Grouping components for a drag [message #193217] |
Wed, 24 August 2005 13:25  |
Originally posted by: gef.oppacher.ca
I'm trying to select a set of editparts when another editpart is selected
for dragging. When component A is selected for dragging I also want
components B, C, and D to also be selected for the components. I am
essentially trying to do what the marquee tool does but on the fly. I
created a DragTracker and overrid the handleDragStarted() method to select
the other components by using the appendSelection method in
GraphicalViewer. By doing this selection it seems to interupt my drag so
the objects don't actually move. Is there a better place to put this where
it won't override the drag?
Re: Grouping components for a drag [message #193350 is a reply to message #193310] |
Thu, 25 August 2005 09:58  |
I managed to get it working by updating the operationSet List in
AbsractTool to include all newly selected EditParts. I also had to
setState(STATE_DRAG_IN_PROGRESS). Thanks for your help.
Yandu
Abul Bashar wrote:
> Yes, you are right. I tried using EditPartListener & EditPart#setSelected().
> All others are selected as well but only the first one moves.
> Sorry, I don't have any other idea, but I think overriding appendSelection
> should work.
> regards
> "Yandu" <gef@oppacher.ca> wrote in message
> news:f6217bb06d79cb8e92e2b5cdd1a6841f$1@www.eclipse.org...
>> Selecting the other parts using GraphicalEditPart#setSelected() is exactly
>> what GraphicalViewer#appendSelection() does. It seems that when I add to
>> my selection group gef trets this as if the drag has finished since each
>> part that I add gains focus be default. So either I can override the
>> appendSelection method which I don't want to do or figure out how to
>> regenerate a drag request. Any ideas on how to do this?
>> Thanks
>> Abul Bashar wrote:
>>> You may try with implementing EditPartListener and register it with the
>>> editparts which will then be notified by
>>> EditPartListener#selectedStateChanged(EditPart editpart). @see
>>> GraphicalEditPart#setSelected() for selecting others.
>>> news:1d9e30770ea568ee686d112e89c85dfd$1@www.eclipse.org...
>>>> Hi,
>>>> selected for dragging. When component A is selected for dragging I also
>>>> want components B, C, and D to also be selected for the components. I am
>>>> select the other components by using the appendSelection method in
>>>> where it won't override the drag?
FUDForum. Page generated in 0.09427 seconds
