Opening XML Schema file in my view [message #203218] |
Sat, 27 October 2007 15:14  |
Originally posted by: sursubra.cisco.com
I am Trying to open schema file with the extension .xsd in my View i call
following code in the view
String path = "C:" + File.separator + "mySchema.xsd";
Path location= new Path(path);
IFileStore fileStore = EFS.getLocalFileSystem().getStore((IPath)location);
IDE.openEditorOnFileStore(page, fileStore);
I expect this file to be open in the XML Schema editor But it open only the
XML Editor with ID
" org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part "
But the same file i added to my eclipse Project Explorer it opens with the
correct Editor. I am not sure what i am doing wrong or what should i do to
get the correct editor.
Suresh Subramanian
Re: Opening XML Schema file in my view [message #203252 is a reply to message #203227] |
Sat, 27 October 2007 17:04  |
Thanks Valentin, Is there a work around for this.
Suresh Subramanian
"Valentin" <valentinbaciu@hotmail.com> wrote in message
news:fg03su$g14$1@build.eclipse.org...
> Suresh, perhaps you're running into this
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=194935. At least the
> symptoms seem similar: the file opens in the XML editor instead of the XSD
> editor.
> Valentin
> "Suresh Subramanian" <sursubra@cisco.com> wrote in message
> news:fg02m0$96v$1@build.eclipse.org...
>> Hi,
>> the XML Editor with ID
>> the correct Editor. I am not sure what i am doing wrong or what should
>> i do to get the correct editor.
>> Thanks,
>> Suresh Subramanian
FUDForum. Page generated in 0.06686 seconds
