Home » Eclipse Projects » GEF » GEF & EMF representing AbsoluteBendpoint in EMF
GEF & EMF representing AbsoluteBendpoint in EMF [message #194228] Wed, 31 August 2005 13:03 Go to next message
I have seen a number of examples in representing points in EMF by using a
type defined in GEF that corresponds to a GEF type ie.
org.eclipse.draw2d.AbsoluteBendpoint.
The problem is that when i persist these they look like so in the persisted
file.
<bendpoints>Point(46, 255)</bendpoints>
During file load i get an exception when the file loads.
The value 'Point(283, 203)' is invalid.
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(Resourc
eSetImpl.java:268)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
mpl.java:349)
Re: GEF & EMF representing AbsoluteBendpoint in EMF [message #194261 is a reply to message #194228] Wed, 31 August 2005 14:52 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
This is an EMF question, not a GEF question.
You have two strategies in persisting a Point in EMF.
1) You can either use two int values representing x,y and build a point
from them when you load the file.
2) You can use a attribute Point, and create the proper createFromString
method so it builds a Point from the persisted "(x,y)" string. If you
have the EMF book, this is discussed with the Date example.
~ Chris
> file.
> at
> eSetImpl.java:268)
> at
> mpl.java:349)
Re: GEF & EMF representing AbsoluteBendpoint in EMF [message #194317 is a reply to message #194228] Thu, 01 September 2005 01:38 Go to previous message
> file.
You must provide custom implementations of the YyyFactoryImpl.createZzzFromString
and YyyFactoryImpl.convertZzzFromString methods. See p270-3 of the EMF book, and/or
org.eclipse.gef.examples.ediagram.model.impl.ModelFactoryImp l.
Previous Topic:Adding connections with custom layers
Next Topic:Copy/Cut and Paste Facility
Current Time: Sat Jul 19 15:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.04048 seconds
