Home » Eclipse Projects » GEF » Draw2d Label bounds
Draw2d Label bounds [message #195163] Thu, 08 September 2005 12:05 Go to next message
Originally posted by: rsudra.no.spam.hotmail.com
With Draw2d 3.0.1 I could do:
new Label(".....").getBounds()
which would return bounds with (0, 0, 64, 36)
3.1.0, the same returns bounds with (0, 0, 0, 0)
Now, I have to resize the label with the width and height above where
before I didn't. I am adding the label to its parent later.
Has the api/behaviour changed?
Raj
Re: Draw2d Label bounds [message #195181 is a reply to message #195163] Thu, 08 September 2005 12:17 Go to previous messageGo to next message
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
If I understand previous messages in this newsgroup correctly, a
figure's initial size is now (0, 0).
Have you tried calling getPreferredSize() on the newly created label
instead?
Martijn.
> Thanks
> Raj
Re: Draw2d Label bounds [message #195188 is a reply to message #195181] Thu, 08 September 2005 12:18 Go to previous messageGo to next message
See news://news.eclipse.org:119/d3m0hj$nm5$1@news.eclipse.org
Re: Draw2d Label bounds [message #195218 is a reply to message #195188] Thu, 08 September 2005 13:10 Go to previous messageGo to next message
Originally posted by: rsudra.hotmail.com
Hello Martijn,
I couldn't see the message, any chance you could repost the guts to this
thread please?
Thanks for the response.
Raj
Re: Draw2d Label bounds [message #195240 is a reply to message #195218] Thu, 08 September 2005 15:15 Go to previous messageGo to next message
Randy Hudson wrote on 14/04/2005:
Some time back, the default size for a figure changed from 64,32 to 0,0.
This was done for performance reason. The default size was meaningless,
yet it had the result that adding a figure and then laying out it's
parent resulted in a damage region that was larger than necessary. The
figure had never painted at 0,0,64,32, so when it moved, there is not
really reason to erase the region. Now that it is initially nowhere, it
doesn't need to erase during the first layout.
M.
Rajeev Sudra wrote:
> Hello Martijn,
> thread please?
Re: Draw2d Label bounds [message #195357 is a reply to message #195240] Fri, 09 September 2005 10:43 Go to previous messageGo to next message
What is the strategy for having the bounds of the Label compacted so it perfectly
fits the text supplied in the constructor?
Re: Draw2d Label bounds [message #195417 is a reply to message #195357] Fri, 09 September 2005 14:05 Go to previous message
Set it to its preferred size, or place it in a layout that does the same.
"Rajeev Sudra" <rsudra@hotmail.com> wrote in message
news:bd907dc11ab0c8c7836c63d07110@news.eclipse.org...
> perfectly fits the text supplied in the constructor?
Previous Topic:DirectedGraphLayout changed for 3.1?
Next Topic:collapsing a figure
Current Time: Sat Jul 19 05:27:42 EDT 2025
Powered by FUDForum. Page generated in 0.06105 seconds
