Home » Language IDEs » ServerTools (WTP) » Flexible Project
Flexible Project [message #201950] Thu, 11 October 2007 17:25 Go to next message
Does anyone know if Flexible Project concept is still valid for WTP2.0? I
was reading some online document and it refers to IFlexibleProject.
However I can't find this interface anywhere in the WTP 2.0 source.
Similar things happen to ModuleCore, ModuleStructuralModel and a few
others. It seems that they were replaced by ArtifactEdit and
ArtifactEditModel etc. But some of them still exist in the source with
minimum references to them. Developer guide doesn't talk anything about
these either. Any clarification appreciated.
Re: Flexible Project [message #201973 is a reply to message #201950] Fri, 12 October 2007 11:37 Go to previous messageGo to next message
I'm not aware of much new documentation yet, but here are some classes
I've made use of in my programming which previously involved some of the
classes you mention:
org.eclipse.wst.common.componentcore.ComponentCore
org.eclipse.jst.j2ee.model.ModelProviderManager
org.eclipse.jst.j2ee.model.IModelProvider
org.eclipse.wst.common.project.facet.core.ProjectFacetsManag er
org.eclipse.wst.common.project.facet.core.FacetedProjectFram ework
org.eclipse.wst.common.project.facet.core.I*
I think IFacetedProject has replaced IFlexibleProject. If you can
elaborate on what you are looking to do, I can try to provide more detail.
Larry
> I was reading some online document and it refers to IFlexibleProject.
Re: Flexible Project [message #201982 is a reply to message #201973] Fri, 12 October 2007 12:23 Go to previous messageGo to next message
I was trying to get some meta information about the project. More
specifically I was looking at the info stored in
settings/org.eclipse.wst.common.component for the module URI, the
wb-resources and the properties. I was able to get the properties using
ArtifactEdit.getComponent().getMetaProperties(). However, I couldn't get
the other two without going into the internal implementation classes such
as ModuleStructuralModel. Any ideas? Thanks for your help.
Re: Flexible Project [message #201988 is a reply to message #201982] Fri, 12 October 2007 13:46 Go to previous messageGo to next message
Would IVirtualComponent.getReferences() and
ref[i].getReferencedComponent() give you an IVirtualComponent that can
access the what you want for wb-resource? It can access some
wb-resource info but not everything. I'm not sure what corresponds to
module URI. Are you referring to the deploy-name or something else?
Larry
> such as ModuleStructuralModel. Any ideas? Thanks for your help.
Re: Flexible Project [message #202094 is a reply to message #201988] Sun, 14 October 2007 22:33 Go to previous message
Unfortunately these don't provide the values for wb-resource etc. It looks
like the IVirtualComponent is not fully populated for some reason. I am
going to look at IFacedProject as you suggested. Thanks.
Previous Topic:creating a new key combination for a WTP command
Next Topic:There are no projects that can be added or removed from the server.
Current Time: Sun Jul 20 09:00:22 EDT 2025
Powered by FUDForum. Page generated in 0.03731 seconds
