Assertion failed, Property View with a ComboBoxDescriptor [message #202353] |
Tue, 08 November 2005 17:50  |
I have a problem with the property view. I have modified the generic
property adapter from the redbook with a ComboboxPropertyDescripter (see
the code under the error trace).
Every time I click on the visibility entry the following error message
arises. What is wrong? I like to use the ComboboxPropertyDescriptor to
show all elements of my EMF Enumeration VisibilityKind.
!ENTRY org.eclipse.ui 4 0 2005-11-08 23:38:59.502
!MESSAGE Assertion failed:
!STACK 0
org.eclipse.jface.util.Assert$AssertionFailedException: Assertion failed:
at org.eclipse.jface.util.Assert.isTrue(Assert.java:180)
at org.eclipse.jface.util.Assert.isTrue(Assert.java:165)
at
org.eclipse.jface.viewers.ComboBoxCellEditor.doSetValue(Comb oBoxCellEditor.java:218)
at org.eclipse.jface.viewers.CellEditor.setValue(CellEditor.jav a:815)
at
org.eclipse.ui.views.properties.PropertySheetEntry.getEditor (PropertySheetEntry.java:380)
at
org.eclipse.ui.views.properties.PropertySheetViewer.activate CellEditor(PropertySheetViewer.java:154)
at
org.eclipse.ui.views.properties.PropertySheetViewer.handleSe lect(PropertySheetViewer.java:682)
at
org.eclipse.ui.views.properties.PropertySheetViewer.access$6 (PropertySheetViewer.java:660)
at
org.eclipse.ui.views.properties.PropertySheetViewer$5.mouseD own(PropertySheetViewer.java:756)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Unhandled event loop exception
Reason:
Assertion failed:
* Created on Jul 20, 2003
* Eclipse GEF redbook sample application
* $Revision: 1.5 $
* (c) Copyright IBM Corp.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Common Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/cpl-v10.html
* Contributors:
* ddean Initial version
package jPDD.editparts;
import java.util.Collection;
import java.util.Iterator;
import java.util.Vector;
import model.ModelElement;
import model.ModelPackage;
import model.VisibilityKind;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EDataType;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.ui.views.properties.ComboBoxPropertyDescriptor;
import org.eclipse.ui.views.properties.IPropertyDescriptor;
import org.eclipse.ui.views.properties.IPropertySource;
import org.eclipse.ui.views.properties.PropertyDescriptor;
import org.eclipse.ui.views.properties.TextPropertyDescriptor;
* This class is intended to be a generic property source for all the
objects in
* the application's model. It currently only supports String and
boolean types,
* and doesn't support reset or nested properties. It uses information
in the EMF
* EAttribute and EDataType classes to get the id, display name, and
type information.
* @author ddean
public class GenericModelElementPropertySourceAdapter implements
IPropertySource {
private ModelElement element;
private ModelPackage modelPackage;
public GenericModelElementPropertySourceAdapter( ModelElement element ) {
this.element = element;
//Map registry = EPackage.Registry.INSTANCE;
//String workflowURI = WorkflowPackage.eNS_URI;
//workflowPackage = (WorkflowPackage) registry.get(workflowURI);
modelPackage = ModelPackage.eINSTANCE;
/* (non-Javadoc)
* @see org.eclipse.ui.views.properties.IPropertySource#getEditableV alue()
public Object getEditableValue() {
return element;
/* (non-Javadoc)
* @see
org.eclipse.ui.views.properties.IPropertySource#getPropertyD escriptors()
public IPropertyDescriptor[] getPropertyDescriptors() {
Iterator it;
EClass cls = element.eClass();
Collection descriptors = new Vector();
it = cls.getEAllAttributes().iterator();
while( it.hasNext() ) {
EAttribute attr = (EAttribute)it.next();
EDataType type = attr.getEAttributeType();
if( attr.isID() ) {
// shouldn't be editable
descriptors.add( new PropertyDescriptor( Integer.toString(
attr.getFeatureID() ),
attr.getName() ) );
//else if( type.getInstanceClass() == String.class &&
!(attr.getName().equals("identifier"))) {
else if( type.getInstanceClass() == String.class ) {
descriptors.add( new TextPropertyDescriptor( attr.getName() ,
attr.getName() ) );
else if( type.getInstanceClass() == boolean.class ) {
descriptors.add( new CheckboxPropertyDescriptor( attr.getName() ,
attr.getName() ) );
//String[] values = {"true", "false"};
//descriptors.add( new ComboBoxPropertyDescriptor( attr.getName(),
// attr.getName() , values));
else if (type.getInstanceClass()== VisibilityKind.class) {
System.out.println(VisibilityKind.VALUES.toArray());
String[] values = {"private", "protected", "public", "package"};
attr.getName(), values));
return (IPropertyDescriptor[])descriptors.toArray( new
IPropertyDescriptor[] {} );
/* (non-Javadoc)
* @see
org.eclipse.ui.views.properties.IPropertySource#getPropertyV alue(java.lang.Object)
public Object getPropertyValue(Object id) {
//EStructuralFeature feature = element.eClass().getEStructuralFeature(
Integer.parseInt( (String)id ) );
element.eClass().getEStructuralFeature(id.toString());
//System.out.println(feature);
Object result = element.eGet( feature );
//System.out.println(result);
System.out.println(feature + ": " +result);
Object tmp = result != null ? result : "";
System.out.println(tmp);
return tmp;
/* (non-Javadoc)
* @see
org.eclipse.ui.views.properties.IPropertySource#isPropertySe t(java.lang.Object)
public boolean isPropertySet(Object id) {
// TODO Auto-generated method stub
return false;
/* (non-Javadoc)
* @see
org.eclipse.ui.views.properties.IPropertySouce#resetProperty Value(java.lang.Object)
public void resetPropertyValue(Object id) {
/* (non-Javadoc)
* @see
org.eclipse.ui.views.properties.IPropertySource#setPropertyV alue(java.lang.Object,
java.lang.Object)
public void setPropertyValue(Object id, Object value) {
id.toString() );
element.eSet( feature, value );
Re: Assertion failed, Property View with a ComboBoxDescriptor [message #202500 is a reply to message #202437] |
Thu, 10 November 2005 05:19  |
Matt wrote:
> Hi Jens,
> I'm not an expert, but I've worked with ComboBoxPropertyDescriptors in
> the past. You need to remember that getPropertyDescriptor() must return
> an Integer and the second argument in setPropertyDescriptor() is an
> Integer.
Do you mean getPropertyValue() instead of getPropertyDescriptor()? If
yes what happens with String values if this method only returns Integers?
> So I'd change 'tmp' in getPropertyDescriptor to an Integer and make sure
> that element.eSet(feature, value) can accept an Integer as its 'value'
> parameter.
> If this doesn't help, please point out which lines of code produce the
> error.
Sorry, but I can not point out the line which produce the error. Without
the ComboxboxDescriptor no error occurs. The error occurs only if I
click the ComboBoxDesciptor in the property view. The initial value is
also ok only modifications do not work.
Jens
> Good luck.
> Matt
FUDForum. Page generated in 0.02885 seconds
