Home » Eclipse Projects » GEF » TemplateTransferDropTargetListener & CombinedTemplateCreationEntry - Problem
TemplateTransferDropTargetListener & CombinedTemplateCreationEntry - Problem [message #195231] Thu, 08 September 2005 15:13 Go to next message
there's one thing that really bugs me, but let me first explain what I need
to do:
My palette shows different kinds of objects the user is supposed to be able
to place on the editor. Some of these objects can be created just by
passing the template object to a factory class.
Some objects in my palette represent objects already placed on the editor
and therefor require some additional data to be passed to the creation
factory. For this purpose I'm using a CombinedTemplateCreationEntry which
I'm passing a custom CreationFactory which takes the additional and needed
data as well as the template to create new models.
This works well for Point&Click-adding new objects to the editor.
When using Drag&Drop with a TemplateTransferDropTargetListener to add new
objects however, I need to implement the getFactory(Object template) method
- All information I'm getting to return a suitable CreationFactory is the
plain template which is not sufficient under certain circumstances.
Why does it not use the CreationFactory passed to the
CombinedTemplateCreationEntry - which can be parameterized with all the
information needed? This would even be the more expected behaviour.
Thanks for any comments!
Fabian
Re: TemplateTransferDropTargetListener & CombinedTemplateCreationEntry - Problem [message #195265 is a reply to message #195231] Thu, 08 September 2005 21:37 Go to previous messageGo to next message
Can you not just set a CreationFactory *as* the template object? then
getFactory() would just cast the template to a factory.
"Fabian Wolf" <Fabian.Wolf@informatik.uni-ulm.de> wrote in message
news:dfq2hv$ufk$1@news.eclipse.org...
> need
> to do:
> able
> method
> Fabian
Re: TemplateTransferDropTargetListener & CombinedTemplateCreationEntry - Problem [message #195289 is a reply to message #195265] Fri, 09 September 2005 03:05 Go to previous messageGo to next message
Hi Randy,
that would surely be possible, is not a clean solution though.That'd make me
pass two CreationFactories to the CombinedTemplateCreationFactory - one
which is used for DragNDrop the other for Point&Click.
What I'm missing is a getFactory() method in
org.eclipse.gef.palette.CreationToolEntry - or for future releases a
getToolProperty(Object key). There would then be no need for the abstract
method getFactory(Object template) in TemplateTransferDropTargetListener,
instead it could return the CreationFactory the palette entry was equipped
with... something like that (not tested):
EditPart editPart = (EditPart)getViewer().getSelectedEditParts().get(0);
Object model = editPart.getModel();
if (model instanceof CombinedTemplateCreationFactory)
return ((CombinedTemplateCreationEntry)model).getFactory();
return null;
This is the way the templates get set in TemplateTransferDragSourceListener.
Or: the CreationFactory could be carried in the TemplateTransfer just like
the template.
I just think that if a palette Entry is equipped with a custom
CreationFactory, that factory should be used not only on Point&Click but
also on Drag&Drop - to make it consistent.
Fabian
>> Hi,
>> need
>> to do:
>> able
>> needed data as well as the template to create new models.
>> method
>> Fabian
Re: TemplateTransferDropTargetListener & CombinedTemplateCreationEntry - Problem [message #195296 is a reply to message #195289] Fri, 09 September 2005 03:07 Go to previous messageGo to next message
Uh, not get set, but get retrieved :)
Re: TemplateTransferDropTargetListener & CombinedTemplateCreationEntry - Problem [message #195425 is a reply to message #195289] Fri, 09 September 2005 14:17 Go to previous messageGo to next message
> Hi Randy,
> me
Could it not just be the same factory? We'll add a new constructor in 3.2
that takes just a factory, and uses it as the template.
> EditPart editPart =
> return
> return null;
> the template.
So, we could also make the drop target adapter concrete, and assume the
template is a creation factory. Subclasses could still override the
preivously-abstract method.
In theory, a template could be anything, including the color blue, a layout
manager, etc. Some of these scenarios might not require creation factories.
Re: TemplateTransferDropTargetListener & CombinedTemplateCreationEntry - Problem [message #195482 is a reply to message #195425] Sat, 10 September 2005 04:38 Go to previous message
>> like the template.
> layout manager, etc. Some of these scenarios might not require creation
> factories.
Do I get this right, that in future a CreationFactory is just another
ToolProperty?
If this is true (an idea I like btw), then PaletteEntry constructors like
CombinedTemplateCreationEntry that take CreationFactories as parameters
could just set this ToolProperty instead explicitly setting the factory
variable as it is done now. Something like
setToolProperty(ToolProperty.FACTORY, creationFactory) ...
setToolProperty(ToolProperty.TEMPLATE, template) ...
This way all that needs to be transported in a Transfer*Listener would be
the ToolProperty-HashMap.
This would be very flexible I believe. The DropTargetAdapter could be made
concrete and to the outside, the behavioud would not change, since the
factory is only internally converted to a ToolProperty - actually it would
get more consistent.
Previous Topic:collapsing a figure
Next Topic:Unable to load graphics library [GDI+ is required]
Current Time: Sat Jul 19 16:42:19 EDT 2025
Powered by FUDForum. Page generated in 0.04138 seconds
