Home » Modeling » GMF (Graphical Modeling Framework) » How to remove elements from non-synchronized diagrams
How to remove elements from non-synchronized diagrams [message #195903] Mon, 07 July 2008 04:29 Go to next message
Originally posted by: janiko.gmx.de
Hello everyone,
Is it possible to remove elements in a non-synchronized diagram
environment? Sylvain had the same problem in
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg12882.html
, but the solution of Jan is to generate the code with synchronized =
true, and than customize the CannonicalEditPolicy. My question is, if
this are the only way to remove elements from all diagrams of a model,
why there exist a synchronized option in the .gmfgen? Is there any
solution to remove a element from all diagrams that reference to the
same model element, without to putting synchronized on, and implement a
non synchronized behavior by my own? Because i think the "delete from
diagram" and "delete from model" options are very nice, if its works.
Thank you in advanced,
Tony
Re: How to remove elements from non-synchronized diagrams [message #195950 is a reply to message #195903] Mon, 07 July 2008 06:47 Go to previous messageGo to next message
Hello Tony,
You can implement simple CanonicalEditPolicy and install it for all the EditParts
on all diagrams. This EditPolisy should be ratehr generic and remove corresponding
"obsolete" views if there any.
This option allows you to not generate CanonicalEditPolicies and manage diagram
elements manually.
You can listen for the corresponding notifications, load all diagrams and
remove corresponding element - just custom code managing this situation.
These actions works well AFAIU the problem is: you'd like to remove corresponding
elements from all other diagrams.
Alex Shatalin
Re: How to remove elements from non-synchronized diagrams [message #195965 is a reply to message #195950] Mon, 07 July 2008 07:45 Go to previous message
Thanks a lot for your answer.
It works, i have installed a very simple CanonicalEditPolicy like this:
installEditPolicy(EditPolicyRoles.CANONICAL_ROLE, new CanonicalEditPolicy(){
protected List getSemanticChildrenList() {
return Collections.EMPTY_LIST;
There are still a small problem: The "delete from diagram" action will
be grayed out, if i install a CanonicalEditPolicy. Do you know how i can
re-enable this action?
regards,
Tony
Alex Shatalin schrieb:
> Hello Tony,
> EditParts on all diagrams. This EditPolisy should be ratehr generic and
> remove corresponding "obsolete" views if there any.
> diagram elements manually.
> and remove corresponding element - just custom code managing this
> situation.
> corresponding elements from all other diagrams.
> Alex Shatalin
Previous Topic:Get Editpart from semantic element
Next Topic:Remove Compartment's top border line
Current Time: Sat Jul 19 08:44:48 EDT 2025
Powered by FUDForum. Page generated in 0.03365 seconds
