Home » Modeling » GMF (Graphical Modeling Framework) » 2 GMF Diagrams based on the same model at runtime
2 GMF Diagrams based on the same model at runtime [message #199466] Tue, 29 July 2008 22:42 Go to next message
Originally posted by: s.gil.gmx.com
Hi all,
I am currently working on a project in which I need to work in 2 or more GMF
diagrams which uses the same model (ecore).
The problem is that the second GMF diagram needs to define its elements
based on the result of the FIRST GMF diagram.
BUT even thought, both of them are running on the same eclipse, I cannot
access the elements created BY the first diagram on the second one.
(Both diagrams use the SAME ecore, and generated classes at runtime.).
Does anyone know how can I do that?
I think it is because both diagrams DO NOT persist the results on the same
"model" file (the result of a GMF diagram, is a diagram file which persists
the graphical things, and a "model file").
Is there a way to make 2 GMF diagrams persist its results on the same
"model" file?
Or is there a way to "import" the "model" results of 1 GMF diagram, into the
"model file" in the second diagram?
Any help appreciated.
Thanks in advance
Re: 2 GMF Diagrams based on the same model at runtime [message #199564 is a reply to message #199466] Wed, 30 July 2008 10:41 Go to previous messageGo to next message
Hello Santiago,
Try calling "Initialize <2-nd>_diagram diagram file" popup menu action on
the .model file created by first diagram. As a result you should be able
to choose elements created on 1-st diagram and create 2-nd diagram for them.
This is a way to "link" two diagrams with the same model file. In addition
diagram partitioning feature can be useful for youe use cases: http://wiki.eclipse.org/GMF_2.0_New_and_Noteworthy#Basic_sup port_for_diagram_partitioning.
Alex Shatalin
Re: 2 GMF Diagrams based on the same model at runtime [message #199712 is a reply to message #199564] Thu, 31 July 2008 23:00 Go to previous messageGo to next message
thanks Shatalin,
i ll give a try to the diagram partitioning,
Alex,
thanks for your help,
do you know where can i find some documentation on how to use "diagram
partitioning" ?
any clues would be great,
thanks,
Santiago Gil
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e624da38cac07a398b3cbd@news.eclipse.org...
> Hello Santiago,
> them. This is a way to "link" two diagrams with the same model file. In
> addition diagram partitioning feature can be useful for youe use cases:
> Alex Shatalin
Re: 2 GMF Diagrams based on the same model at runtime [message #199728 is a reply to message #199712] Thu, 31 July 2008 23:29 Go to previous messageGo to next message
There are a couple of existing news postings on diagram partitioning...
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg06184.html
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg05492.html
Re: 2 GMF Diagrams based on the same model at runtime [message #199735 is a reply to message #199564] Fri, 01 August 2008 00:50 Go to previous messageGo to next message
Hello, and thanks for your answer..
ill check the links, and try them in my project...
but I what i need in my project is to persist the behaviour of the "Add
Resource.." functionality (Which links the 2 diagram file).
Is there a way i could make this link between the two diagrams permanent?
either at runtime, programatically or modifying the .xml?
thanks in advance.
Santiago Gil
> Hello Santiago,
> Alex Shatalin
Re: 2 GMF Diagrams based on the same model at runtime [message #199759 is a reply to message #199735] Fri, 01 August 2008 03:43 Go to previous message
Hello Santiago,
> "Add
> permanent?
> thanks in advance.
You can load second diagram in generated ???DocumentProvider (see .createDocument()
method as an entry point). This is a place where Diagram instance is loaded
from EMF Resource, so you can load another instance there based on som information
you have concerning the link between these two diagrams. If you need to store
this knowledge in a notation model - try using DiagramLinkStyle for it.
Alex Shatalin
Previous Topic:A tree outline in GMF
Next Topic:NULL with ArrangeAll
Current Time: Sat Jul 19 06:16:26 EDT 2025
Powered by FUDForum. Page generated in 0.25105 seconds
