Home » Eclipse Projects » GEF » Custom Zooming
Custom Zooming [message #194510] Thu, 01 September 2005 17:46 Go to next message
Originally posted by: harsh.ti.com
Can someone please explain this to me. In the javadoc of
setZoomLevelContributions method in the ZoomManager class, it says
"Sets the list of zoom level contributions (as strings). If you contribute
something other than FIT_HEIGHT, FIT_WIDTH and FIT_ALL you must subclass
this class and override this method to implement your contributed zoom
function."
Does that mean I have to subclass ZoomManager? If so, how do I tell GEF
to use this new ZoomManager since the init of the
ScalableFreeformRootEditPart already calls a default one for you.
I am trying to set my own custom zooming so I need to ovverride the
zoomlevels.
Thank you,
Harsh
Re: Custom Zooming [message #194561 is a reply to message #194510] Fri, 02 September 2005 02:01 Go to previous messageGo to next message
Originally posted by: mail4zlq.gmail.com
At first,yes!you must subclass ZoomManager.
To "tell GEF to use this new ZoomManager",you can subclass
"ScalableFreeformRootEditPart" and overwrite "getZoomManager".
and in your editor overwrite "configureGraphicalViewer" set the
rootEditPart use you customer RootEditPart ...
good luck!!!
Harsh Sabikhi 写道:
> contribute something other than FIT_HEIGHT, FIT_WIDTH and FIT_ALL you
> must subclass this class and override this method to implement your
> contributed zoom function."
> zoomlevels.
> Thank you,
> Harsh
Re: Custom Zooming [message #194616 is a reply to message #194510] Fri, 02 September 2005 05:22 Go to previous messageGo to next message
Harsh Sabikhi schrieb am 01.09.2005 23:46:
> zoomlevels.
Do you want to define only own zoomlevels?
Like 20%, 50%, 66%, etc?
If yes, jsut create an array with your zoomlevels within configureGraphicalViewer() of your editorclass:
GraphicalViewer viewer = getGraphicalViewer();
ScalableRootEditPart rootEditPart = new ScalableRootEditPart();
viewer.setRootEditPart(rootEditPart);
ZoomManager manager = rootEditPart.getZoomManager();
double[] zoomLevels = new double[] { 0.05, 0.1, 0.25, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0 };
manager.setZoomLevels(zoomLevels);
ArrayList zoomContributions = new ArrayList();
zoomContributions.add(ZoomManager.FIT_ALL);
zoomContributions.add(ZoomManager.FIT_HEIGHT);
zoomContributions.add(ZoomManager.FIT_WIDTH);
manager.setZoomLevelContributions(zoomContributions);
Andreas
Re: Custom Zooming [message #194631 is a reply to message #194616] Fri, 02 September 2005 09:28 Go to previous messageGo to next message
Thank you all for your feedback.
I am doing something pretty complicated. It's not as simply as zooming
in/out with different levels.
Basically, the user can select a range in the editor with the marquee tool
and decide to zoom in. What I have to implement is to show only these
edit parts and fit them in the visible window.
Harsh
Re: Custom Zooming [message #194641 is a reply to message #194631] Fri, 02 September 2005 13:09 Go to previous messageGo to next message
Partik/Randy,
Just wondering about the following function in ZoomManager
* Currently does nothing.
* @param rect a rectangle
public void zoomTo(Rectangle rect) { }
Are there any plans to implement this in a future release?
Thank you,
Harsh
Re: Custom Zooming [message #194657 is a reply to message #194631] Sat, 03 September 2005 05:00 Go to previous messageGo to next message
Harsh schrieb am 02.09.2005 15:28:
> tool and decide to zoom in. What I have to implement is to show only
> these edit parts and fit them in the visible window.
I solved a similary problem with a wrapper object.
Instead of using a concrete rootmodelelement I wrapped it.
The new element references the elements to show and the root model element.
The content of your graphicalviewer is the wrapper element.
The edipartfactory now reacts on the wrapper instead the rootModelElement.
for example:
yor model A with children B and C.
User selects C, so now the visible child of A is C.
The getModelChildren method of editPart_A (corresponding to the wrapper) must return the elements referenced in the wrapper. (in the example
it references C, in your case a list of the selected elements).
In your case it could be difficult to zoomout.
But perhaps this idea could help you. It works for me in cooperation with the outlineview.
Andreas
Re: Custom Zooming [message #514656 is a reply to message #194657] Tue, 16 February 2010 04:09 Go to previous messageGo to next message
Just one comment on this. It does not really look like ZoomManager and ScalableFreeformRootEditPart are supposed to be subclassed. All the fields, e.g. zoomManager in ScalableFreeformRootEditPart are or zoom in ZoomManager are private. In order to properly extend these classes, those fields should be protected.
I want to override primSetZoom(), because I want a custom zoom behaviour. However this is the place, where "this.zoom = zoom" is set, what is necessary for most other methods to work in a correct way.
[Updated on: Tue, 16 February 2010 04:45] by Moderator
Re: Custom Zooming [message #514686 is a reply to message #514656] Tue, 16 February 2010 05:54 Go to previous messageGo to next message
I think MarqueeSelect zoom has been implemented in GMF
REF:
http://www.eclipse.org/forums/index.php?t=msg&goto=51319 1&#msg_513191
org.eclipse.gmf.runtime.diagram.ui.internal.tools.ZoomTool
is the implementation you are looking for..right??
Re: Custom Zooming [message #514688 is a reply to message #514686] Tue, 16 February 2010 06:04 Go to previous messageGo to next message
Thanks, I do not want to have marquee selection zoom. To make my issue more comprehensive: in my view I display an image, which I have in several zoom levels. So, when the zoom is executed, I want to load the image in another zoom level. I would do this by calling a method in primSetZoom(). However, I want to use all the other functionality that is already implemented in ZoomManager. As a workaround, I copied most methods from ZooManager, and introduce my own fields "zoom" and "listeners". I definetely do not want to use GMF.
Re: Custom Zooming [message #514696 is a reply to message #514688] Tue, 16 February 2010 06:33 Go to previous message
I think ZoomInAction and ZoomOutAction does that only!!
Previous Topic:GEF incubator proposal discussion
Next Topic:Change Zomm ComboBox width in my GEF editor
Current Time: Sat Jul 19 10:18:02 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
