Home » Language IDEs » ServerTools (WTP) » Creating a web service by WTP
Creating a web service by WTP [message #196733] Thu, 19 July 2007 13:04 Go to next message
Originally posted by: zomithex1.yahoo.com
Hello Dear Friends,
I am trying to create a web service using WTP by going through the
"Eclipse Evaluation Guide".
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/WebServicesToolsEval.html#tour-bu-prereqtomcat
in part 3.2.4 which is "Create a Web service and Web service client"
after step 8, which is the end of the configuration of the web service
before using it, I got this error:
"IWAB0213E Error in starting server
Detail:
org.eclipse.core.runtime.CoreException:
several ports(8005,8080,8009) required by Tomcat v6.0 server at localhost
are already in use. The server may already be running in another
process, or a system process may be using the port. To start this server
you will need to stop the other process or change the port number(s)".
I can run the Tomcat manually, seems noting is wrong with it.
And I am not using any other program which may use Tomcat server.
Do you have any idea what's wrong and what should I do?
Thanks a lot
Mitra
Re: Creating a web service by WTP [message #196767 is a reply to message #196733] Thu, 19 July 2007 16:01 Go to previous messageGo to next message
Hi Mitra,
When you are running Tomcat from WTP, is the other instance(outside of
Eclipse) also running? If so, there's likely a port sharing issue, and
you need to shutdown the outside server. Another option is to change
the WTP Tomcat configuration to use a different server port other than 8080.
I have used Tomcat5.0 and Tomcat5.5 (but not Tomcat v6.0) in this
scenario, so I can't rule out Tomcat v6.0 behaviour.
Hope that helps,
Seng
mitra wrote:
> Hello Dear Friends,
> Detail:
> localhost are already in use. The server may already be running in
> another process, or a system process may be using the port. To start
> this server you will need to stop the other process or change the port
> number(s)".
> Thanks a lot
> Mitra
Re: Creating a web service by WTP [message #196775 is a reply to message #196767] Thu, 19 July 2007 16:30 Go to previous messageGo to next message
Originally posted by: zomithex1.yahooo.com
Dear Seng,
Would you please explain me a lil what you mean by "other instance" in
"is the other instance(outside of Eclipse) also running?" and "outside
server" in "you need to shutdown the outside server".
Sorry, but I have no idea what they really point to.
thanks a lot
Mitra
Re: Creating a web service by WTP [message #196782 is a reply to message #196775] Thu, 19 July 2007 16:48 Go to previous messageGo to next message
The following would be a good place to start in the WTP Tomcat FAQ to
learn about these "instances":
http://www.eclipse.org/webtools/faq/TomcatServerFAQ.php#gett ing_started_1
This FAQ has not been updated with WTP 2.0 info yet, but this aspect of
Tomcat servers in WTP hasn't changed and is still relevant.
Larry
mitra wrote:
> Dear Seng,
> thanks a lot
> Mitra
Re: Creating a web service by WTP [message #196790 is a reply to message #196775] Thu, 19 July 2007 16:53 Go to previous message
Hi Mitra,
I may be wrong here, but a common mistake is starting Tomcat from the
actual install location; that is what I mean by the 'outside(of Eclipse)
server', and then starting it again from inside Eclipse. The conflict
occurs because the Tomcat server created in WTP is attemptig use the
same ports but since another server may already be started, there is a
conflict.
The solution is to make sure you have no servers(or ports) occupied when
you try to start your server from Eclipse.
Hope that helps,
Seng
mitra wrote:
> Dear Seng,
> thanks a lot
> Mitra
Previous Topic:Error parsing WSDL
Next Topic:Exported jars from utility module...
Current Time: Sun Jul 20 06:00:28 EDT 2025
Powered by FUDForum. Page generated in 0.05497 seconds
