Home » Eclipse Projects » GEF » selectionProvider in MultiPageEditor
selectionProvider in MultiPageEditor [message #194394] Thu, 01 September 2005 13:07 Go to next message
Originally posted by: gef.oppacher.ca
I was having problems with the MultiPageEditorPart and the Gef editors
that I embedded into the MultiPageEditorPart, specifically getting
selection changes. To fix this whenever I
MulitPageEditorPart#setActivePage() is called I set the selection provider
of the MultiPageEditor to be the GraphicalViewer of the newly selected
EditorPart. This all seems to work fine. So I was wondering if I'm
causing, or will cause problems by setting the selectionProvider? The
selectionProvider seems to be null before I set it and runs fine
afterwards. Any comments would be great.
Yandu
Re: selectionProvider in MultiPageEditor [message #194601 is a reply to message #194394] Fri, 02 September 2005 05:15 Go to previous messageGo to next message
Originally posted by: zhaojiangbin.163.com
i think you'd better to install a MultiPageSelectionProvider for a
MultiPageEditorPart in init() method.
consule the sample code bellow:
site.setSelectionProvider(new EditorMultiPageSelectionProvider(this));
and calss definition is:
EditorMultiPage is the MultiPageEditorPart name in my application
private static class EditorMultiPageSelectionProvider extends
MultiPageSelectionProvider {
private ISelection globalSelection;
* @param multiPageEditor
public EditorMultiPageSelectionProvider(EditorMultiPage editorMultiPage)
super(editorMultiPage);
public ISelection getSelection() {
IEditorPart activeEditor = ((EditorMultiPage) getMultiPageEditor())
.getActiveEditor();
if (activeEditor != null) {
ISelectionProvider selectionProvider = activeEditor.getSite()
.getSelectionProvider();
if (selectionProvider != null)
return selectionProvider.getSelection();
return globalSelection;
* (non-Javadoc) Method declared on <code> ISelectionProvider </code> .
public void setSelection(ISelection selection) {
.getActiveEditor();
selectionProvider.setSelection(selection);
} else {
this.globalSelection = selection;
fireSelectionChanged(new SelectionChangedEvent(this,
globalSelection));
"Yandu" <gef@oppacher.ca> д
Re: selectionProvider in MultiPageEditor [message #194624 is a reply to message #194601] Fri, 02 September 2005 08:12 Go to previous message
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
There already is a org.eclipse.ui.part.MultiPageSelectionProvider which
does this for you. If your multi-page editor extends MultiPageEditorPart
and you call the appropriate methods when adding new GraphicalEditors,
your problem should automagically be taken care of.
M.
> .getActiveEditor();
> .getActiveEditor();
> } else {
> globalSelection));
> "Yandu" <gef@oppacher.ca> дÈëÏûÏ¢ÐÂÎÅ:d434fd29286e7e94745b887a5148ef04$1@www.eclipse.org...
>>Hi,
>>Yandu
Previous Topic:IBM GEF/EMF Redbook
Next Topic:Help with GEF and layouts
Current Time: Sat Jul 19 19:34:21 EDT 2025
Powered by FUDForum. Page generated in 0.04993 seconds
