Home » Modeling » GMF (Graphical Modeling Framework) » Platform-/ file resource problem
Platform-/ file resource problem [message #194916] |
Mon, 30 June 2008 05:36  |
Originally posted by: balancedblend.gmx.de
one of our editors internally uses platform resources instead of file
resources like the others. This causes for example, that the
modification stamp in the document provider cannot be computed, because
no file can be retrieved from the platform resource (very bad in our
case). Does somebody know the reason for this?
Thanks in advance!
Kind regards,
Johannes
Re: Platform-/ file resource problem [message #194956 is a reply to message #194916] |
Mon, 30 June 2008 09:05   |
Originally posted by: cdamus.zeligsoft.com
--=-9rIrwqtuqGRX3kVwqbVD
Content-Type: text/plain
Hi, Johannes,
In EMF 2.4, the Resource interface now has API for accessing stuff like
the timestamp, for protocols (such as file: and platform:) that can
provide it. Have a look at the Resource::getTimestamp() method for
uniform access to your resources' timestamps.
HTH,
Christian
On Mon, 2008-06-30 at 11:36 +0200, Johannes Koehler wrote:
> Hello,
> Thanks in advance!
> Kind regards,
> Johannes
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Johannes,<BR>
<BR>
In EMF 2.4, the Resource interface now has API for accessing stuff like the timestamp, for protocols (such as file: and platform:) that can provide it. Have a look at the Resource::getTimestamp() method for uniform access to your resources' timestamps.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Hello,</FONT>
<FONT COLOR="#000000">one of our editors internally uses platform resources instead of file </FONT>
<FONT COLOR="#000000">resources like the others. This causes for example, that the </FONT>
<FONT COLOR="#000000">modification stamp in the document provider cannot be computed, because </FONT>
<FONT COLOR="#000000">no file can be retrieved from the platform resource (very bad in our </FONT>
<FONT COLOR="#000000">case). Does somebody know the reason for this?</FONT>
<FONT COLOR="#000000">Thanks in advance!</FONT>
<FONT COLOR="#000000">Kind regards,</FONT>
<FONT COLOR="#000000">Johannes</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-9rIrwqtuqGRX3kVwqbVD--
Re: Platform-/ file resource problem [message #196573 is a reply to message #196349] |
Thu, 10 July 2008 17:44  |
--=-r9Kjmh46HvRzQLXcKvo9
Hi, Johannes,
It is generally recommended, in the Eclipse environment, to use the
platform: scheme URIs to access resources in the Eclipse environment.
This includes resources in the workspace, installed plugins, workspace
meta-data area, configuration meta-data area, and something else that I
forget at the moment.
Using platform URIs should solve more problems than it produces. The
benefit of these URIs is that they are portable; the don't depend on the
location of files in the user's filesystem. For shared resources, such
as workspace files shared in CVS or installed plug-ins, you don't want
URIs in your models that depend on a particular users's installed
location of Eclipse. These platform URIs abstract away that detail.
IMHO, editors that don't use platform URIs are broken! ;-)
Christian
On Wed, 2008-07-09 at 19:46 +0200, Johannes Koehler wrote:
> Hi Christian,
> thanks for your hint. Right now I can't use emf 2.4 for several reasons,
> I fixed it in a similar way.
> I assume the use of platform resources leads to another problem. Can you
> tell me, why the editor uses those platform- instead of file resources?
> It depends on the location where the file is stored, but not all editors
> behave this way and I don't understand why.
> Thanks in advance!
> regards,
> Johannes
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Johannes,<BR>
<BR>
It is generally recommended, in the Eclipse environment, to use the platform: scheme URIs to access resources in the Eclipse environment. This includes resources in the workspace, installed plugins, workspace meta-data area, configuration meta-data area, and something else that I forget at the moment.<BR>
<BR>
Using platform URIs should solve more problems than it produces. The benefit of these URIs is that they are portable; the don't depend on the location of files in the user's filesystem. For shared resources, such as workspace files shared in CVS or installed plug-ins, you don't want URIs in your models that depend on a particular users's installed location of Eclipse. These platform URIs abstract away that detail.<BR>
<BR>
IMHO, editors that don't use platform URIs are broken! ;-)<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<PRE>
<FONT COLOR="#000000">Hi Christian,</FONT>
<FONT COLOR="#000000">thanks for your hint. Right now I can't use emf 2.4 for several reasons, </FONT>
<FONT COLOR="#000000">I fixed it in a similar way.</FONT>
<FONT COLOR="#000000">I assume the use of platform resources leads to another problem. Can you </FONT>
<FONT COLOR="#000000">tell me, why the editor uses those platform- instead of file resources? </FONT>
<FONT COLOR="#000000">It depends on the location where the file is stored, but not all editors </FONT>
<FONT COLOR="#000000">behave this way and I don't understand why.</FONT>
<FONT COLOR="#000000">regards,</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-r9Kjmh46HvRzQLXcKvo9--
Current Time: Sun Jul 20 18:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.04634 seconds
