Home » Language IDEs » ServerTools (WTP) » Problem with requested resource not available
Problem with requested resource not available [message #193078] Fri, 25 May 2007 03:49 Go to next message
Originally posted by: gunnar.bostrom.tietoenator.com
Me an my colleagues are working with Eclipse 3.2, WST/JST 1.5.4 and
Tomcat 5.5.23.
Most of the time it works good but sometimes we can't start the webapp.
The web-app is not published correctly.
I tried almost all thing I can think of like remove Tomcat and install a
new instance, starting eclipse with -clean, removed the files in
....\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\web apps.
I've googled but did not found anything useful.
The log just complains about some problem with the plug in mylar, which
I have used with the setup that worked before.
Any suggestions?
Gunnar
This is from the Console:
2007-maj-25 09:37:13 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance
in production environments was not found on the java.library.path:
D:\gb\jdk\bin;.;C:\WINDOWS\system32;C:\WINDOWS;D:\oracle\ora 92\bin;D:\oracle\BPEL\bin;D:\Perl\bin\;C:\WINDOWS\system32;C :\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\ATI Technologies\ATI Control Panel;C:\Program Files\Executive
Software\Diskeeper\;D:\gb\jdk\bin;D:\gbx\apache-ant-1.6.5\bi n;D:\Program
Files\MySQL\MySQL Server 5.0\bin;D:\cygwin\bin;C:\Program
Files\Oracle\jre\1.3.1\bin;D:\oracle\BPEL\MOBILE\sdk\bin;D:\ gbx\maven-2.0.5\bin;D:\gb\jdk\bin;D:\Program
Files\QuickTime\QTSystem\;D:\gbx\agentControler\bin;D:\Progr am
Files\Subversion\bin;D:\PROGRA~1\F-Secure\Ssh;
2007-maj-25 09:37:13 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
2007-maj-25 09:37:13 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 741 ms
2007-maj-25 09:37:13 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
2007-maj-25 09:37:13 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.23
2007-maj-25 09:37:13 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
2007-maj-25 09:37:13 org.apache.catalina.core.StandardContext resourcesStart
ALLVARLIG: Error starting static Resources
java.lang.IllegalArgumentException: Document base
D:\gb\eclipse\workspaceSerf\.metadata\.plugins\org.eclipse.w st.server.core\tmp0\webapps\serf-web
does not exist or is not a readable directory
at
org.apache.naming.resources.FileDirContext.setDocBase(FileDi rContext.java:141)
at
org.apache.catalina.core.StandardContext.resourcesStart(Stan dardContext.java:3855)
at
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4024)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1014)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:736)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:448)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552 )
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 95)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 3)
2007-maj-25 09:37:13 org.apache.catalina.core.StandardContext start
ALLVARLIG: Error in resourceStart()
2007-maj-25 09:37:14 org.apache.catalina.core.StandardContext start
ALLVARLIG: Error getConfigured
ALLVARLIG: Context [/serf-web] startup failed due to previous errors
2007-maj-25 09:37:14 org.apache.catalina.core.StandardContext stop
INFO: Container
org.apache.catalina.core.ContainerBase.[Catalina].[localhost ].[/serf-web]
has not been started
2007-maj-25 09:37:14 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
2007-maj-25 09:37:14 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
2007-maj-25 09:37:14 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/70 config=null
2007-maj-25 09:37:14 org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
2007-maj-25 09:37:14 org.apache.catalina.startup.Catalina start
INFO: Server startup in 1061 ms
Re: Problem with requested resource not available [message #193144 is a reply to message #193078] Fri, 25 May 2007 13:38 Go to previous messageGo to next message
I don't have any guesses as to what exactly is going wrong. I would
highly recommend only adding and removing projects from the Tomcat
server when it is stopped, if you haven't been doing that already.
Also, try File -> Refresh on the project when the publishing problem
occurs and see if that help, assuming you haven't already tried this.
Finally, check your Error Log view for any unusual errors that might be
related.
Feel free open a bug report on the WebTools "jst.server" component. We
will have to gather more clues before I can figure out what is going
wrong. Any addition detail about circumstances when this occurs would
be helpful.
Larry
Gunnar Boström wrote:
> Tomcat 5.5.23.
> ...\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\weba pps.
> Any suggestions?
> Regards
> Gunnar
> lifecycleEvent
> resourcesStart
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> INFO: Container
Re: Problem with requested resource not available [message #193436 is a reply to message #193144] Tue, 29 May 2007 06:58 Go to previous messageGo to next message
Hi Larry,
Thanks for the reply.
We don't usually stop Tomcat before changes. It is very convenient to be
able change a file and Tomcat picks it up.
I finally get it working again by removing the Tomcat server from the
Servers view and removed the project from Eclipse without deleting the
content. Then I added the project again and let it run on the server and
it was fine again.
I really don't know how or why it happened. It could perhaps has
something to do that we are using Eclipse and Maven 2 and I think I
added a library with maven.
Gunnar
> server when it is stopped, if you haven't been doing that already. Also,
> try File -> Refresh on the project when the publishing problem occurs
> and see if that help, assuming you haven't already tried this. Finally,
> check your Error Log view for any unusual errors that might be related.
> be helpful.
> Cheers,
> Larry
>> Hi,
>> Tomcat 5.5.23.
>> a new instance, starting eclipse with -clean, removed the files in
>> which I have used with the setup that worked before.
>> Any suggestions?
>> Regards
>> Gunnar
>> lifecycleEvent
>> performance in production environments was not found on the
>> java.library.path:
>> resourcesStart
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> INFO: Container
Re: Problem with requested resource not available [message #193686 is a reply to message #193436] Wed, 30 May 2007 13:40 Go to previous message
I've tried to address this issue to some degree here:
http://www.eclipse.org/webtools/faq/TomcatServerFAQ.php#info _13
I don't have any good guess as to what caused your error either.
Larry
> Hi Larry,
> it was fine again.
> Regards
> Gunnar
>> be related.
>> We will have to gather more clues before I can figure out what is
>> going wrong. Any addition detail about circumstances when this occurs
>> would be helpful.
>> Cheers,
>> Larry
>>> Hi,
>>> Tomcat 5.5.23.
>>> install a new instance, starting eclipse with -clean, removed the
>>> files in
>>> Any suggestions?
>>> Regards
>>> Gunnar
>>> lifecycleEvent
>>> java.library.path:
>>> resourcesStart
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> INFO: Container
Previous Topic:Problem with WTP and Apache 4.1
Next Topic:Validation of JSP with VXML hangs
Current Time: Sat Jul 19 19:25:03 EDT 2025
Powered by FUDForum. Page generated in 0.03548 seconds
