Problem while creating DiagramDocumentEditor as a drop target [message #196991] |
Mon, 14 July 2008 16:01 |
Hello All,
I am trying to assign the DiagramDocumentEditor (generated by GMF) as a
drop target for some custom tools in the fly-out palette (some of which
were added manually). I did an override of the
createPaletteViewerProvider method to make it a drag source:
protected PaletteViewerProvider createPaletteViewerProvider() {
super.createPaletteViewerProvider();
getEditDomain().setPaletteRoot(createPaletteRoot(null));
return new PaletteViewerProvider(getEditDomain()) {
public PaletteViewer createPaletteViewer(Composite parent) {
return super.createPaletteViewer(parent);
protected void configurePaletteViewer(PaletteViewer
viewer) {
super.configurePaletteViewer(viewer);
viewer.addDragSourceListener(new
TemplateTransferDragSourceListener(viewer));
I then did an override of the initializeGraphicalViewer method:
protected void initializeGraphicalViewer() {
super.initializeGraphicalViewer();
getDiagramGraphicalViewer().addDropTargetListener(new
TemplateTransferDropTargetListener(getGraphicalViewer()) {
protected CreationFactory getFactory(Object template) {
return new NodeCreationFactory((Class<?>)(template));
"NodeCreationFactory" is the name of my class which creates and returns
Objects based on the "template".
There is no problem when I drag and drop tools in the palette which were
generated by GMF. But the editor does not act as a drop target for the
tools which were manually added by me. Am I missing something here? Do I
have to implement/override some other method?
Thanks in advance.
Naren.
FUDForum. Page generated in 0.05029 seconds
