Home » Modeling » GMF (Graphical Modeling Framework) » Remove Compartment's top border line
Remove Compartment's top border line [message #194133] Mon, 23 June 2008 09:27 Go to next message
The compartment which is inside a component. And compartment created using
ResizableCompartmentFigure. Now inside compartment showing its only top
border line.
How can made invisible or transparent?.
Thanks In Advance.
Nagesh
Re: Remove Compartment's top border line [message #194770 is a reply to message #194133] Fri, 27 June 2008 05:16 Go to previous messageGo to next message
I was getting the same problem.You can remove compartment's border line
For this u need to comment the
createcontents method of ur compartment figure and write this line
private WrapLabel fFigureContainerNameFigure = new WrapLabel("");
in ur container figure.Hope this will work.
Re: Remove Compartment's top border line [message #194897 is a reply to message #194770] Mon, 30 June 2008 02:28 Go to previous messageGo to next message
Hello Anjali,
Thanks for the solution. I am not able find createcontents function in my
compartment editpart. And my compartment uses ResizableCompartmentFigure.
So can you send me your compartmenteditpart code, so that i can use the
same.
Thanks In Advance.
Nagesh
Re: Remove Compartment's top border line [message #195921 is a reply to message #194897] Mon, 07 July 2008 04:36 Go to previous messageGo to next message
Originally posted by: zippo29.hotmail.fr
Hi!
It's a bit late to answer your question but in case someone is searching
for the same feature there is another method:
In the createFigure() method in your compartment class add:
yourResizableCompartmentFigureInstance.setBorder(null);
Re: Remove Compartment's top border line [message #195973 is a reply to message #195921] Mon, 07 July 2008 08:20 Go to previous message
Thanks Mous, it's working.........
Mous wrote:
> Hi!
> Regards
Previous Topic:How to remove elements from non-synchronized diagrams
Next Topic:How to make figure's foreground line (boundry line) invisible?
Current Time: Sat Jul 19 13:26:48 EDT 2025
Powered by FUDForum. Page generated in 0.05052 seconds
