Home » Modeling » GMF (Graphical Modeling Framework) » Unexpected DND Error with GMF 2.1.1
Unexpected DND Error with GMF 2.1.1 [message #202119] Sun, 17 August 2008 23:03 Go to next message
I just upgraded from Eclipse 3.3 to 3.4, and GMF 2.0.1 to 2.1.1. I have
the structure of my model automatically generated into the Project
Explorer so they may be drag-dropped into an open window to
automatically create shortcuts.
However, I now get this exception when I try to copy across a node:
org.eclipse.swt.SWTException: Data does not have correct format for type
at org.eclipse.swt.dnd.DND.error(DND.java:277)
at org.eclipse.swt.dnd.DND.error(DND.java:228)
at org.eclipse.swt.dnd.FileTransfer.javaToNative(FileTransfer.j ava:68)
at org.eclipse.swt.dnd.DragSource.GetData(DragSource.java:469)
at org.eclipse.swt.dnd.DragSource.access$7(DragSource.java:435)
at ...
It was working fine in GMF 2.0.1/Eclipse 3.3 - has something changed? Is
there something additional that I now need to do to make this work?
Jevon
Re: Unexpected DND Error with GMF 2.1.1 [message #202140 is a reply to message #202119] Mon, 18 August 2008 06:23 Go to previous messageGo to next message
Hello Jevon,
Nothing was intentionally changed in this area.
Can you please check the same situation with Ecore diagram example? In case
you have this problem in both diagrams then this looks like a bug in GMF..
Otherwise I suggest totally regenerating .gmfgen model + code from changed
..gmfmap model.
Alex Shatalin
Re: Unexpected DND Error with GMF 2.1.1 [message #205148 is a reply to message #202140] Wed, 10 September 2008 18:59 Go to previous messageGo to next message
Sorry for the delay in replying. I still haven't had any luck getting
this to work.
I tried regenerating all of my diagram and edit code from .gmfgen with
no success.
I then created a new project with a really basic metamodel:
- Container; contains containers, elements; has attribute title
- Element; has attribute title
Went through the steps to create both Diagram Partitioning (to have
Containers containing Containers) and creating shortcuts (Containers
contain Elements), and I still get the same error:
One thing I noticed is that even before I enabled shortcuts (by setting
..gmfgen > Editor > Diagram > Contains Shortcuts To and Shortcuts
Provided For) is that I could still drag elements onto the Container,
and it would also get the same error.
GMF allows for the elements to be dragged (with a drag-drop mouse icon)
but once I let go of the mouse button it throws the unhandled loop
exception.
Any ideas? The full exception stack trace is provided below.
Jevon
at org.eclipse.swt.dnd.DragSource$4.method3(DragSource.java:258 )
at org.eclipse.swt.internal.ole.win32.COMObject.callback3(COMOb ject.java:92)
at org.eclipse.swt.internal.ole.win32.COM.VtblCall(Native Method)
at
org.eclipse.swt.internal.ole.win32.IDataObject.GetData(IData Object.java:25)
at org.eclipse.swt.dnd.FileTransfer.nativeToJava(FileTransfer.j ava:120)
at org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:442)
at org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:257 )
at
org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMOb ject.java:119)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:362)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:288)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :171)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Alex Shatalin wrote:
> Hello Jevon,
> case you have this problem in both diagrams then this looks like a bug
> in GMF.. Otherwise I suggest totally regenerating .gmfgen model + code
> from changed .gmfmap model.
> Alex Shatalin
Re: Unexpected DND Error with GMF 2.1.1 [message #205308 is a reply to message #205148] Thu, 11 September 2008 07:47 Go to previous messageGo to next message
Hello Jevon,
Can you reproduce this problem with Ecore diagram editor on latest GMF (2.1)?
Alex Shatalin
Re: Unexpected DND Error with GMF 2.1.1 [message #207835 is a reply to message #205308] Sun, 05 October 2008 22:00 Go to previous messageGo to next message
Hi Alex,
Yes, I can reproduce this error with the latest GMF 2.1.2. I have
submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=249718.
Jevon
> Hello Jevon,
> (2.1)?
> Alex Shatalin
Re: Unexpected DND Error with GMF 2.1.1 [message #208137 is a reply to message #202119] Thu, 09 October 2008 05:13 Go to previous messageGo to next message
Since I've upgraded in GMF 2.1, I have the same problem with drag and
drop object from model (into project explorer) to diagram.
My application can't work without this feature!
Thanks in advance
Hugues
Re: Unexpected DND Error with GMF 2.1.1 [message #208637 is a reply to message #208137] Wed, 15 October 2008 04:31 Go to previous message
I found a solution to authorize drag and drop between navigator and diagram
You have to Modify "inputChanged" method of
XXXDomainNavigatorContentProvider like this :
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
myViewer = viewer;
if (myViewer != null) {
Transfer[] transfers = new Transfer[] { LocalTransfer.getInstance() };
Control myControl = myViewer.getControl();
DragSource dragSource = (DragSource) myControl
.getData(DND.DRAG_SOURCE_KEY);
dragSource.setTransfer(transfers);
dragSource.addDragListener(new ViewerDragAdapter(myViewer));
DropTarget dropTarget = (DropTarget) myControl
.getData(DND.DROP_TARGET_KEY);
dropTarget.setTransfer(transfers);
dropTarget.addDropListener(new EditingDomainViewerDropAdapter(
myEditingDomain, myViewer));
I don't know if it's a proper solution but it's working for me
Hugues
Hugues Rérolle wrote:
> Thanks in advance
> Hugues
Previous Topic:Phatom node keep referencing a deleted element => save impossible !
Next Topic:XXXViewFactory.decorateView -> different behavior in GMF 2.1 vs. GMF 2.1.1
Current Time: Sun Jul 20 09:09:27 EDT 2025
Powered by FUDForum. Page generated in 0.04897 seconds
