uvXdyI5U1fMp
hYfVVVfwbpquFIG1tRSNlajkVI0kcxFS/Pk3X6bHmPy3iF6mb/xpiJqiPpTG JnM9M7Rt4x46
PEqtRqLmbtVc7z58uP8AJzBPkbDfsrPA9b5NK+fA+F+F4ZRyPTC8SdLC+lc9 XMje2J8rXsRf
i6o1RUTUt050PJQYrpkmEaIy0dbC6qdnU1pEjW6ksvxsqSPpSyO+Y9HwX83h 1wYmX4kVXK5y
JrcqLSTt81vG5bqmpEVbXXiRVMnwm/raNdbtai5VMVRVtMzPTmjeJ8TSynBb uoo4hZpqqnee
me28T+DdXCjE/gTg1i2K5CP0Gkmqshfyshiut9x+d6nD2YtJpfCFrcUr5Eyp JKpM4iO50a1b
o1qcSIiJqN0eU/EqdfJtwraqVLcrCqpqK+mkal1icia1bZNamoap07YHLSxx yzaslkkisauv
XdyI5U1fMplfUl+9YtWYsVzTNdVUTicdOXG+2I+dOe3no2L1leu0fBot1Yic 98dMfmwP5OYJ
8jYb9lZ4D+TmCfI2G/ZWeBfBKp9fgtBVzI1slRTxyuRqWRFc1FW3zazpabhX Sz4Phssdbh78
RqXUzZKdsqKqLI9iPRG3vdEc76LazXrVPFr1ddu3crmaaopnFVW0znr7bTu0 umNVXM001TOJ
xO8+/wCTYHk0r58D4X4XhlHI9MLxJ0sL6Vz1cyN7YnytexF+LqjVFRNS3TnQ 3maC4L+bw64M
TL8SKrlc5E1uVFpJ2+a3jct1TUiKtrrxIqm8PhODZ1f2SX3Tb+D3q72ht13J zVOczPX6U/ye
k+lbty7w+JuTM7z18M0GF8JwbOr+yS+6PhODZ1f2SX3TJNjZpKr9Fm3Hewx/ hODZ1f2SX3Sd
ViUC00yIyr1sXjpZU5t0sdR2IML4Tg2dX9kl90fCcGzq/skvukGaDC+E4NnV /ZJfdHwnBs6v
7JL7oGaDC+E4NnV/ZJfdHwnBs6v7JL7oGaSd6VHuO9rTH+E4NnV/ZJfdJuxK DSY1yKv4jv8A
7WXpb+iWBx4UYn8CcGsWxXIR+g0k1VkL+VkMV1vuPzvU4ezFpNL4QtbilfIm VJJVJnER3OjW
rdGtTiRERNRujyn4lTr5NuFbVSpblYVVNRX00jUusTkTWrbJrU0pwjrKrD8F q6uhiglkgifI
qTPVqIjWqt9SLddSatV+lDB8eq1EU6e1pa+Wq5VVHXHTlxvtt86fuaT6wuXu axatVY5s98eM
fi4/ycwT5Gw37KzwH8nME+RsN+ys8DspZGQxPlme2ONjVc57lsjUTjVV5kOt wDEZ6+GRK2n0
apZkPWJbo5GPYjkui69Sq5l+dY3cXEmoUariNy1Xepu1ctOM/Onvt537Z8Zh otNzUVUzXFU4
j3et8mlfPgfC/C8Mo5HpheJOlhfSuermRvbE+Vr2IvxdUaoqJqW6c6G4OFGJ /AnBrFsVyEfo
NJNVZC/lZDFdb7jSvBfzeHXBiZfiRVcrnImtyotJO3zW8bluqakRVtdeJFU2 V5T8Sp18m3Ct
qpUtysKqmor6aRqXWJyJrVtk1qb76frq1WmsTemZmZxMz1+lMdf4PS/S925c 4dE3JmZzLS9T
h7MWk0vhC1uKV8iZUklUmcRHc6Nat0a1OJERE1Ev5OYJ8jYb9lZ4GfVOnbA5 aWOOWbVkskkV
jV167uRHKmr5lMfBKp9fgtBVzI1slRTxyuRqWRFc1FW3zazQqtdxC5bq1Pxq sZxtVPWcz0zt
G23btHR5rXqNRcibtVc9fKH8nME+RsN+ys8D1vk0r58D4X4XhlHI9MLxJ0sL 6Vz1cyN7Ynyt
exF+LqjVFRNS3TnQ1/wbxx+JpQumxjBpJJ4kkdRwx2lRVbdW3zq605/N5l4j 23BRF/CBwTdb
UlbMn/J1JnND8u03E6dLqblVW1WYmasbRV2qiM4mM5jbxLMcIq1NniVq1VVM 779enfq36ADb
nq4AAJTcpBvr3XFSU3KQb691xUs9gABAAAAAASh5SffTutKkoeUn307rSpZE GsbNlOkTKajl
ajV4tS24jlo0Gxi9RBTcmu+/vKVLMzEiWjQbGL1ENV8I6zEU4UVVHQTsiYmU /wA/LVEsqJZE
RyW4zbJqTGv691n+W/voTMjHysd/v9P6knvnGGtxWDFaOCqqo5I5lXk8tqpa 3S5ek7A66r/H
uE/S/wD6RmRuHRoNjF6iEp4I2rG2OGFFc611jReZV/cZROaJsuRloita69lS 99Sp+8sVSMVI
2umzSRU6OS93Zrj+KvFf9I5oyFKZ8iwRKrMq6I1EvZV8CrqeNzmXYzIaiojc lLa7eH3nKSCN
7VRWNTzclFREuifMcuZGLJGyJyNdFA5XcSpHa2tE+vj+4LGxsiRLFAr1tZ2b 1JdHc3/t6ecu
6F71RZHtVyfFyW2TjRdev5kCwvV2cV7c4lrKjdWq/Nf9Jecc3uIJGx0ixJFA j0vd2b1LZG83
/u6eY+tYxXRItPBkuc5irk86X5rfMWSF6OziPbnFvdVbq125r/opznxYHpkZ MjUyXK7Wy91W
9+fi1jm9xGnY1ysymsjcqcTYlYt7cSLcy4HK+NFdxoqtX6lt+44pG9XtV70c jFulm2Xitr1/
P0Cm5Nd9/eUlU5VUAHASh5SffTutKkoeUn307rSpZAAEAlV+izbjvYVJVfos 2472Fp6wKkqv
0Wbcd7CpKr9Fm3HewU9YFQAQeS8o2KVOF4ZG+lkcxHo5HtaiecmpLa0Xp5kN SyRsler5aNj3
rxudFdV+tac3hwiwKHHYY4qiRzWMvqRqKjr247/Qef8Awc4ZtF7NoGv8Mwii raNk6wMjVXOa
rczEtrOVOeNF5ug7HCM1heISMwyqdDVRNynMZFG1LKnGtmWU9zBwJp6eJsUF XKyNt7NaxqIl
1uc/5Gw3VdNmuupVyG+AHo8Pe6WgppJFynvia5y9KqiFydNEkFPFC1VVI2Ix FXnsligAwsX9
Ej/WIP8AVYZphYv6JH+sQf6rAM0AAAAAJUnosO432FSVJ6LDuN9hewVfos24 72FSVX6LNuO9
hUdgABAAAAAASm5SDfXuuPPeVD+zThb/AMIq/wDReehm5SDfXuuMXhBhrMaw HEsLmcrI66ml
pnORL2R7Faq/ed1muLdyiuekTE/elXSX59qmzugclLJHFNqyXyRq9qa9d2or VXV86GBhGH1l
Bh9BSPrY5GUtmKrIMjORtjVqNW7nWW9nXTotY7WegxrDJFpMUwXFnVMXmukp KGapik/Sa+Nr
ksvHZbKnOhP+mfIvCH9i1f8ADPN44bxW1bq09FiqqmZzmKObO0xmKuWe0zjE 7derxmeH6+3E
2vg1Yz+zn264YGF4SzD6usnZK561DtSKlslMt8lvnXKlfr6MlONFVfQ8FP7Q eCX67N/s6g63
+mfIvCH9i1f8M9T5OeD2JV/Cqgxeqoaugw/DVkkYtXC6GSaV0bo0RGOs5Go2 RyqqomuyJfXb
I8M0XEZ4hTqdZbqjaczVTMf2ZiOsRv09+7JcI0Otq4hau3bdUYmMzMTHRsDy of2acLf+EVf+
i80pVNndA5KWSOKbVkvkjV7U167tRWqur50P0Fwgw1mNYDiWFzOVkddTS0zn Il7I9itVfvNB
z0GNYZItJimC4s6pi810lJQzVMUn6TXxtcll47LZU50Mp6h0uo1Vqz8momua JqnERnry423z
HzZztjy2D1fpL9/4NdmiauXPSM9cdvqdVhGH1lBh9BSPrY5GUtmKrIMjORtj VqNW7nWW9nXT
otYMwjJwKgw7P30XR/5zI+NmnMdxX1XyOnVfnOx/pnyLwh/YtX/DH9M+ReEP 7Fq/4Zr1el41
Xc+LNivPNFW1vHzomZidqfef+RDTp0nEJq5vhVZzn6E9d/b3dlwU/tB4Jfrs 3+zqDfppnyc8
HsSr+FVBi9VQ1dBh+GrJIxauF0Mk0ro3RoiMdZyNRsjlVVRNdkS+u25jbeEW Lmn0Vu1djFUZ
zE9Y+dMvRPS+nu6fQRTdpmJzM4kABkWxBKr9Fm3HewqSq/RZtx3sLT1gVABA AAAAACTvSo9x
3taVJO9Kj3He1pYHnvKh/Zpwt/4RV/6LzRWO0U+I4XUUdPPHBn2Oie98SyeY 5qotkRzbLr49
f0H6M4QYazGsBxLC5nKyOuppaZzkS9kexWqv3mg56DGsMkWkxTBcWdUxea6S koZqmKT9Jr42
uSy8dlsqc6GE45Z1Vymxc0dE1V26qp2jmnflxOMTnHL48NM9W6bUXarNzT0T Vy56Rnxjb6nV
VmH1ldSNp6qtjzb2OjqGxwZLZWq9qqiXcqt8xHt1L+XfmQ5UWEx0NetRTSz5 L4s3K2aV8yvV
Fuxcp7lVEbd+pOPL+Yz/AOmfIvCH9i1f8Mf0z5F4Q/sWr/hmtfJONfDmzFiu KZzmItzETnzE
U4ntjP0cRy4xDTPkfEeXk+FVjxyz3+r7PHZ2XBT+0Hgl+uzf7OoNr+VD+zTh b/wir/0Xmv8A
yc8HsSr+FVBi9VQ1dBh+GrJIxauF0Mk0ro3RoiMdZyNRsjlVVRNdkS+u21+E GGsxrAcSwuZy
sjrqaWmc5EvZHsVqr95ufAbdej09mm9GJpnMx3j50z9uHofpnT3bHD+S7TMT mZxL8+1TZ3QO
Slkjim1ZL5I1e1Neu7UVqrq+dDAwjD6ygw+gpH1scjKWzFVkGRnI2xq1Grdz rLezrp0WsdrP
QY1hki0mKYLizqmLzXSUlDNUxSfpNfG1yWXjstlTnQn/AEz5F4Q/sWr/AIZp McN4rat1aeix
VVTM5zFHNnaYzFXLPaZxiduvV53PD9fbibXwasZ/Zz7dcOrwXD8Rw6no6WWu pJqSnibEiNpH
Me5GtsnnZxUvqTm6j1XBL+vPBb9fk/2VUdT/AEz5F4Q/sWr/AIZ6zycYNVVv CSirqyhrqCKh
e+ogWqgWF0zs0+JyIx1nIiJMi3VEvzc9stwrT8QjiVOr1lmaYxXmZo5IzNNU eIiZzP8AH6oZ
ngWk1n6Tt3r1qYjfM8uI6T7Q3GADbHpwAAJTcpBvr3XFSU3KQb691xUs9gAB AAAAAASh5Sff
TutKkoeUn307rSpZEqbk13395SpKm5Nd9/eUqJ6jBxyqlosKqKiDIzrETJy0 unGiGjcVxOLF
a+SsnVElcrtbHtjVNetLJOi83Ob0xikdX4bPTMejHSIiI5Uuia0X9x4Zvk6k almV2S3oRz0R
PvIPC4bSRYg+VsU8rViRqreaRya721tmXoU7CHDG0dZBLpUSTXtHnVkdfpRE dIvQexo+Ak9I
+R8dZG50iIjlflOWyXtxr86lpeBc8r43yT0rnxrlMVY1u1fm1gei4M18+I4e 6aqzecSRWfzb
ValkROZVXpO2Os4P4dJhlC6CWRsjlkV92pZNdvA7MAAAAAAAAASpuTXff3lK kqbk13395S9h
UAEEoeUn307rSpKHlJ99O60qWQABAJVfos2472FSVX6LNuO9haesCpKr9Fm3 HewqSq/RZtx3
sFPWBUAEAAAAAAAAAwsX9Ej/AFiD/VYZphYv6JH+sQf6rAM0AAAAAJUnosO4 32FSVJ6LDuN9
hewVfos2472FSVX6LNuO9hUdgABAAAAAASn1Zt/Mx11+iyp+8qioqXRboCa0 8KrdYY1XpVqF
/iKAlo0Gxi9RBo0Gxi9RBsKglo0Gxi9RBo0Gxi9RBsKglo0Gxi9RBo0Gxi9R BsKglo0Gxi9R
Bo0Gxi9RBsKglo0Gxi9RBo0Gxi9RBsKglo0Gxi9RBo0Gxi9RBsKkqpbwvYnx norUT6Ro0Gxi
9RDmyKOO+bY1t/zUsNoHIAEAAAAAAJS+bNG9dTURWqvRe3gVC601lgAS0aDY x+qg0aDYxeog
2FQS0aDYxeog0aDYxeog2FQS0aDYxeog0aDYxeog2FQS0aDYxeog0aDYxeog 2FTCl/HVL+rz
d6IyNGg2MXqIYctPD8M0qZqOy08y2yU/OjGw7EEtGg2MXqINGg2MXqINhUEt Gg2MXqINGg2M
XqINgkXLmiRutWKrl+bUqfvKnxjGsSzGo1OhEsfRIAAgAAAAAJQ8pPvp3WlS UPKT76d1pUsi
VNya77+8pUlTcmu+/vKVE9QABAAAAAAAAAAAAAACVNya77+8pUlTcmu+/vKX sKgAglDyk++n
daVJQ8pPvp3WlSyAAIBKr9Fm3HewqSq/RZtx3sLT1gVJVfos2472FSVX6LNu O9gp6wGjs6Ze
0d4jR2dMvaO8Sp4Hhb5Ro8IxSXDcIw1cUrIFRKhzp0hhicqIqNV+S5VdZUVU Rq2v06jjXdi3
TNVdWIjvM4j7ZdGp1NnS0fEvVRTHu9zo7OmXtHeI0dnTL2jvE1V+FPG/8MYb +2H/APbD8KeN
/wCGMN/bD/8Atj5/0hpv31P+qPzY79YOHfvo+9tXR2dMvaO8Ro7OmXtHeJrn BPKkk2IQ02P4
QmGxTPSNlVDVaRE17ls1HqrGK1FVUS9lS/HbjNlnfbvU3aea3VFUeYnMfc+/ S6yxq6eexVFU
eyWjs6Ze0d4jR2dMvaO8Tw3C3yjR4RikuG4Rhq4pWQKiVDnTpDDE5URUar8l yq6yoqojVtfp
1HR/hTxv/DGG/th//bHXc1lm3Vy3LlMT4mqIn7MvkvcZ0Niubdy7ETDaujs6 Ze0d4mHi0DEp
WWWT0iDjkdtW/Oa2/Cnjf+GMN/bD/wDtjKw3yjT4pWU9DiuCpQJJNG5KmGrS eJuS9HLlqrWK
1LNXXZUuSnW6eueWm7TMz/ej80tcb0F2uLdF2JmejZejs6Ze0d4jR2dMvaO8 SoPozLKpaOzp
l7R3iNHZ0y9o7xKgZkS0dnTL2jvEUnosO432FSVJ6LDuN9hc5gKv0Wbcd7Cp Kr9Fm3HewqTs
AAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABhS/jql/V 5u9EZphS/jql
/V5u9EBmgAAAAAAAAAAAAAAAlDyk++ndaVJQ8pPvp3WlSyMaCNzmuVJntTLf qRG/nL0oUzT9
vL1N8BTcmu+/vKdPwv4TUfBfDWVNY2SaWV+ap6aFEWSZ9lWyXVERERFVVXUi IWqrGZlwuXKb
dM11ziIdxmn7eXqb4DNP28vU3wNVL5VMZVbs4MUKN5kkxZyO+tEgVPvUfhTx v/DGG/th/wD2
x8n6Q0v72j/VT+bFfp/h376PvbVzT9vL1N8Bmn7eXqb4GrYPKtiEcrVxDgzG lPfz3UeIZ6Rq
c6ox0TEX6LmzcKxClxbDaavw+Zs1JUMSSORv5TV9n0cx3W79u9GbVUVY8TE/ g+zScQ02sz8n
rirHhXNP28vU3wGaft5epvgec4bcMaXgtHBGtPLW4jUo5YaWJUaqtS13Ocup rUuiX6V1Ip43
8KeNrxcGMOt8+Lvv/tzjc1Vm1OLldNM+8xH4urU8V0elr+HeuRE+G1c0/by9 TfAZp+3l6m+B
qr8KeN/4Yw39sP8A+2OcHlWxCOVq4hwZjSnv57qPEM9I1OdUY6JiL9FzhGv0 0ziLtH+qn83R
HH+HTOIvR97aWaft5epvgM0/by9TfAlhWIUuLYbTV+HzNmpKhiSRyN/Kavs+ jmMo+nMwy8TE
xmEs0/by9TfAZp+3l6m+BUDKpZp+3l6m+B8pEtCqKqr579a8/nKWJU3Jrvv7 ylzsKgA4iUPK
T76d1pUlDyk++ndaVLIAAgEqv0Wbcd7CpKr9Fm3HewtPWBUlV+izbjvYVJVf os2472CnrAqf
m6eRI6/H5pMp1sVxBzslqucqNqZUSyJrVbIiWToP0ifm2WRIqzHZHI5WsxXE XKjWq5bJVy8S
JrVfmQwnqOM8PiMZ/pKf/GvZqPrL+p0f44/CWC3H6B8EE0TqmVkzEkYkVJK9 2QqqiOVqNVWo
tlsqol7La5lPxGjZo2VUR2qbZlUddHotrKipqsqq1L8V3NTjciL5jDkSnwjC nvdjNBUaDDBI
6no1kVysRUyXNWN6tVqq7XZt8rUrrauVXS4zit5HUdNHVRU0cTVmldGkNR5s rnsRGuSRqOSL
jXjiVOJVvg7nBdLF6YiqaaImYmaqoidpxtmmKZxPXFU7dYpqmKWjVaO1z4zi nfrP1eIjbvv9
k7O74V6uC+LqnGlJK5F6FRiqin6gPy7jNW53BKvrGRLG5aGSVIqiJFVq5tVy XsW6X5lRbofp
X4Mg2lX9rl94yvpqmaNJVTV1iufwpbl6LjFm9E9cx+D88T1McWMYqkz7S1ON V8bNSrlObUTK
ifU1i9R9raynoYkkq5WxMV2Siu6ePqREVVXmRFVbIiqdTjN6TE84rameOn4Q YhnHMidM+2cq
m5So1FVdaprtzkMVbNjU8DKeiz9EyF6vZWLJSo50iOjSy5CuujUlRUVE1SNX XqtjOJcOou8S
uV15i3NVzmnaIiYrriKYmcREzERiJnvno1PX6eKtbcqq+jzVZn/NO2+3h3Xw hS/Cnwdnf6bm
dIzeSvJ5WTe9rcfNe5i4xVRz8F8alpnqqMpKtmUiKlnMY9q9StXqOnpKSvrK iWeZjmYnT0kC
RzSsVsb6iN1Qxy8WtjspeJL5L0VLLa31HyO8n2MSvgnpnTRV8manZkPa175V RFTmWyoXT8Ps
aPVWblFXNNFy1FW8TvOapmNo22iI94nPZx09q3p9RbuROeWqjP4zj28fXl+t wAbm9jAAAJUn
osO432FSVJ6LDuN9hewVfos2472FSVX6LNuO9hUdgABAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAMKX8dUv6vN3ojNMaqpM/NFKyomgkja5qLHkrdHKi rfKRfzUAyQYW
hz/KVX6sXuDQ5/lKr9WL3AM0GFoc/wApVfqxe4NDn+Uqv1YvcAzQYWhz/KVX 6sXuDQ5/lKr9
WL3AM0GFoc/ylV+rF7g0Of5Sq/Vi9wDNBhaHP8pVfqxe4NDn+Uqv1YvcAzQY Whz/AClV+rF7
g0Of5Sq/Vi9wDIh5SffTutKnXQ0c6yT/AP1GrSz/AM2LX5qfoFNDn+Uqv1Yv cLIyKbk13395
TU/lulZFwh4Nvne1kMdHXyuc9bNbZ1MmUq81kV3WbMp6OdY1tiNWnnu4mxfn L+gaZ8vE7qXh
FgUNS1tbHHTuqM5UXasLUqqbLd5mSmSiNRyqqLbI6LovC7Zi/TVanbmiY+2J hi+M24uaK5RM
4zER98POsxbDn0clWyvpHUkbsl8yTNVjV1aldeyLrTrQyKWpgq4Gz0s0c8Lr 5Mkbkc1bLZbK
mrjQ8/VY/hUeIz1zY8OnjyIIYKnPLm1m/n7tWTKVrclqqq286z1TzrtReywj EaB0aSsfQSz1
tQqPdSyOkYsqR3yb5S60jYmvVe17Jexoer4L8G1NyIqjpjMTPaJmJiKY6b/O 26Y5esx5bd4f
TRTzc3/l4z+z28/VhaixbDq+VYqGvpKmRG5Sshma9UTpsi8WtDcXkX/s9pE5 kq65qfMiVkyI
h+e+DOJxVcWARo7CapGMa5tNSZxJKP8AmXJlPXOuVURFzetE1vRb31Lv3ySQ vqOA1NJDUy0r
Fq61M1CjVaipVzIq+e1y3VUuuvjVbWSyJtHDuG0cOvXrNEzMfN65ztNcd6af Hj+GYxM7d6Z0
lGm1dymmrPzffz7xH/PteP8AKtKyLyi1Ek72sihwemcrnrZrEWapylVeZPNS /wBB5RmLYc+j
kq2V9I6kjdkvmSZqsaurUrr2RdadaHdeWV2i8MahKlkdYkdJh0yzTIrVZGlX NdXZCtbZmS59
7JxrlXRDxtVj+FR4jPXNjw6ePIghgqc8ubWb+fu1ZMpWtyWqqrbzrPVPOu1F +Li/CY1mrruR
EzPzIxHTam3t0nGeaZz2iMzE74xfHdFTe192vm3zG2/in2nrn6vtx6ClqYKu Bs9LNHPC6+TJ
G5HNWy2Wypq40MeixbDq+VYqGvpKmRG5Sshma9UTpsi8WtCOEYjQOjSVj6CW etqFR7qWR0jF
lSO+TfKXWkbE16r2vZL2JcEX1TsFw6WZKBKR9JGscEMMjVjRWtsmU6V10RNX FrNfucLs2rd6
q5XyzTMRTnmjrzZ/sTnE0zET82JxM7TswdWitU01zVciMYxnm9/7u/T2/k3b 5F/7PaROZKuu
anzIlZMiIe3PEeRjX5PqXVb+m1+r/wDcmPbnotf0pev6P+r2/wDDH4AAOL6Q lTcmu+/vKVJU
3Jrvv7yl7CoAIJQ8pPvp3WlSUPKT76d1pUsgACASq/RZtx3sKkqv0Wbcd7C0 9YFSVX6LNuO9
hUlVJelmRPzF9gp6ip+c6mN9Nj2P0szVZNHilXIrV1LkyTPlYv0K17VP0Yi3 S6Hn+EfA3AeE
dRHUYtQq+pjbkNnhmkgkyfzVfG5rlT5lWx8PEdFGv086eqrl3ic4zvGY8x2m WG45wurimni1
TViYnP8AL+bSYNq/gs4J/wB1xL9sVn8Ufgs4J/3XEv2xWfxTXv1Tp/ff7f8A 9NS/UrUfvafv
aY4SxunwGupoWq+eqidTQsTWr5JEyGtROlVVD9PHl8D4BcG8ExBldQ0D1q40 VI5amqmqVjvx
q3Ovdkr86WU9QZ7hnD44fZmzFXNmZnOMdYiPM+G0cB4PVwu3XRXVzTVOdn5z qY302PY/SzNV
k0eKVcitXUuTJM+Vi/QrXtUG7OEfA3AeEdRHUYtQq+pjbkNnhmkgkyfzVfG5 rlT5lWx1H4LO
Cf8AdcS/bFZ/FMXrvTlOr1Feo+LjnmZmOXO87z3juwOt9IXr+oru0XIxVMzv nvu1UdbwljdP
gNdTQtV89VE6mhYmtXySJkNaidKqqG5/wWcE/wC64l+2Kz+KZ+B8AuDeCYgy uoaB61caKkct
TVTVKx341bnXuyV+dLKcNL6Zp096i98XPLMTjlxnE5/adVj0beouU11XIxEx Pd6gAGzvQQAA
CVJ6LDuN9hUlSeiw7jfYXsFX6LNuO9hUlV+izbjvYVHYAAQAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABKHlJ99O60qSh5SffTu tKlkSpuTXff3
lNO+WRFbw9wKRU8xcPqIr/pLJG5E6mOX6jcVNybt9/eU6LH8AoOEc9ZQ4pE5 8WZgex7HKx8T
0dLZ7XJrRUuvWqLdFVDq1Fr41uu1nHNEx9sYfDxLSzrNLXYpnE1Q0qDYf4Ja Pm4S8IUTovSL
7YB+CWj/AMS8If8AlP4Bp/6o6j99R/v/APg8/wD1N137VP2z+TXhtXyLov4O 6J3M+qrZGr0t
dVzKi/Wiop18fklw3ON0rHMeqob+dC+SCNr06FWOJrkT6HIbCo6aCipIaWki ZDTwsSOONiWa
xqJZEROhEM3wfhNfDYriuuKpqx0zjbPmInv4bH6d4Ff4ZcruXqonMY2/9Q0z 5UkVnlJc5yWS
XCadGL05E1RldWW3rPPG7uFvBXDeFFNFHiCTRzQKroKmnfkSxKvHZbKiotku ioqLZNWpDyn4
JaP/ABLwh/5T+AfNxbgFziOpnUW7lNOYiJirm7REbYie0R43fDxn0zqdbq6t RZqpxVjrmO2P
E+GvAbD/AAS0f+JeEP8Ayn8A5R+SXDc43Sscx6qhv50L5II2vToVY4muRPoc hjY9I3463qMe
3Pn76Y/GGLj0bru9VP2z+TsPIui/g7oncz6qtkavS11XMqL9aKintyVHTQUV JDS0kTIaeFiR
xxsSzWNRLIiJ0IhU3Wqczl6RYt/Ct02/ERH2AAI7QlTcmu+/vKVJU3Jrvv7y l7CoAIJQ8pPv
p3WlSUPKT76d1pUsgACASq/RZtx3sKnx7Uc1WrxKllLG0j6CKOkYiNdG59vy mqmvrU+51+wl
62+IwCRyMS0cjUanEjm3t96DJn2kXZr7wzr9hL1t8RnX7CXrb4l3DJn2kXZr 7wyZ9pF2a+8M
6/YS9bfEZ1+wl62+I3DJn2kXZr7wyZ9pF2a+8M6/YS9bfEZ1+wl62+I3DJn2 kXZr7wyZ9pF2
a+8M6/YS9bfEZ1+wl62+I3DJn2kXZr7wyZ9pF2a+8M6/YS9bfEZ1+wl62+I3 DJn2kXZr7wyZ
9pF2a+8M6/YS9bfEZ1+wl62+I3DJn2kXZr7wyZ9pF2a+8M6/YS9bfEZ1+wl6 2+I3DNyOS0kj
VavGjW2v96lUSyWTiJZ1+wl62+Izr9hL1t8RiZCr9Fm3HewqRdlzNVixuY1d TlcqcX1KWJPT
AAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAACU
PKT76d1pUlDyk++ndaVLIhdzZXpC1HIq3cirZEX6TFidN8M1X83HfR4fy1/O k+YzKbk3L+m/
vKY8X46qv1eHvSlmRkZU+zi7RfdPNYpw1ocMrJKasa2ORjlb50zWotui9j1R qLHGNfw6rEc1
HJm38aX/AC0Jn2HqPwjYPtIvtEfiVpuH2G1UzYqdGySOW2SyZjl6kU8tmYtm z1UMCpYxmO4V
kNa3W/iS35oz7DceVPs4u0X3T4+SVjVc9kLWpzrIqfuLEqiyNY5XoxWuujnJ dOJU19ZYxPYc
WyyPRFa2F19aWlVb/cfc5La+RDa9r5xeO9ugir1yUlajXq19rs1Zy6W9qp1H 1kbmSxxKquby
l157JZdX02X6zliBRkskiXjbC5OK6Sqv7j42Z7nq1qQK5ONEl1p9wpnq6P8A mshzc4+65XF5
y/MY8io+jijYqOkaxUc1Nap5iprT6dQiIz0RkNne5HK3MORutVSW9vuCTvVi vTMKxNSuzupP
uJ1D2SSMdG5rmt1uVq3RPOauvqXqD3sWqbKjmrGmSivRdSan8/1p1jljwKLL M6PKYkFl1I7O
Kqew+RyOjVIrRK5PyUlu5efishKV0XnPc5muZqscqpxebeylJJGPVrY3sVFc 1chE85fOvf6O
fiGPYZLHI9t0/wDB9JQ8pPv/APShU4SqUPKT76d1pUlDyk++ndaVEgACAAAA AAAAAAAAAAAA
AAAAAAAAAAAJQ8pPvp3WlSUPKT76d1pUsiVNya77+8pjxfjqq/V4e9KZFNya 77+8pjxfjqq/
V4e9KJ6jKnmip4nSzyMjibrc962RPrNM8I8Rij4W1VXTrHUwuRzLxzxprykX 8pydBtPhWqJw
frFXUlk7yGkWNrrLnHVKuuuvOv6fmlRPuQg7P4fT+6O+0Q++TjxJtVjFBLIx tPHCrspz5414
7fmuXoKYCs7Jqpap8iRq1mQkj1XX517Xe75uc7KomlSaDR3QLErv51Xu1onz fOBtqlqoKuLO
Us0c0d7ZUbkcl/pQqee4DqjsHkVqoqZ92tPoQ9CAAAAAAAAAAAEoeUn307rS pKHlJ99O60qW
RKHlJ99O60qSh5SffTutKiQABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEoeUn307 rSpKHlJ99O60
qWRKm5Nd9/eUx4vx1Vfq8PelMim5Nd9/eUx4vx1Vfq8PelE9RmOa17Va9Ec1 eNFS6EtFp9hF
6iFgQR0Wn2EXqINFp9hF6iFgBxjYyNuTG1rU6GpY5AAAAAAAAAAAABKHlJ99 O60qSh5SffTu
tKlkSh5SffTutKkoeUn307rSokAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABKHlJ 99O60qSh5Sff
TutKlkY0EzWtcio+6PfxMcv5S9CGPFOz4ZqltJ6PD/6bvzpPmMym5Nd9/eUx 4vx1Vfq8PelL
OMjI0hnRL2bvAaQzol7N3gVBNhLSGdEvZu8BpDOiXs3eBUDYS0hnRL2bvAaQ zol7N3gVA2Et
IZ0S9m7wGkM6Jezd4FQNhLSGdEvZu8BpDOiXs3eBUDYS0hnRL2bvAaQzol7N 3gVA2EtIZ0S9
m7wGkM6Jezd4FQNhGmcjnTql7K/nRUX4qdJYlDyk++ndaVFXUSh5SffTutKk oeUn307rSokA
AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAABKHlJ99O60qSh5SffTutKlkSpuTXff3l NW+V/GKynxqj
wainlpo8QplmqJInKx6xROVFYjk1pd0rbqmuyKnObSpuTXff3lNQeWKF/wDL vA57IkXwbUsu
qol1zsK6k41tz24rpfjQ+fW3Jt2LtdM4mKapj+OJwxXG7ldrQXa6JxMQ8GvB 3BnLd+FUMjl4
3SQNe5fpVUuo/k5gnyNhv2VngKqorpsUlo6CWmgzMMcz3zQuly8tz0RERHtt bNr03vzW14Mm
KYi/BYsXh0SOndTsnbSuY6SSVXNRUYj7tRHK5chEyXa7Lrvkpo1v9I3OX/qJ iZxtNVXWremP
80bxjOP7WHlNPyirH9JO+O89+n2/+8OxgwTD6WVs2H0sdBUNW7J6NMxI1eZU c2ym9/JtjFVj
vAugrsQc11ZlSwSvalke6KV8SutzXyL2+c0ybV8i/wDZ9S/rtf8A7yYzPprV XtRTd+NXNWOX
GZmcZ5vP8G1ejdRdrvXKK6pmMd593twAbO9BAAAAAAAAAABKHlJ99O60qSh5 SffTutKlkSh5
SffTutKkoeUn307rSokAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABKHlJ99O60qS h5SffTutKlkS
puTXff3lNVeWj+tPBj9Sr+/Sm1abk13395Twflb4O12KR4ZiuFQOqqjDs6yS mZbLkikyVdk3
43IsbFtzpe2uyL0ayiq5YuUU9ZpqiP4zEsXxqzXe0F23bjMzDUVXQ1Wnvq8P qYIZJImRSJPA
sqKjFcrbWe2y+e6/HfVxW19fDgNVSTQOpKykcymiZDTaXSLK+FrWI1clySNR FXWqqiIq3st0
RETv/wCmc+CcIUXo+BqtfZGP6Z8i8If2LV/wzSrVnjlqnkosV4mMf9rOY6b5 pnO20e2Y6TLy
+nS8RpjEWqvH0P8A6/5DmbV8i/8AZ9S/rtf/ALyY1THFiU8jYqXAcekmetmt fhk8LVX53yMa
1qfOqobs8n+BzcHeCVDhtW9j6pmcmmVnxUkkkdI9E6URz1RF+Yy/pzQ6jSU3 flFuaM8uMxMT
tntO/ds/pDRaixeuV3aJpjGN4x393oQAbI30AAAAAAAAAAEoeUn307rSpKHl J99O60qWRKHl
J99O60qSh5SffTutKiQABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEoeUn307rSpK HVLOnPlIv1ZK
eBUsiUCo1XxrqcjlW3Sirf8AeVOL2MkSz2tcnQqXOGjQbGL1EG0ioJaNBsYv UQaNBsYvUQbC
oJaNBsYvUQaNBsYvUQbCoJaNBsYvUQaNBsYvUQbCoJaNBsYvUQaNBsYvUQbC oJaNBsYvUQaN
BsYvUQbCoJaNBsYvUQaNBsYvUQbCoVURLqtkJaNBsYvUQ+pTwot0hjRd1BsP kGtZH8z3XT6L
In7ioAncSh5SffTutKkoPjzrzK//AKUKiQABAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAHB8aOW6K5
ruK7Tjmn7eXqb4FQXIlmn7eXqb4DNP28vU3wKgZEs0/by9TfAZp+3l6m+BUD Ilmn7eXqb4DN
P28vU3wKgZEs0/by9TfAZp+3l6m+BUDIlmn7eXqb4DNP28vU3wKgZEs0/by9 TfAZp+3l6m+B
UDIlmn7eXqb4DNP28vU3wKgZEs0/by9TfAZp+3l6m+BUDIlmn7eXqb4DNO55 5VT/ANvgVAyP
jWo1qI1LIh9AIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAD/2Q==
name="BorderItemRectilinearRouter.jpg"
filename="BorderItemRectilinearRouter.jpg"
CAFDAxEDASIAAhEBAxEB/8QAHAABAQACAwEBAAAAAAAAAAAAAAMEBwIFBggB /8QAXRAAAQMC
AQUKCQYKBwMKBwAAAAECAwQRBRITITFyBhQ0QVFTkZOx0QciM1RxgZKy0hUW MmGU0xcjJDVS
VVZ0ocFCdYKVpLO0NkNzN0RFYmOExNTw8QgloqPC4eP/xAAbAQEBAAIDAQAA AAAAAAAAAAAA
AQIGBAUHA//EAD8RAQABAwIEAwIJCwMFAAAAAAABAgMRBCEFEjFBBlFhcZET FCIygZKhwdEV
FiNSU2JysbLS8DM0QjWCk6Lx/9oADAMBAAIRAxEAPwD6pAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABJZHOVc0xHImi6usgyp+bi6x fhFJwWH62Iv8
CplO2wllT83F1i/CeUqd32G0szoqhGxyNW2S+ZjV6FU9gaXpmMfj2K5bWu0s 1pf9ImfQez/C
Ng/ORfaI+8y8L3a0OJ1cdNRtbJI9yN8WZrkS/La55DMxc2z2UJ4GxrN3VGjW o1M2zUlv6ajP
oNsZU/NxdYvwnF8skaXkbC1NV1lVP5FyNTlI6DIRFdl6lW39FSxiew455+by 7QZH6Wd0dNjk
ySV7UcxkLmrxpIq/yJ2WOZJJla1q3VdOhq2aiafQi6frscqhzpKeTNI17HMd pR11vZdSW0lx
ANne5HK3MORulVSW9v4BJ3qxXpmFYmhXZ3Qn8CdQ9kkjHRua5rdLlat0Txmr p6F6A97Fqmyo
5qxpkor0XQmh/H606S8seSKLO9GI9cwjF0I7O6F/gFneitRcxd2lEzuv0aCb HsSqdKrmpGuU
iPVdC6GcfqXoJMc1KerarkR0jnqxFXS5FTRbluXljyGS2Z7nq1qQK5NaJLpT +Bzyp+bi6xfh
JRSxzPjRj40a3SxqOS66FTVxaL//AKMownbsqWVPzcXWL8Iyp+bi6xfhKgmf QSzkjdMkaI3j
Vrr2/ghUayVJppYb/oN7B2FQAQAAAAABVsl11Es8q/QikenKlk7VQVXkrcSu ai+hXIhUvbIl
nX8xL0t7yVVWtpKd89RFKyJiXc7QtuhTKOr3U/7P1ux/NBn0GN86cN/Sm6tR 86cN/Sm6tTVG
DYTQVGHMlno4JJHOernOYiqvjqZ3yHhfmFN7CDPoNp0GN0uISvjpGyyPamUq ZOTZPWZ2dfzE
vS3vNeeCiNkNbiccTUZGx70a1NSJlmyBn0Es6/mJelveM6/mJelveSmYiOlk cxkjW6VVV8Zl
k1Jo9etNZyYyN7XvmRqua513LraiLo08Wiy/xMsR1HPOv5iXpb3jOv5iXpb3 knPe6njSRjkV
cjKVbWW6pdLdPEcXsYlU2JGtSNclVYiaF0P4vUnQMC+dfzEvS3vGdfzEvS3v IMYxap0Stasa
ZSoxU0JoZxetekU7GSSPbI1rmt0NRyXRPGcmjoToLiOovnX8xL0t7wk1l8eN 7E5XWt/BTCgR
q4fHNJbOK5LyKtnWyra9eoyoomq9XNiSONWqittbKvxqnfyqJiIRkAnSqrqa JV0qrEVegofO
dlAAAAAA/HORrVVy2RD9JT6XwpxK/T0Kv8iwGdcv0YZFTl0J2qM6/mJelveV Az6DCrsSioIM
9VRysjujb2RdK+hTr/nThv6U3VqY3hF/2Ym2k7FNbYbg2GyYdSvfQ07nOiYq qrEuq2QZ9BtL
504b+lN1ambh+LQYg160bJZEYqI7QjbdKmqfkPC/MKb2EPVeCFLYDIiakVqJ /EZ9B7fOv5iX
pb3jOv5iXpb3lTFyEY/Lcxj0y7ZxF8bStrauLVr1dBYxIrnX8xL0t7xnX8xL 0t7ybIIkqn2i
YlmtVLNTQt3EqRlo4HMgVio1Fc5MlMtMnVr5bLpLiBk51/MS9Le8Z1/MS9Le 84I1s07s7Gi2
Y1Ua9EW2l3chjxoj6OWR6I6RrEVrl0qniIuhfTpLEQMvOv5iXpb3jOv5iXpb 3mG9rUp6RyNR
HSOYj1RNLkVNN+W5ZYo8+9jY41sxrkjXQ291utujTYcsIyGSo52SrXMdyO4z mYqaKZnK2VE9
Hj2sn1cRlGExhQAEAAAAABxe9GIl7qq6kRLqpwzr+Yl6W94TTVPvxMbb1qvc hUvQSzr+Yl6W
95g1+N0uHysjq2yxvcmUiZOVdPUdma38K8bJq3DI5Wo+N72I5q6lTLGfQer+ dOG/pTdWo+dO
G/pTdWprb5DwvzCm9hDBxnCaCnw6SWCjgjka5itc1iIqeOgz6DdVLWtq6dk9 PFK+J6Xa7Ql+
lSudfzEvS3vMDct/s/RbH81M+r4LNsO7CxvIZ1/MS9Le8Z1/MS9Le8nCixvl RI0aqI38XGqW
49PF/wCkOErUdHVSOYmW36KqmlviouhfSXEZF86/mJelveM6/mJelveQyW5v OZKZzPWy7abZ
dtfo0E5ERlHFIxEbI5iq5yaFXxFXSvp0limEZedfzEvS3vGdfzEvS3vIVDGR yMbG1rWu0ORq
WRfGamnpXpPx8TUqlRsKPiRiKsaIlspVXTZdHEMR1GRnX8xL0t7xnX8xL0t7 z8pFvAi2VEut
k5Eutv4FjGdpVLOv5iXpb3jOv5iXpb3lQTPoJZ1/MS9Le8Z13HBKif2e8qBn 0H4x6Pbdv/sf
pJmiqlTiyWr69PcVEgACAAAAAAlScFh2G9hUlScFh2G9hUs9RKqqoKSLOVU0 cMd7ZUjkal/S
po+TEm0uMV8sbG1EcytyXMnjTVf9Jycps/wh5XzddkLZ+WmSt7acl1jULG1u Q3KWpyrafxkm
vriDs/l9PNHfaIfjMjc5iMUm62lq6hY6aFrWsvJPGunKVf6LlOOAuljp50q3 uRVluxJHqq5O
S3lc5dd+My3zS78YjHU+9clctVd4+VxW4rAbdgmiqImywSMkidpa9i3RfWcz qdyiou5+jVNK
ZK+8p2wAAAAAAAAAAAAAAJUnBYdhvYVJUnBYdhvYXsKgAgAAAAAJVPk022e8 hUlU+TTbZ7yF
S9gOq3UqiYBW3VPofzQ7U1r4WFelRSrE3KcrGoviI6zcp19bXdhB5bCsQZSU LIJqetSRjn3t
TSKn0lXWiGZ8swcxXfZJO488qOt9D/7LfuD0OHUdPJh9K+ekgzzomufeJqLl KiX0W5QPQeCt
yrW4k9zHxpI572pI1WrZX6NC6TY5pujhjz8t6CKnRkiIx6I3x05dCaDcgHF0 bHPRzmNVyalV
NKB0bHPRzmNVyalVNKHIFyCojkVFRFRdCopwSGNGKxI2IxdKtyUspzBMjgsM asRixsViaUbk
pZA6GNyNR0bHI3QiK1FscwXMjgsMbnK5Y2K5dCqrUuGQxxreONjV1XRqIcwM yJUnBYdhvYVJ
UnBYdhvYVE9QABAAAAlN5SDbX3XFSU3lINtfdcWBUAEHmfCH425uVrdLlciI ia10Ka2oMVih
oaaKSnrkeyNrXJvWTWiJ9R2nhNy03Qfi2IrXWy1zaO1NS2tjrdB46fOthkWK O70aqtTMNW6+
jMJ2oB6X5Zg5iu+ySdx63wSoseCStkarH3bdrksqa+I838n0fmlP1be4tuXj auJUT3UMdJJv
lqZKIl7X13QDbBxzbM5l5Dcv9K2npOQAWS6rZLrouERGoiIiIiaERAAOMkbJ LZxjXW1ZSXsH
Rsc9HOY1XJqVU0ocgXI4JDGiuVI2XdoVclNPpPzMRZGTmmZN72yUtcoBmRGo RGwtRERER7ER
E2kLEqnyabbPeQqOwAAgAAAAAJN4VJsN7XFSTeFSbDe1xUsga48KjlStw57W PkSNzHuSNquW
yP06E0mxzQWMZz5UqG5tM2lsn8U1b316c26/SQdt8swcxXfZJO4w8VxBlXQv ghp61ZHuZa9N
IifSRdaoYOHsWTEqZj4Wvic5yPR0LbWyVVP9022lE4zvaukp4aaSSHDoJpGp dsaMamV67AbP
3Kqi4BRWVPofzU7VURyKioiouhUU8JuAjZHiMuRCyK9PdWtREt4yaNB7sBZL otkumi5xdGxz
0c5jVcmpVTShyAHHNszmXkNy/wBK2npDY2Nermsajl1qiaVOQLmRwbDG1HI2 NjUdoVEaiXPz
MRZGTmmZN72yUtcoBmQABAAAAAASbwqTYb2uKkm8Kk2G9ripZAAEAAAAABKk 4LDsN7CpKk4L
DsN7CpZ6jjIxkjcmRrXN5HJcnvWn5iL2ELAgjvWn5iL2EG9afmIvYQsAPxrW sajWIjWpqREs
h+gAAAAAAAAAAAAAAAlScFh2G9hUlScFh2G9hewqACAAAAAAlU+TTbZ7yFSV T5NNtnvIVL2A
xK3DKKuka+rpo5XtSyK5NSGWCDq/m/hXmEHQPm/hXmEHQdoAOsTAMKRUVKGC 6aU0HZgAAAAA
AAAAAABKk4LDsN7CpKk4LDsN7CpZ6gACAAABKbykG2vuuKkpvKQba+64sCoA IMGqwigq5lmq
aSKSVbIrnJpUj838K8wg6DtAB1fzfwrzCDoOcOCYbBMyWKjhZIxcprkTSinY gAAAAAAAAAAA
JVPk022e8hUlU+TTbZ7yFS9gABAAAAAASbwqTYb2uKkm8Kk2G9ripZA6xcAw pVVVoYLrpXQd
mCDq/m/hXmEHQPm/hXmEHQdoAMOiwyioZHPpKaOJ7kyVVqa0MwAAAAAAAAAA AAAAAAACTeFS
bDe1xUk3hUmw3tcVLIAAgAAAAAMWlnYlNEipJoYmqNy8XoK74ZyS9W7uFJwW HYb2FTKcZEt8
M5Jerd3DfDOSXq3dxUE2Et8M5Jerd3DfDOSXq3dxUDYS3wzkl6t3cN8M5Jer d3FQNhLfDOSX
q3dw3wzkl6t3cVA2Et8M5Jerd3DfDOSXq3dxUDYS3wzkl6t3cN8M5Jerd3FQ NhLfDOSXq3dw
3wzkl6t3cVA2Et8M5Jerd3DfDOSXq3dxUDYS3wzkl6t3cKTgsOw3sKkqTgsO w3sL2FQAYgAA
AAAjVqjYUVVRER7FVV2kP3fMHPRe2gqfJpts95CpltgS3zBz0XtoN8wc9F7a FQTYS3zBz0Xt
oN8wc9F7aFQNhLfMHPRe2g3zBz0XtoVA2Et8wc9F7aDfMHPRe2hUDYS3zBz0 XtoN8wc9F7aF
QNhLfMHPRe2g3zBz0XtoVA2Et8wc9F7aDfMHPRe2hUDYSpOCw7DewqSpOCw7 DewqJ6gACAAA
BGpc1joHPcjWo/Sqrb+ipYlN5SDbX3XFjqG+YOei9tBvmDnovbQqBsJb5g56 L20G+YOei9tC
oGwlvmDnovbQb5g56L20KgbCW+YOei9tBvmDnovbQqBsJb5g56L20G+YOei9 tCoGwlvmDnov
bQb5g56L20KgbCW+YOei9tBvmDnovbQqBsMaeeJ7WtZKxzlezQjkVfpIZJKp 8mm2z3kKlnoA
AMQAAAAAY6yMjqn5x7W3Y22Utr6XHPfMHPRe2gbwqTYb2uKmU4Et8wc9F7aD fMHPRe2hUE2E
t8wc9F7aDfMHPRe2hUDYS3zBz0XtoN8wc9F7aFQNhLfMHPRe2g3zBz0XtoVA 2Et8wc9F7aDf
MHPRe2hUDYS3zBz0XtoN8wc9F7aFQNhLfMHPRe2g3zBz0XtoVA2Et8wc9F7a DfMHPRe2hUDY
S3zBz0XtoN8wc9F7aFQNhCF7JKmVY3NcmQ1Lot+Nxck3hUmw3tcVFXUAAQAA AAAEqTgsOw3s
KkqTgsOw3sKlnqIRRtmjbJK1H5SXRHaUROLQct7QczF7CCk4LDsN7CpZmYkS 3tBzMXsIafmr
cVmxWsgpaqOOOFU8pluVbqvI5OQ3KaZpPz7i3pZ/+RMyOeVjvn9P7EnxmVuc rMQXdRS0dfOy
Vi5L/Ey0RbqqWVFct9RQjgv+3dH/AMJnvqMyNrb2g5mL2EITxxRyxpmIchUV XLkJdE0J/PoM
w4qy8rX31NVLem3cWKp7jFzcbpXxNhhRyLoVWIqIiI1f5nN8MUUD3vhhc5rV XQxEufsdMsV1
Y9Mq65KqmhG2RLfXqQ5SxsWJzqhWIqNVHSWtZNPGuoymr1GPJGyJyNdFA5Xa lSO1tKJ69f8A
ALGxsiRLFAr1tZ2b0JdHcX9nl4yLq+geqLJidErk+jkyNRNaLp8b6kC19Ars 4uJ0WcS1lSRt
tF+LK/6y8Y5vVF80zJflMpmZDrOe5mjUi6vXyn62Fj40ekdMxqXu5Y7ounXx WTj9ZBMSom3V
uJ0WW5buvI2y6ETVf6uU47+oLtVMToVtps57VRHKqqqp431jm9RkJHZsb83H HlKiZDG2cl/r
+rXq4jKgcr40V2tFVq+pbfyOuZiNE2TLdidA5y61y23tyJ42g50+K4ekaotf SJ47l0zN/SX6
yVTmFdiSpOCw7Dewx/lbDvP6Trm95OlxXD200KLX0iKjERUWZvJ6THsOxBhf K2Hef0nXN7x8
rYd5/Sdc3vIM0GF8rYd5/Sdc3vHyth3n9J1ze8DNBhfK2Hef0nXN7x8rYd5/ Sdc3vAyKnyab
bPeQqddUYrh6xoiV9IvjtXRM39JPrKfK2Hef0nXN7y9hoau3TYtuqk+Un4pi NHQzKr6Wloql
9O1kS/QVzmKjnOVLKqqttNkSxjfln663Q/31V/eHV7mXKzcjhT2xukc2hiVG Ntdy5tNCXVEv
6VQysHrlxGh3w6B1O7OyxrG5yOVqskczSqaL+LxX9K6zQ9fxLiVF69XavVU0 U1zTiKsY642i
Y7RO+PbOXjuq4lrqrldcXaojONqpjz7RPoyvyz9dbof76q/vDutye6XFcCx3 Do5cRra/Dayq
ipJYayZ0zo1kejGPY913JZzm3RVVFRV49J5SLF85Q0UqQflNTMlOsGX9CRFV JUyrWXIRki31
OyNGtDs2se/EMIVjXOSPFKGR6ol8ljaqJznLyIiIqqvEiH20Gu4lGvs2dVdq mmquKZiqrP8A
y5ZneZ6b4npmJxO0uRw7X66nWWqa7lU5qiMTMz3xPd9GnzzXbpsW3VSfKT8U xGjoZlV9LS0V
S+nayJfoK5zFRznKllVVW2myJY3z8rYd5/Sdc3vPmncy5WbkcKe2N0jm0MSo xtruXNpoS6ol
/SqHece1N7TaWKrFXLVNURmNp6T37dOrbPF2rvaezbizVNOZnpt9rtPyz9db of76q/vB+Wfr
rdD/AH1V/eGLg9cuI0O+HQOp3Z2WNY3ORytVkjmaVTRfxeK/pXWQfi+TgVfi OYvvXfH4vL+l
mnPbrtovkcmi/Gav8d4z8JNr4evmiqKJ+XPzpzERnmx2nfp6tG+O8Q5pp+Fq zE4+dPX3+j1e
5PdLiuBY7h0cuI1tfhtZVRUksNZM6Z0ayPRjHse67ks5zboqqioq8ek3qfOT WPfiGEKxrnJH
ilDI9US+SxtVE5zl5EREVVXiRD6A+VsO8/pOub3m18C1N3VaGLt6rNXNVGZ6 4iKZjPn1nd6B
4T1N7UaOqq9VMzFUxGfZDNBhfK2Hef0nXN7x8rYd5/Sdc3vO2bOzQYXyth3n 9J1ze8fK2Hef
0nXN7wMik4LDsN7Cp11LiuHtpoUWvpEVGIioszeT0lPlbDvP6Trm95Z6jNBh fK2Hef0nXN7x
8rYd5/Sdc3vIM0GF8rYd5/Sdc3vHyth3n9J1ze8DNJTeUg2191xj/K2Hef0n XN7yc2K4eskK
pX0i2fdfxzdHir9ZYHYnzzXbpsW3VSfKT8UxGjoZlV9LS0VS+nayJfoK5zFR znKllVVW2myJ
Y3z8rYd5/Sdc3vPmbc9K+HcfhMkcElQ9KKC0catRzvEbqylRPr0qdNxzUX9P pqZ09XLVNURn
OOsT37dI329rUfFuqv2LNumzVNPNPacfa7f8s/XW6H++qv7wfln663Q/31V/ eEMJq/lDC6Os
yM3viFk2Re+TlNRbX49Zj4XizMQq6yBkTmLTu0Kq3yky3x3+pcqJ+jkyV1qq Jqk6/jNMXJm/
c/R7VfLnbfHn5+TRZ13EI5v0tfyevyp9nm9TuT3S4rgWO4dHLiNbX4bWVUVJ LDWTOmdGsj0Y
x7Huu5LOc26KqoqKvHpN6nzk1j34hhCsa5yR4pQyPVEvksbVROc5eRERFVV4 kQ+gPlbDvP6T
rm95tvAtTd1Whi7eqzVzVRmeuIimYz59Z3eg+E9Te1GjqqvVTMxVMRn2Q0NX bpsW3VSfKT8U
xGjoZlV9LS0VS+nayJfoK5zFRznKllVVW2myJYxvyz9dbof76q/vDq9zLlZu Rwp7Y3SObQxK
jG2u5c2mhLqiX9KoZWD1y4jQ74dA6ndnZY1jc5HK1WSOZpVNF/F4r+ldZrWv 4lxKi9ertXqq
aKa5pxFWMdcbRMdonfHtnLRNVxLXVXK64u1RGcbVTHn2ifRlfln663Q/31V/ eHdbk90uK4Fj
uHRy4jW1+G1lVFSSw1kzpnRrI9GMex7ruSznNuiqqKirx6TyNDiGI1kjnxUN IlI2okhV7qt2
XZkjmK7Jzdr+Kq2yvWdpb/5jgv8AW+H/AOriPvodbxKniFnTaq9NUVVRTMTX zdZxPecTHvcj
h+v11GttUV3apzVETHNnvie8vo8AG6PWgAASqfJpts95CpKp8mm2z3kKl7AA CAAAAAAk3hUm
w3tcVJN4VJsN7XFSyJLeWRzUcrWt0LbWq6+4b3Zyy9Y7vEPlJ9tPdaVLM46C W92csvWO7zwO
7PHMSw3HWUeHPe7OImS10uSieLdVuqKpsM1fu6/22o/Qv+WpOaRjfL+6b9Fn 2r/+ZOXdPugg
fClSuQyV6R5TKhHKiqirqyE5DIOsx36NF+8t7HDM+Y27RxpJRwPe6VXOja5V zjtap6TnNG2N
mUmcVboiIsrk1rbl+sYd+b6b/hN7EKTxrJHkotvGauu2pUUsTOdxjORUekat dnFVNGffayov
H/ZXiKxRtflI7OI5q2VElcqakXl+s/X0zVVlsrQ66qr1vaypr18ZzSFiWtla Fv8ASXT6dOn1
lmqBi3a2Nsj2yJG5LttM5V1KulPQnKcnJkKiSNejl+jkzuVNaJp6UOS073ws idko1jVRHIt1
XxVTV6+U5SRSSuRzkY1W6kRyrfSi8mjV/EyzCJqlnZtWvzi2siTutpvx/wBl eILZEsrJbo9G
OtM6yXt9f18hRYpHSJKqMR6Ws3KWy2R3Hb/rcnEfj45Va6yMynPR6plLotbR q06iZEo1R8qt
Y5EVHK2yzqrtC8i+gy4XK5HI76TFyVXl4/5nBzZX2a9GI3KR10cvEt7Wt6v/ AFY/YfKT7ae6
0k7qqADASbwqTYb2uKkm8Kk2G9ripZAAEAAAAABKk4LDsN7CpKk4LDsN7CpZ 6iVJwWHYb2FS
VJwWHYb2FRPUdPurxObCMJWqp0YrkdZctquS1lVdF05OU0hUVUFVUPqXuVJJ NKqyVrL8l0Sd
OU3lulwt2MYatK2RrLuRVVyKqKllS2j0nj2+DqRrURMQVETQiZb+8g8RhtAz EIpJIp5Gox+Q
t5ZF02RdbZlTjTjOzwqlXCsVingqYFqks5GyZb1VEXkdIuj0HraPcPUUbHti rIly3ZblejnK
q2RNaryIhR24ud07Z1npVmamSj82t0Tk1geqwOqlrcKp6ifIzr0VXZCWTWqG cYeD0bqDDYKZ
70e6NFRXIlkXSq/zMwAYWN/mXEP3eT3VM0wsb/MuIfu8nuqBmgAAAABKm8mu 2/3lKkqbya7b
/eUvYVJUnBYdhvYVJUnBYdhvYOwqACAAAAAAlU+TTbZ7yFHta9jmPajmuSyo qXRU5CdT5NNt
nvIVL2Hy5uZV6bkcKWFrXSJQxZLXOyUVc2lkVbLZPrspwwinxSlopYpYqJki 1LpkVsz5EVkk
yvei+I2yo1yomu667GTIxm5FrMFx6WOhno25mN9Q7Nsnjboa9jlsjkVETVqW 6LqOHzjwT9c4
b9qZ3mhazT6ym/fopsTVTVXzZ5ap6TOMY2mJiZ8+vseL6izft3blE25+dnpP aZcKbCXxY3JV
OlatIjnyxQ20MkejEcqJqRUyXrdNKrM/VpV3af8ASOC/1vh/+riOu+ceCfrn DftTO87bcrD8
6N0OFQYK9tVBTVtPV1NTEuVFEyKRsllemjKcrEaia9N9SKpnw+zrrnENPd1F uqIomneaZjEU
zmc7e2fOZfbh9rUXdbZmqmdqqe3aJy+iXta9jmPajmuSyoqXRU5D5d3Mq9Ny OFLC1rpEoYsl
rnZKKubSyKtlsn12U+oz5ikYzci1mC49LHQz0bczG+odm2Txt0Nexy2RyKiJ q1LdF1He+ILF
y/pYptUTVMVROIiZ2xPlvhuHjKzcuWbU0U5xM5Y2EU+KUtFLFLFRMkWpdMit mfIiskmV70Xx
G2VGuVE13XXYwqncpSz4PiUUlFh78RqXVLo6h0SKqLI96sVXWvdEc30W0HZ/ OPBP1zhv2pne
PnHgn65w37UzvNfpvcVt3artmzVRNVUVTimreY+3Gczjpu0eK9VTVNVFExMz naJdj/0jgv8A
W+H/AOriPo8+ddysPzo3Q4VBgr21UFNW09XU1MS5UUTIpGyWV6aMpysRqJr0 31Iqn0UbJ4fs
3NPoIt3aZpq56pxO04mKY+6W/wDg+1Xa0VXPGM1TP2QAA7htYAAJUnBYdhvY VJUnBYdhvYVL
PUAAQAAAJTeUg2191xUlN5SDbX3XFgUe1r2OY9qOa5LKipdFTkPlrc86du4/ CVpY45Zt5QZL
JJFY1fEbe7kRypo+pT6mPmKRjNyLWYLj0sdDPRtzMb6h2bZPG3Q17HLZHIqI mrUt0XUdHx+z
cvaWmLVHPMVROIzO2J8t8expvjG1Xcs2qqKc4mc/5DEw2mxii3P0dJGzD21V NEkN3SPexyNi
VGu+i1UVXo26afFvpuMPwOTDqnD3wVs9RDTROpsipyPEhVqfRyGIquymR/SV dGVxmR848E/X
OG/amd4+ceCfrnDftTO81uuridU18tiY585xRO+cx1mJmOs4xPfHRo0zqZzi jGc5288/i7H/
AKRwX+t8P/1cR9HPa17HMe1HNcllRUuipyHztuVh+dG6HCoMFe2qgpq2nq6m piXKiiZFI2Sy
vTRlOViNRNem+pFU+ijZ/D9m5p9BFu7TNNXPVOJ2nExTH3S9A8H2q7Wiq54x mqZ+yHy5uZV6
bkcKWFrXSJQxZLXOyUVc2lkVbLZPrspwwinxSlopYpYqJki1LpkVsz5EVkky vei+I2yo1yom
u667GTIxm5FrMFx6WOhno25mN9Q7Nsnjboa9jlsjkVETVqW6LqOHzjwT9c4b 9qZ3mt6zT6ym
/fopsTVTVXzZ5ap6TOMY2mJiZ8+vsaFqLN+3duUTbn52ek9pl1lDgb6eudJL g+DTOWrknSrd
J+ORHSuei2zX0moqJ9Li1oeoi4dhf9aYf/rYDqvnHgn65w37UzvO73Hsg3TY 5RU+GVDJ2Q1V
PUvnju+JuamZLkq9LplKkbrJe+heQ5mgnXXuJ2NRqbVURTVEzOKsdcz1mYj2 RiPRz+FRfu8Q
tVV0TtPr976FABuD1kAAEqnyabbPeQqSqfJpts95CpewAAgAAAAAJN4VJsN7 XFSTeFSbDe1x
UsiUPlJ9tPdaVJQ+Un2091pUSJVcuYpZpkblZtjn2va9kuaY3UYouM4tvpjZ aeSJclFgSR1l
tZUvmlRTc1dG6aiqImWy3xual+VUNWy+DzEJJ5ZFbBeRyuW+Q7T6Vbcg85T7 8qJs1HX1aSZK
us9ci6IqIv0oU5UMlcMrnyROmqHzJG7La18yWvZeSJF4z0GHbhMRoqvPsZAr shWWRzWpZVRe
JqchmVm5DEKyNsc8ESta5Hpae2lNXEB6rcpikmIUr45YGxOp2sZ4r8rK0ehO Q7w6DcphlVhz
arfjWNWRW5KNdlar9534AAAAAAAAAlD5SfbT3WlSUPlJ9tPdaWO4qACCTeFS bDe1xUk3hUmw
3tcVLIAAgAAAAAJUnBYdhvYVJUnBYdhvYVLPUSpOCw7DewqSpOCw7DewqJ6g ACAAAAAAGFjf
5lxD93k91TNMLG/zLiH7vJ7qgZoAAAAASpvJrtv95SpKm8mu2/3lL2FSVJwW HYb2FSVJwWHY
b2DsKgAgAAAAAJVPkb/oua5fQiopVNKaASWCPiy2/U16onQilFQS3uzll6x3 eN7s5Zesd3jY
VBLe7OWXrHd43uzll6x3eNhUEt7s5Zesd3je7OWXrHd42FQS3uzll6x3eN7s 5Zesd3jYVBLe
7OWXrHd43uzll6x3eNhUEt7s5Zesd3je7OWXrHd42FT8c5GtVztCIlye92cs vWO7z9bAxFRf
GW2rKcru1RsFM1W08TXaFRqIvQUAJO4AAAAABKfQ6Jy6mv0+tFT+ZUKiKioq XRSwAJb3ZxLI
n1JI5P5je7OWXrHd42FQS3uzll6x3eN7s5Zesd3jYVBLe7OWXrHd43uzll6x 3eNhUEt7s5Ze
sd3je7OWXrHd42FTCxDheG/vC/5Uhkb3Zyy9Y7vMOvgYlVh2mTTUL/vHc1J9 Y2HYglvdnLL1
ju8b3Zyy9Y7vGwqCW92csvWO7xvdnLL1ju8bBU6WsamtXtt6lRf5FTgyJrFu iKq8qqqr/E5i
QABAAAAAASbwqTYb2uKkm8Kk2G9ripZEofKT7ae60qSh8pPtp7rSokAAQAAA AAAAAAAAAAAl
D5SfbT3WlSUPlJ9tPdaWO4qACCTeFSbDe1xUk3hUmw3tcVLIAAgAAAAAJUnB YdhvYVJUnBYd
hvYVLPUYtLG9aaJUmkTxE0IjdGj0Fc0/n5ehvcKTgsOw3sOg3W7s8K3Luiir d8VFZM3LjpKW
PLlVurKXSiNbfRdyohaqsTMy+dy7Rapmu5OIjzd/mn8/L0N7hmn8/L0N7jXf 4WqP9mt0P+E+
/H4WqP8AZrdD/hPvz5fGdP8Atrf16P7nC/K+g/b0/Wj8WxM0/n5ehvcM0/n5 ehvceEw/wq4N
PVRw4hQYrhTHqjUnrI41iRV1ZTo5H5KfWtkNgGcV01RmiYmPOJiY98ZhyrGp s6iOazXFUek5
SzT+fl6G9wzT+fl6G9x0G63dnhW5d0UVbviorJm5cdJSx5cqt1ZS6URrb6Lu VEPNfhao/wBm
t0P+E+/JVdt0bXK6af4qqaf5zD5XuIaWxVyXbtNM+sxDYmafz8vQ3uMPGo3p g1eqzSL+TyaF
RunxV+o8P+Fqj/ZrdD/hPvw/wn4XiFPPRT4Zi+HyVEboo31MUbmK9yKjUVYn vtdVRNNkJF+z
VOKblEz5RVTM+6JmWFHFNFXVFNN6mZn96GxM0/n5ehvcM0/n5ehvcVBnlz0s 0/n5ehvcM0/n
5ehvcVAyJZp/Py9De4/KRLQqiqq+O/SvH4yliVN5Ndt/vKXOwqSpOCw7Dewq SpOCw7DewnYV
ABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMLEOF4b+8 L/lSGaYWIcLw
394X/KkAzQAAAAAAAAAAAAAAASbwqTYb2uKkm8Kk2G9ripZGOxJFmnzb2NTL T6TVX+in1oc8
mfnIurX4hD5SfbT3WksVxGkwnD567EZ2U9JA3KkkfqRP5rxIiaVUszOcJMxE ZlXJn5yLq1+I
ZM/ORdWvxGvX+FrDspd74Bj88fFIkcEaO9UkrXJ60Q4/hao/2a3Q/wCE+/Pl 8YsRtN2iPbXR
E+6ZcD8raGOt6n60fi2Jkz85F1a/EMmfnIurX4jXjPC3h6OTP4Buggj43rHB IiepkznL6kU9
7hOJUeL4dBX4bOyopJm5UcjNS8XqVFuioulFSxlTcor3oqiqPSYmPfGX3saz T6mZizXFWPKY
lbJn5yLq1+IZM/ORdWvxGFuhxzD9z2GvrsVnzUCKjGojVc6Ry6mtamlzl5EP EL4WqFV/F7nN
0L28Tsmmbf1OnRU9aCq5RR/qVU0/xTFP85hL+t0+nnlvXIpn1mIbEyZ+ci6t fiGTPzkXVr8R
rv8AC1R/s1uh/wAJ9+frPC3h6OTP4Buggj43rHBIiepkznL6kUx+MWJ6XaJ9 ldE/Zl8fytoZ
6XqfrR+LYeTPzkXVr8QyZ+ci6tfiI4TiVHi+HQV+GzsqKSZuVHIzUvF6lRbo qLpRUsZZ9My5
8TExmEsmfnIurX4hkz85F1a/EVAyqWTPzkXVr8R+U2Ujp8tUV2XpVEt/RQsS h8pPtp7rS52k
VABiJN4VJsN7XFSTeFSbDe1xUsgACAAAAAAlScFh2G9hUlScFh2G9hUs9RKk 4LDsN7DRG69y
y+EXdS96qro54IG34mJSwvRPakevrN70nBYdhvYaH3V/8oO6399h/wBHTnU8 f/2F36P6oax4
u/6dPth0Py1he9d8/KVFvbLzedz7MjLtfJve17abGUlTAsEc6TRrDJk5EmUm S7KVEbZdS3VU
ty3Q8hQVlHvWOugxaippGVNdE2adM5CrX1GWqKqOaiOVEY5PG0tutl1oqnrj EFPSpQyTRIyo
km3jkRqqyLJEyVucciZMjVmfoVy3yVuqaXa9c4BbprxM1U0xVVFU1bYiObG8 xTG/LEZz1qiJ
jOM+f1aGmJxvERM5mfTPniN8efWce32U0bJonxStR0b2q1zV1Ki60N2eDeaS o8He5aaZ6vlk
wqle9yrdXKsLVVTROC1b6zDKeedrEqLZE7G3yWytXJe1PqRyOTWurWus3V4O aeWbwe7mJY6y
enY/C6VzYY0YrI0WJqo1uU1XWTUl1VeVVOy8MWqrNGptV9aaqY+n5cT78fY2 vwXTNFV+mesc
v3tXbtJmp4Q91EtRI1uRU01Mxz1siN3tC5rU9L5HWTlcYEsjIYnyzPbHGxqu c9y2RqJrVV4k
MTwmLvXdNupdV1KObHjFA580lmWbm6NbrayJZOP6jqsWxKDEG0UOGObiLXVC TSNpJWOcjYla
/Q5XI26PWFFRVvZy25U4XFuGVanW/C78sziZ7RFNFE9Z2ziZ6z2dBxjTzc19 yrtNUxPpiIl3
slTBFPDBJNGyaa+bjc5Ec+yXXJTWtk12L0cjH1aNY9rnRyNa9EW6tXQtl5Fs qL60PD0FMtVV
4VRLlUtXh1PURx5SI50SsfTrHlK1bKro1ZlZK6Ue5LpfR3O4+tWrmxaqzebl StRJI75WbkbB
C17b8dnIqXTQtrocO9wijS0/DxXmKIzP/k5aZjziqmMxiZ6dcTGeHTpqbFUX c5inEz9bEY9J
jf8AyH0P4N5pKjwd7lppnq+WTCqV73Kt1cqwtVVPRHmfBf8A8mm5L+qKT/JY emPRNVEReriP
Of5vZaekAAPgyCVN5Ndt/vKVJU3k123+8pewqSpOCw7DewqSpOCw7DewdhUA EAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwsQ4Xhv7wv+VIZpjV1PJOt O6GVkckMmcRX
sV6L4rm2sip+lygZIMLN4j51SfZnfeDN4j51SfZnfeAZoMLN4j51SfZnfeDN 4j51SfZnfeAZ
oMLN4j51SfZnfeDN4j51SfZnfeAZoMLN4j51SfZnfeDN4j51SfZnfeAZoMLN 4j51SfZnfeDN
4j51SfZnfeAZoMLN4j51SfZnfeDN4j51SfZnfeAZDeFSbDe1xU65seIb5k/K qS+Q3/mzuV3/
AGhTN4j51SfZnfeFkZEPlJ9tPdaa88OLlXBsAhuubmxZqPb+kjaeeRP/AKmN X1Ht4Y8Qzk9q
qk+np/Jnfop/2hq3/wCIarlo9z2Ftr3LM1Z6iWN1Iq072OZST6cpcvic62hL LZdNrLl8FN6m
u3T1mmqI9J5ZxP0dXC4jRz6S7TE4zTP8nlgefrKTAsOxCOHeCU1NPTSulZAq MZLkyQo1rmNb
d6qr7InHlObZcqxm4PT0VC2adKFcLhmcyNtNnY2tRb2RytamSj3K62hVuiM4 9CebXeF2abEX
qLueb5uacZ3xMdZnMb9IntnGYeRVaK1FHPF2N+m07748v8+l2ZsTwHKqYRuh iuubjxdyMbxN
yqaB629LnOX1mjKaCjjkWt+SIoo1xN7N+x1LVqletUrOaTxVcuSqZX0FVNPH u7wOpK+g3Q7w
eyFqYpaRJmLKrnb1p9KWVtktkpbTpRVvpsmz8E4dTodTdimvn+TMeyYro8pm O/nmM9MS2nwx
padPrquWuKvkz59pp/zz9GH4anK7dFuXhVVzaQVs+TxZbVp2ovRI9PWeMO/8 PcslLUUMlcrp
HMwrEXxSUj1gc1EWnyk05en6FnIuiy6F0W8BWUmBYdiEcO8EpqaemldKyBUY yXJkhRrXMa27
1VX2ROPKc2y5Vj48c4dTqtRbmquYmaZiIinOeXNU947TtHeXw8SaWm9r5mqv EzEYjEz0jMvQ
A6zB6eioWzTpQrhcMzmRtps7G1qLeyOVrUyUe5XW0Kt0RnHoTA3P0dMtdLVx YLRtbvupvWOn
R1RfOyIq2zKaL3S2Vobymvzwqzy3a4vRy0YxOI3mYmcdcdv+M1T5Q174jbxV MXYxHpPl/nTL
c3gOVUwjdDFdc3Hi7kY3iblU0D1t6XOcvrNkGt/Ahb5P3TZKKifK/Gt/+aUx sg9Cs/6Fr+Cj
+iHrPCv9lZ3z8mn+QADN2ASh8pPtp7rSpKHyk+2nutLHcVABBJvCpNhva4qS bwqTYb2uKlkA
AQAAAAAEqTgsOw3sKkqTgsOw3sKlnqJUnBYdhvYaH3XIrPCJuqa9LK+oglb9 bVpYWovSxyeo
3xScFh2G9h53dduKwzdPNDUVMlVR10TchtXSPa2TIvfJVHI5rkut9KLbTa11 OJxHSzrNPXp4
nE1d+20xO/u/+un45w+viOkmxbnE5id/RpoGw/wS0f7S7of8J9wPwS0f7S7o f8J9war+aOo/
bUf+/wDY0n8zdd+tT75/ta6ke2KN8kio1jUVzlXiRDdfg1jfD4OdyscrVbIz CqRrmrrRUhbd
Dz9H4J8IjqY34hieL4nA1brTVT4WxP2kjjYrk+pVsvGimw0SyWTQh3/B+GVc Mt3LddUVTVMT
tnG2cdYie852bR4d4Le4XFyb0xM1Y6emfZ5tBbrkVnhE3VNellfUQSt+tq0s LUXpY5PUYBuX
dduKwzdPNDUVMlVR10TchtXSPa2TIvfJVHI5rkut9KLbTa11PO/glo/2l3Q/ 4T7g6/ifh67r
tTVqLdymmJxtVzZ2iI7Uz5ejp+KeFdVqtXXftVU4qnO8z+EteHGR7Yo3ySKj WNRXOVeJENi/
glo/2l3Q/wCE+4LUfgnwiOpjfiGJ4vicDVutNVPhbE/aSONiuT6lWy8aKcGn wjeiYmu9Rjvj
mz9GaYj3zDg0+DdbmOaqnHtn8HoPBrG+Hwc7lY5Wq2RmFUjXNXWipC26Howi WSyaEBu12ubl
c1z3nL0uIxGAAGChKm8mu2/3lKkqbya7b/eUvYVJUnBYdhvYVJUnBYdhvYOw qACAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJN 4VJsN7XFSTeF
SbDe1xUsiUPlJ9tPdaau8O2ibci7+i2vluvJenkRP4qies2jD5SfbT3WnRbr MCo90bosOxBH
pE+CR7ZI1s+J7XxK17V4lRe5boY3aeeiu3+tTNP1qZj73F11idRprlmnrVEx 74aGjwXC4oJo
I8NomQzWzkbYGI19lumUlrLZdVzlS4Th1I17aWgpIWvc1zkjha1HK1btVbJr RdKch79fBXjL
VVI91FCrE1LJhLldb61SdEVfQiD8FmN/tPhv9zv/APMmn1cD4nVExVfic7z8 qreYxienpHuh
5xPhnis5if6ngIsJw6KsWrioKRlWrlcszYWo+63uuVa91uvSbQ8B35s3SrxL i+hf+60yfyOu
TwV4yq2funoUbxrHhLkd6lWdU6UU2LuXwGj3N4RHh+Ho9Y2uV75JFRXyvct3 PcqWuq9CaESy
IiHbcI4dqdHdru6m5FczTyxvM4jMT3iPLp6u+8PcF1mi1M3tT05cRvnvE/c1 14adG6fcw5dS
0lc2/wBeXSrboReg19HguFxQTQR4bRMhmtnI2wMRr7LdMpLWWy6rm/N2e5ek 3U4dHBUSSU9T
A/O01TEiK+J9lTUuhUVFsqLrTkWyp4T8FmN8W6fDrfXhD7/6gx4rw3Vau7Fz TXOWMRExmY3i
ZmJ2iemdvKXy49wPW6vVze03SYjvjo8BS4Th1I17aWgpIWvc1zkjha1HK1bt VbJrRdKchlxR
siarYmNY1XK5Ualkuqqqr6VVVX1ntPwWY3+0+G/3O/8A8yE8FeMqtn7p6FG8 ax4S5HepVnVO
lFOnueHNfdmZuXaZz5zVPp+r5Okq8LcUr+dET/3Ox8B35s3SrxLi+hf+60yf yNknVbl8Bo9z
eER4fh6PWNrle+SRUV8r3Ldz3KlrqvQmhEsiIh2pudunkt0W/wBWmmn6sRGf pw9J0NirT6a3
Zq60xEe6AAGTlBKHyk+2nutKkofKT7ae60sdxUAEEm8Kk2G9ripJvCpNhva4 qWQABAAAAAAS
pOCw7DewqQjdmWJG9r7N0IrWqt04tRy3wzkl6t3cZTEzII2SPRGjHM4kcqpb +CjKn5uLrF+E
b4ZyS9W7uG+GckvVu7hv5BlT83F1i/CMqfm4usX4RvhnJL1bu4b4ZyS9W7uG J8gyp+bi6xfh
GVPzcXWL8I3wzkl6t3cN8M5Jerd3DE+QZU/NxdYvwjKn5uLrF+Eb4ZyS9W7u G+GckvVu7hif
IMqfm4usX4RlT83F1i/CN8M5Jerd3DfDOSXq3dwxPkGVPzcXWL8Iyp+bi6xf hG+GckvVu7hv
hnJL1bu4YnyDKn5uLrF+EZU/NxdYvwjfDOSXq3dw3wzkl6t3cMT5BeddGTG3 68pV/hZDnGxG
MRqakOG+GckvVu7hvhnJL1bu4YnyFSVJwWHYb2BZspFSNr1dxXYrUTpOcbEj jYxNTURCdIHI
AEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAASbw
qTYb2uKkm8Kk2G9ripZEHuzUyq1Fdl6Vamv0mLLI/wCWaVczJwebRdv6Uf1m ZDplnVdaORPV
kov81MeX89Uv7vN70RZGRnX8xL0t7zrqzH6KiqHQVOdZKiIqtRl9foO2NVeE Oniqt2FJFURt
kjVFVWuS6L+LUmfQe4+dOG/pTdWoXdVhiJdXTW/4amtvkPC/MKb2EMHE8Noq R9FJS0sUUm+G
plMbZbWcM+g3bHULJG17IZVa5EVFu3Si+s5Z1/MS9Le84Yd+b6b/AITexClQ 3KiVLol1TXqX
Tq9er1liYH5nX8xL0t7xnX8xL0t7yCokaOtG2N0ateuQt0tdUVeLTa/FyH4u X9FyLadUW1vr
0ovIuTboUy5UZGdfzEvS3vGdfzEvS3vOEdo5KhWRq5VkS+TZF+ii8f8A60k8 lubzmSmcz1su
2m2XbX6NBMQq+dfzEvS3vGdfzEvS3vMSREZRxSMRGyOYqucmhV8RV0r6dJSo YyORjY2ta12h
yNSyL4zU09K9JeWEXWV9tFPJf0t7zhE97Ecr4ZMpy5SqmT3kqiNrWVLWpktS JHIjdCX8bkOd
WxqskejWK5qLd6r4zNHF28QxHQZLHo9t2/8AsfpJmiqlTiyWr69PcVMJVJvC pNhva4qSbwqT
Yb2uKiQABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAASbwqTYb2uKkm8Kk2G9rip ZEofKT7ae60x
5fz1S/u83vRGRD5SfbT3WmPL+eqX93m96ISM01X4QZczutpp83LJGxPGzUav VLsVE0IbLxT8
2Vn/AAX+6poSpzi1c6OjREa9Ub+Jb9Hi/wB07tIO9+WYOYrvskncYeIVra19 IyGCrRWzo9yv
p3sRERF03VLGNg0STYjm5oGPhzTnLlQtsjrttpzbeJV5Ttqylghja6DDYJ3K 5EVqNa2yca6u
IDb2Gqi4fTWVF/FN7EMhURyKioiouhUU8luAjZG2vbGxrG3ZoaluJT1oHFsb GsVrWNRq60RN
CnJURVRVRFtpT6gAOLWMarla1rVdpVUS1xm2ZzLyG5f6VtPScgMji2NjXq5r Go5daomlT8bD
G1HI2NjUdoVEaiXOYLmRPMRZGTmmZN72yUtcJBEitVImXbq8VNBQDMiTeFSb De1xUk3hUmw3
tcVEiTeFSbDe1xUk3hUmw3tcVEgACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAk 3hUmw3tcVJN4
VJsN7XFSyJQ+Un2091pjy/nql/d5veiMiHyk+2nutMeX89Uv7vN70QkZkjGy Mcx6I5jkVFRe
NDrPm/hPmEHQdoCDq/m/hXmEHQPm/hXmEHQdoAMaioKWhR6UcDIUfZXZKazJ AAAAAAAAAAAA
CTeFSbDe1xUk3hUmw3tcVLIk3hUmw3tcVJN4VJsN7XFRIAAgAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAJN4VJsN7XFSTeFSbDe1xUsjHZNHHNOkkjGrlotnORP6KGNLUQ/LNKud jslPMl8pP0oz
Mh8pPtp7rTHl/PVL+7ze9EWcDI3zBz0XtoN8wc9F7aFQTYS3zBz0XtoN8wc9 F7aFQNhLfMHP
Re2g3zBz0XtoVA2Et8wc9F7aDfMHPRe2hUDYS3zBz0XtoN8wc9F7aFQNhLfM HPRe2g3zBz0X
toVA2Et8wc9F7aDfMHPRe2hUDYQheySplWNzXJkNS6LfjcXJN4VJsN7XFRV1 Em8Kk2G9ripJ
vCpNhva4qJAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABJvCpNhva4qSbwqTYb 2uKlkSh8pPtp
7rTxPhT3RVW52HD34dkJX1qyUcD3tykjVcl7n247MY9UTltfQe2h8pPtp7rT WHhzje+bcm5j
HOayumc9US6NTe8iXXkS6onrQwvVclq5cjrTTVMe2KZmPthwuI3arWku3KJx MUzMfRDwz5MR
lcr6jHsfkkXSrkxSeJF/sxva1PUhx/LP11uh/vqr+8MPEK2eGqgpaKCOaplY +VEllWNiMYrU
XSjXLe722S3Lp0aceHEa+rha+ioIHK1z45VmqVY1Hse5jkaqMcrku1dKo3Qr eO6JoVGs4xXb
i7F+qKZ6fpOWO/bmjHScbR02eTRrOIVUxX8NVif38efr6S7Vj8Qicj4Me3QR yJqcuKzyIn9l
73NX1obf8GG6Gr3Q4BULiWS6uoal1HNIxuSkqoxj2vtxKrZG3TVe9tBpvD6p lfQU1XCjmx1E
TZWo5LKiORFS/wBek2V4D/zdul/rf/wlMdz4e1mr1F+9Z1dc1TTTn5U5mJiq mnGZ37zs2Twp
rdVd1ldm9XMxyz1nO8TEd/a2SADZnoQAAAAAAAAAAJN4VJsN7XFSTeFSbDe1 xUsiTeFSbDe1
xUk3hUmw3tcVEgACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAk3hUmw3tcVJN4V JsN7XFSyJQ+U
n2091prvw4fm7c1/W/8A4SpNiQ+Un2091p4vwv4RWYnuco58OhfUTYdWNrFh jS75GZuSNyNT
jVGyKtuO1k0mF+marVyiOtVFUR7ZpmI+2XB4nRVc0d2imMzNMx9jTWI01Vv+ mraFkEskUUkK
xTSLGio9WLlZSNdpTNolrab60tp6p2FYmjGQuipKmkV0kz4Vq5IUWSSV73Nd Zi5xiI5Goi2R
fGVzV0W7Nd0ODNVUkxWhjemhWSTtY5q8itVUVF9I+ceCfrnDftTO80KxPEbF FNuNPMxH7tWe
+N4mMY5pxMYnf2PIqPjFERT8HO3pPr+MuyiV6xMWZrWyK1MprXZSIvGiLZLp 9dkNi+A/83bp
f63/APCUxqhN0WDOWzMVoZHLqbHO17l+pERbr6jc3gfwmsw3c9XVGIQPp5MS rXVbIZEVr2Mz
ccbcpF1KqRZVtaZWnToO08M6W/p796u9bmmJpxGYmN+amcRn0iWx+ELF2nW1 V1UzEcs9vWPw
e6ABtb0gAAAAAAAAAAEm8Kk2G9ripJvCpNhva4qWRJvCpNhva4qSbwqTYb2u KiQABAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAASbwqTYb2uKkm8Kk+tje1xUsiUWiaZF1qqOT0W RP5FTi+Nr7ZS
atSotlT1nDe7OWXrHd42kVBLe7OWXrHd43uzll6x3eNhUEt7s5Zesd3je7OW XrHd42FQS3uz
ll6x3eN7s5Zesd3jYVBLe7OWXrHd43uzll6x3eNhUEt7s5Zesd3je7OWXrHd 42FQS3uzll6x
3eN7s5Zesd3jYVBLe7OWXrHd43uzlk6x3eNgZpqZVTVktb69K/zQqfjWo1qI 1LIh+iRJvCpN
hva4qSbwqTYb2uKiQABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAcJGZSo5q5L0 1KccmfnIurX4
ioLkSyZ+ci6tfiGTPzkXVr8RUDIlkz85F1a/EMmfnIurX4ioGRLJn5yLq1+I ZM/ORdWvxFQM
iWTPzkXVr8QyZ+ci6tfiKgZEsmfnIurX4hkz85F1a/EVAyJZM/ORdWvxDJn5 yLq1+IqBkSyZ
+ci6tfiGTPzkXVr8RUDIlkz85F1a/EMmfnIurX4ioGRLJn5yLq1+IZM/OR9W veVAyOMbMi+m
7l0qq8ZyAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAP/2Q==
name="CollapsedAndMoved.jpg"
filename="CollapsedAndMoved.jpg"
CAEZAoUDASIAAhEBAxEB/8QAHAABAQACAwEBAAAAAAAAAAAAAAMEBwIFBgEI /8QAUxAAAQMC
AAkGCwMHCQcFAQAAAAECAwQRBQYSExQhMVPRQVFykZKTBxUiMzRUYXGxstIy dLMWF0JWgaHB
IzU2N1J1lJXTVWJkc4K0xCRDo6Txwv/EABsBAQEAAwEBAQAAAAAAAAAAAAAB AgYHBQME/8QA
MBEBAAEDAgQEBQMFAQAAAAAAAAECAxEEIQUSMUEGUWFxMoGRobETFCIVQlJT 8OH/2gAMAwEA
AhEDEQA/AP1SAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAHF72sRMpbX2e05EovKmmVdqKjU91kX+JYDSGc0vdu4DSGc0vdu4 FQNhgz4WoKeR
Y56lkUia8l92r1KT8e4M9dh7Rr7whMWbG2ngzs0ccieVmpFYq2YqprQ6vxRD 6xX/AOLk4jYb
V8e4L9eh7RmNqY3NRzc4rVS6Kkbtf7jSeEKNKJ9I+Goq1V06Mcj6h7kVFRdV lU3Vg7+b6b/l
N+CDYc9IZzS927gNIZzS927gcpkcsaoy99WxbKqX1p1EEdZzY0zrMpyIqOdd USyrdFuu21tv
UZRESK6Qzml7t3AaQzml7t3A43SGVGor1YrVcqLdy3RU2cvKTkVXMqJEc9Fj +xrVLeSi6096
8oimJFtIZzS927gNIZzS927gS15GdynZedyftLa2XbZs2E3ucyljma92ce1V VVcqp9hV2bNq
F5YRk6Qzml7t3AaQzmk7t3AhK3IqYImufkSZWUmWq7E1a76v2H2zUfI1zpXZ LrMa1y32IvxX
apOWFZTHte27VRUPpBiObNGj1RXOjXLVOVUtxUuYzGAABAAAAAAcHyMYqI5d a8iJdeo46Qzm
l7t3AU+tHuXar3J1Lb+BUu0CWkM5pe7dwMSTDODopHMlq42Patla5bKi+1Ds DT+MsOlY51cL
5qhkaNe+0UrmXXKRLrZRsNnePcGeuw9o+phzBiqiJWwqq6kRFNU+KIfWK/8A xcnEi2m0PDeD
mxT1LmSK7KbJM56LbJtqVRsN0aQzml7t3AaQzml7t3AqTqEcrW5KOVL+UjVs qp7F99ixgfNI
ZzS927gNIZzS927gRkRFpZVRZWujRdSvW7Vtfai6+fl2n2VrWSxtVZshWuWz XOVb+Tzay8sC
ukM5pe7dwGkM5pe7dwJOldHTPvlo9Guc1Vaq6tdrr7rbT5OixPY1jn2ftu5V /SanLs1Ko5YF
tIZzS927gNIZzS927gQyf/W5jKfm83l2y1ve9tt7nBiudBUvV78qJzms8pdS Imq/P+0vLCMr
SI+XLanO5jkT96FUW6XTYY9lZOxEzmtbK5zro7Uq6kvq6k2HODU6VqbGvsnU i/xMZiOyqgAx
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJQ+cn6 afK0qSh85P00
+VpY7ioBj4ScrcHVTmqrXJE9UVFsqLZSDWXhDqIaXHCklqJGRRIiornrZE/k 1Ou8eYL/ANoU
3eIdNW4SnmrqhZZlVzHqy75XKqomy6rM34FcETLV4QzEr3OZmnPuyVyKiorU 5JXc/sAthPCV
FVvoo6Wqhlk0hq5LHoq2s43Zg7+b6b/lN+CGoK2GnpYmvcyskRzkZaOWRy6+ X7Ww99iK+RY6
xj5ZZGsViNSSRXZKWXZdQPUPaj2q1yXRTgkLEaqWVb7VVyqvWUBcyOMcbWXy b3Xaqqqr1qcX
wse5VVF17URyoi+9OUoBmRPMsy8qy7b2yltf3bAkEaL9lVTZZVVUT3JsQoBm RLR4+XKVeRVe
qqnuW+o+aNHdVTLRV2qj3Iq+/XrLAc0iKpapiRL6o3bVvytLEnelR9B3xaVE gACAAAAAAlTe
bXpv+ZSpKm82vTf8ylSz1A07jLV09HjxVvqpo4WOY9EV7rIq5SGz8ZnvjwFV uje9j0RLOY5W
qnlJyoaNXCU073yySplucqreRb7fbOi/uQg7/wAeYL/2hTd4hjJX0lbh7BiU lRFMrVershyL
b7JDAjkrZqlkznqkbWKismem3Kve0jk5Oc7CeKngnp2KyscsrrI5kr1Rqpru vlagNzHF7GvS
zr86Ki2VP2nR4mSSSYJessskjkmciLI9XLaycqnfAcEiZm3Msqtdtuqqq/tO StRXo63lIioi
+/8A/D6BkFRHIqKiKi6lRSaQRoi3Ry35XOVVT3X2FAXMwJaPH/vX/tZa3917 3t7Bo8fMtuVE
ctl96cv7SoGZE2QsY5FRF1bEVyqie5OQ+Q+cn6afK0qSh85P00+Vpc5yKgAx AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJQ+cn6afK0qSh85P00 +VpY7ipwmjbN
DJE/7D2q1bcynMEHnVxOwSq3WOVV9sin1uKGCmLdjJmr7JFQ9CAOh/JTBv8A xHeqdhgrBVNg
tJUpUf8Ayiorstyu2GcAAAAAAAAAAAAk70qPoO+LSpJ3pUfQd8WlSz2AAEAA AAABKm82vTf8
ylSVN5tem/5lKlnqIV1LFW0slPOirG9LLZbLtvtOk/I7BG7l7xT0QIPPsxRw Uy+Q2Zt+aVUO
X5KYN/4jvVO+AGJgzB8GDadYKZHIxXK5cp11uplgAAAAAAAAACUPnJ+mnytK kofOT9NPlaWO
4qACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEo fOT9NPlaVMdk
Mck06yRscuWiXc1F/RQsdxkAlo0G5i7CDRoNzF2EGwqCWjQbmLsINGg3MXYQ bCoJaNBuYuwg
0aDcxdhBsKglo0G5i7CDRoNzF2EGwqCWjQbmLsINGg3MXYQbCoJaNBuYuwg0 aDcxdhBsKglo
0G5i7CDRoNzF2EGwO9Kj6Dvi0qY6RsjqmZtjW3Y6+Slr62mQJAAEAAAAABKm 82vTf8ylTGgg
ie1znxMc5Xv1q1FX7SlNGg3MXYQynGRUEtGg3MXYQaNBuYuwhNhUEtGg3MXY QaNBuYuwg2FQ
S0aDcxdhBo0G5i7CDYVBLRoNzF2EGjQbmLsINhUEtGg3MXYQaNBuYuwg2FQS 0aDcxdhBo0G5
i7CDYVJQ+cn6afK0aNBuYuwh8pmtY6drGo1qP1IiW/RQu2JFgAYgAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEofOT9NPlaVJQ+cn6afK0sdx0Hh AxlXFfAKVUEL
Z62ombTU0b1s1ZHIq3dbXZGtc5bbbWNTvxmxulcr340VUTl/Qp6OmaxPcj43 O63Kez8OH83Y
tf3v/wCJUmr6nCUNPhGkonsnWapcrWOSJ2Qlmudrf9m9mLqvfZqtrNd47rdZ prtu1pO9E1zt
E7RNUT1idoinP/Q0PxPxLWWNVTZ09cxHLnb55/DvPyixs/W3CX+Fo/8AQCYy Y2tW7ca65ypy
PpKRWr77Qov70OplqmRVlPTPRyOna9WPt5N228m/9pUVVROZrl5BSVTKp1Qk SOyYZViV6p5L
1REvkryoiqrV5la5OQ1/+tcUinn5tsZ+GnpnHl5xLWf61xLHN+rVj3+Tb/g0 xsqcYqeuo8KM
jTCeD1jzj4mq1kzHouQ9EVVyVVWPRUuutvtOw8IGMq4r4BSqghbPW1Ezaamj etmrI5FW7ra7
I1rnLbbax4nwL/0pxn+5UHz1R2Phw/m7Fr+9/wDxKk3i1eqq0n7irr+nNXzi jm+8uiafW3qu
Efupn+fJM59Yy8Y/GbG6VyvfjRVROX9Cno6ZrE9yPjc7rcp8/KLGz9bcJf4W j/0Do6nCUNPh
GkonsnWapcrWOSJ2Qlmudrf9m9mLqvfZqtrLVNUynmpIno5XVMqxMsmpFRjn 6/ZZi/uNJnjH
Foxmr4omqP407xGcz06bT9HPJ4zxPbN2reM/L/odsmMmNrVu3Guucqcj6SkV q++0KL+9DZPg
0xsqcYqeuo8KMjTCeD1jzj4mq1kzHouQ9EVVyVVWPRUuutvtNQMqmPr5qREd nIomSuW2pUer
0S3t8hf3HufAv/SnGf7lQfPVHscD4jrNTqKrWpnMcvNG0R1mnHSI6xL3vDfF NZf10Wb9c1RM
TO/tmG2gAbO6GAACTvSo+g74tKknelR9B3xaVLPYAAQAAAAAEqbza9N/zKeC 8JmONdgiup8D
YDWKKvlh0maplZlpDHlK1uS3YrnKjtupEaupT3tN5tem/wCZTTHhP/rLqP7o pPxqo/LxK9Xp
9Jev2/ipiMfOqKftnLx+Paq5pdBcu2pxVGPvMQ678o8bF1rjZhFF9lLR2/AH 5RY2frbhL/C0
f+gdGmEoVwv4uRk+fzTpcpYnNZZqsRbOXU5fLTZe2u9hhbCVPgunbNVq5GK5 U8lLrZGq5y+5
Gtc7/psl1si6ZTxXi9VdNuJnNUZiOWnePPp02+m7m0cX4pMxTF2rM9HfwY1Y 30srZY8YpKtW
rfM1lJBm3+xVjYxye9FNxYoYcjxkxcosKxROhz6OR8TluscjXKx7b8tnNcl+ Wxos2r4F/wCr
6l++1/8A3kx7nh/iGo1tNz9erPLjG0R1znpEeTafCfEtVq7ty3frmqIjO/ux PCZjjXYIrqfA
2A1iir5YdJmqZWZaQx5Stbkt2K5yo7bqRGrqU8J+UeNi61xswii+ylo7fgHY +E/+suo/uik/
GqjySYShXC/i5GT5/NOlylic1lmqxFs5dTl8tNl7a72PzcZ4jrrGsr0+lnam mJnaJ60xVMzm
J6Zx/wCy8/j3Fddb19yzYrmKacdPaJz93eflFjZ+tuEv8LR/6BzgxqxvpZWy x4xSVatW+ZrK
SDNv9irGxjk96KeewhhJaSqgpoqOpq5pmPkRsKsSzWK1FVVe5qbXtMqllfNA 2SSCSnet7xyK
1XN18uSqp7dSnlVcZ4pbt03qq4xV02ozO8x0xnGYmM4eN/WuJUxFc3pxPrH4 b5xQw5HjJi5R
YViidDn0cj4nLdY5GuVj235bOa5L8tjuDxHgX/q+pfvtf/3kx7c6BVGJmIdb 01c3LNFdXWYi
fsAAj7BKHzk/TT5WlSUPnJ+mnytLHcVABAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAd
Tg/B9FUQyyT0lPLItRNd74muVbSuTaqGT4pwd6hSdy3gMEeiSfeJ/wAV5mgY XinB3qFJ3LeA
8U4O9QpO5bwM0AYXinB3qFJ3LeA8U4O9QpO5bwM0AYXinB3qFJ3LeA8U4O9Q pO5bwM0AYXin
B3qFJ3LeA8U4O9QpO5bwM0AYXinB3qFJ3LeA8U4O9QpO5bwM0AYXinB3qFJ3 LeBOHBWD1knR
aCkWz7J/It1eSnsOxJQ+cn6afK0sdxrLw00FJTUeLMtPTQwyeNVbeNiNui0l Quu23YhqvDjq
rxhgx1Ng6pqo6eZZnvjfEiWWKRlkynot7uRea3LyG5PDbSTS4t4OrYmOfFg2 vbVT5KXVsaxS
xK73JnUVfYiqazjkZLG18T2vY5Lo5q3RU95qniO9Vp9TZvxRFUck075xmZrz 0mN8Vebm/i6q
q3rqbnLmOTG+cd8+Xm63CcVVUMWSKnyZqOpZLTrloqyssmXZF1IqtdKxEdy2 W6alS+BqV9Fg
unhnVrqjJy53NXU6Vy5T3J7Fcrl2Jt2IZoVURFVVsicpqlesrrsRp8RFMTE9 87RjrMztvM46
ZqlqU3pmj9PG3/f+z7zL13giijrMYsYYauNk8MVJROjZKmU1iufU5Soi7FXJ bfnsnMZnhpoK
Smo8WZaemhhk8aq28bEbdFpKhddtuxCfgRgkmr8YcKsbehnZTUsMvJI6JZnP VvOiZ1Evzoqc
inaeG2kmlxbwdWxMc+LBte2qnyUurY1iliV3uTOoq+xFU6TYoqjQfp4/lNqY x6zbmMfV1DTU
VzwLkxvyT+Jabw46q8YYMdTYOqaqOnmWZ743xIllikZZMp6Le7kXmty8gwtR z4SqqOOSCSOn
p63KWSOoVjnR6O9MpFaqOTy35NkW+q+xTuI5GSxtfE9r2OS6Oat0VPecjntH Ea7PJy0RFVFM
0xP8s753+LrGZxt36dHMo1FVGMRiYiY753+fXeXUYLwYtBhquljz7qeWnga1 807pVVzXS5SX
e5VRERzfZr95sXwRRR1mMWMMNXGyeGKkonRslTKaxXPqcpURdirktvz2TmPI qqIiqq2ROU9t
4EYJJq/GHCrG3oZ2U1LDLySOiWZz1bzomdRL86KnIp7vh+/d1etrv3d55IjO /bliN57zEfls
Xhau5d4lFc/4zn6Y3bJ8U4O9QpO5bwHinB3qFJ3LeBmg3F1BheKcHeoUnct4 DxTg71Ck7lvA
zQB1zsFYP0mNNApLKxy2zLedvsKeKcHeoUnct4GQ70qPoO+LSpZGF4pwd6hS dy3gPFODvUKT
uW8DNBBheKcHeoUnct4DxTg71Ck7lvAzQBheKcHeoUnct4DxTg71Ck7lvAzQ B11PgrB6xqq0
FIvluTXC3+0vsNPeEalgpPCTVNpomRMdgqkcrWJZL52pTZybEN203m16b/mU 074XoH0WPFNh
GoTIo62gjpGSrqaksckrshV5FVJbpz5K8x+Li9M16C/RTGZmI+1VMz9omXg+ JqZr4bcimM9P
zDwFU6q/KaklZg6pfTRQyQuma+LJu90SotlejrJkOvqvzIpKto8IYTrWudFT U0MLJWI2pj0m
ObLc5t8lHNsuQ1Na31TObyLfvwc/t8UrtRRNuimKqaeWJ3mcTnO0zNOZ5p7b dsS5XTqZpxyx
ETEYz9fOcb58vZhYGjqIcF08NYrnTwtzTpHOyllRq5KSKvO5ER1uS9jbfgkp KeuxFpp62CKp
nWrrWrJMxHuVG1czWpdddkREROZERDVtTPFTQulqJGRRN1q562RDcPgloamg xBwdFWwvhmlk
qKnNvSzmtlnklaipyLkvS6chsnhqqq7N+9VGOaY6dP7pmI9s/huHg2aqtRer xtMfLq154RqW
Ck8JNU2miZEx2CqRytYlkvnalNnJsQ8XVOqvympJWYOqX00UMkLpmviybvdE qLZXo6yZDr6r
8yKe/wDC9A+ix4psI1CZFHW0EdIyVdTUljkldkKvIqpLdOfJXmPNH4uP3qtN xKu9yRMVUREZ
zj4IpmYxMbxvHl6PK8RVVWuJ3app6xHXP+MQ83henqqrCFFUy4OrXxxMqYlZ R1aRvS8keQ5X
ZbLo5rFW11tdL7DusFtyKGJuZqYbX/k6mXOyJrXa7KdfrXVb3GUTqZ4qaF0t RIyKJutXPWyI
eNe113U2aNLFO1M7RE1d5mcYmqY/uxnGfXrnxK79Vyim1EbR06+c+vr7tpeC Skp67EWmnrYI
qmdautaskzEe5UbVzNal112RERE5kREPY+KcHeoUnct4HnfBLQ1NBiDg6Kth fDNLJUVObeln
NbLPJK1FTkXJel05D151GrrLtWkiYsUc3XEfhheKcHeoUnct4DxTg71Ck7lv AzQYv0MLxTg7
1Ck7lvAnDgrB6yTotBSLZ9k/kW6vJT2HYkofOT9NPlaWO4x/FODvUKTuW8B4 pwd6hSdy3gZo
IMLxTg71Ck7lvAeKcHeoUnct4GaAMLxTg71Ck7lvAeKcHeoUnct4GaAMHArW soXMY1GsbPM1
rUSyIiSusiGcYWCPRJPvE/4rzNAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMLBH okn3if8AFeZp
hYI9Ek+8T/ivM0AAAAAAAAAAAAAAEodUs6cuUi/syU4FTg+NHLdFc12y7SwO Z5y
Re: Border Item Rectilinear router with nested EditParts [message #207083 is a reply to message #207042] |
Thu, 25 September 2008 10:15  |
I debugged the routing process. It seems that the routing only works
with BorderItems, which i admit is in a way implied by the Name of the
Router. :-)
But what is exactly the difference between this BorderItems and normal
Items. I don't get it. How can i change my EditParts to
BorderItemEditParts and the Containers to BorderedBorderItemEditParts?
What is the Benefit and what is lost?
Do i have to use YXLayout to work with this items?
Totally confused, please Help!
> Thank you, Uwe
FUDForum. Page generated in 0.17716 seconds
