servlets in view [message #195473] |
Tue, 03 July 2007 04:27  |
I upgraded to WTP 2.0 (using eclipse 3.3 on Win XP).
I remember there used to be a view in which I could see all the servlets and
their mappings in my dynamic web projects - was it removed?
Zohar.
Re: servlets in view [message #195514 is a reply to message #195497] |
Tue, 03 July 2007 05:37  |
If you create, for example, a Web project, on the second page of the wizard
you can see the facets and adjust its version. If the Dynamic Web Module
facet points to 2.4 then you create a J2EE 1.4 project. If the facet points
to 2.5, then you create a Java EE 5 project.
What is the situation in your case?
"zohar" <david_fire4@hotmail.com> wrote in message
news:f6d4hq$h3h$1@build.eclipse.org...
>I can't see the Deployment Descriptor, which probably meand I use EE5 - but
>how do I set this?
> Zohar.
> "Kaloyan Raev" <kaloyan.raev@sap.com> wrote in message
> news:f6d42f$fmv$1@build.eclipse.org...
>>I suggest you are talking about the Deployment Descriptor tree in the
>>Project Explorer.
>> It still exists for J2EE (1.2, 1.3, 1.4) projects.
>> The new Java EE 5 projects that were introduced in WTP 2.0 still do not
>> have such tree due to their new models. There was not enough time to
>> implement the tree for them. This is something that will probably be
>> introduced in WTP 3.0.
>> news:f6d1a0$7q8$1@build.eclipse.org...
>>> Hi,
>>> and their mappings in my dynamic web projects - was it removed?
>>> Thanks,
>>> Zohar.
FUDForum. Page generated in 0.03706 seconds
