Home » Newcomers » Newcomers » Installing Visual Editor 1.2.2
Installing Visual Editor 1.2.2 [message #192130] Tue, 06 February 2007 04:54 Go to next message
Hi Everyone,
I just download the Visual Editor 1.2.2 for Eclipse but I do not know how
to install it ! Although the Visual Editor has FAQs for the installation
but it is for the version 1.1.0.1 (old version). If anyone knows how to do
it, could you please show me how ?!
Thank you !
Enger
Re: Installing Visual Editor 1.2.2 [message #192144 is a reply to message #192130] Tue, 06 February 2007 05:18 Go to previous messageGo to next message
Originally posted by: jakub.jurkiewicz.gmail.com
Hi Enger,
You have to unzip the downloaded archive with VE. In the unpacked folder
you should see two directories: features and plugins. You have to copy
content of dir features to $ECLIPSE_HOME/features and content of dir
plugins to $ECLIPSE_HOME/plugins.
Let me know if it helps :)
regards,
Jakub Jurkiewicz
Enger wrote:
> Hi Everyone,
> how to install it ! Although the Visual Editor has FAQs for the
> installation but it is for the version 1.1.0.1 (old version). If anyone
> knows how to do it, could you please show me how ?!
> Thank you !
> Enger
Re: Installing Visual Editor 1.2.2 [message #192171 is a reply to message #192144] Tue, 06 February 2007 10:22 Go to previous messageGo to next message
Thank for your advice ! I already did as you say but after I run Eclipse
again, there is nothing affected :( In my new project menu, I see no
Visual Editor Project or even in Preferences/Java, no Visual Editor
setting ! Seemingly it does not recognize the plug-in folder of Eclipse
each time restarting !!!
Do you have any suggestion ?
Thank you !
Enger
Re: Installing Visual Editor 1.2.2 [message #192209 is a reply to message #192171] Tue, 06 February 2007 10:31 Go to previous messageGo to next message
Enger,
Maybe you need to run "eclipse.exe -clean" to refresh the configuration
after adding new things.
> Eclipse again, there is nothing affected :( In my new project menu, I
> see no Visual Editor Project or even in Preferences/Java, no Visual
> Editor setting ! Seemingly it does not recognize the plug-in folder of
> Eclipse each time restarting !!!
> Thank you !
> Enger
Re: Installing Visual Editor 1.2.2 [message #192214 is a reply to message #192209] Tue, 06 February 2007 10:58 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Ed Merks wrote:
> Enger,
>> Thank you !
>> Enger
There is no such thing as a Visual Editor Project, there is only a New
Visual Class wizard. If all you downloaded was the visual editor, then
you are probably missing several plugins that the visual editor requires.
The easiest was to install the Visual Editor is to use the Eclipse Update
Manager and select the Calisto update site. This will allow you to
automatically select required plugins when downloading.
Re: Installing Visual Editor 1.2.2 [message #192256 is a reply to message #192209] Tue, 06 February 2007 11:52 Go to previous messageGo to next message
I still get same result , nothing affected after I unzip the zip file to
the Eclipse folder ! I use Java SDK 1.6.0. Although I see the help of
Visual Editor in Help menu but I still do not see the Visual Editor
Project :">
Help me please !!!
Enger
Re: Installing Visual Editor 1.2.2 [message #192270 is a reply to message #192256] Tue, 06 February 2007 12:02 Go to previous messageGo to next message
Enger,
Dave makes a good point. You're sure you've installed all the required
prereqs listed in the "Requirements: PLEASE READ THIS SECTION FIRST"
section of the download page? Have you looked at the Error log for
clues about that?
> to the Eclipse folder ! I use Java SDK 1.6.0. Although I see the help
> of Visual Editor in Help menu but I still do not see the Visual Editor
> Project :">
> Help me please !!!
> Enger
Re: Installing Visual Editor 1.2.2 [message #192275 is a reply to message #192270] Tue, 06 February 2007 13:04 Go to previous messageGo to next message
I have read the prerequisites before installing Visual Editor. I also
download and unzip them into Eclipse folder. I try using the Update
Manager but it shows "Current Configuration Problems" when I choose to
install Java Development/Visual Editor in Callisto Update Site. Do you
Thank you.
Enger
Re: Installing Visual Editor 1.2.2 [message #192282 is a reply to message #192275] Tue, 06 February 2007 13:30 Go to previous messageGo to next message
Enger,
You've looked at the Error log and there are no clues there about
disabled plugins or missing prerequisites?
> Thank you.
> Enger
Re: Installing Visual Editor 1.2.2 [message #192405 is a reply to message #192282] Tue, 06 February 2007 19:23 Go to previous messageGo to next message
Well, finally I did update my Eclipse with Visual Editor by using Update
Manager :-) One more thing, how can I draw UML in Eclipse ? I can not find
UML update in Callisto Project !!!
Thank you !
Enger
Re: Installing Visual Editor 1.2.2 [message #192480 is a reply to message #192405] Wed, 07 February 2007 08:23 Go to previous message
Enger,
The support for graphical UML editing is just getting off the ground.
http://www.eclipse.org/modeling/mdt/?project=uml2tools#uml2t ools
> Update Manager :-) One more thing, how can I draw UML in Eclipse ? I
> can not find UML update in Callisto Project !!!
> Thank you !
> Enger
Previous Topic:Eclipse does not load!
Next Topic:How change jface wizard button text?
Current Time: Sat Jul 19 15:20:04 EDT 2025
Powered by FUDForum. Page generated in 0.10185 seconds
