Home » Eclipse Projects » GEF » WYSIWYG Text example added to GEF
WYSIWYG Text example added to GEF [message #191971] |
Fri, 12 August 2005 06:51  |
Originally posted by: snowice.asiamail.com
I've just noticed that a Text example has been added to GEF in Jan, but,
try as i might, i couldn't run the example in Eclipse. When i put in the
plugins, i can easily see from New -> Other Examples -> Shapes, Flow,
Logic... but where's Text? or should i invoke the application in another
way?
Btw, apart from Eclipse 3.1, what other versions of Eclipse can this
example runs on?
Evon
Re: WYSIWYG Text example added to GEF [message #192009 is a reply to message #191971] |
Fri, 12 August 2005 09:46   |
Originally posted by: none.unknown.com
Create a new file with a .text extension.
A wizard for the text example has been added, and will be available in
3.1.1.
"Evon" <snowice@asiamail.com> wrote in message
news:291b8db687d23ece83d0ee4b6ba3b76e$1@www.eclipse.org...
> way?
> example runs on?
> Regards,
> Evon
Re: WYSIWYG Text example added to GEF [message #194758 is a reply to message #192009] |
Mon, 05 September 2005 16:44   |
Originally posted by: kevin.cs.washington.edu
When I try to use the editor, the cursor somehow gets mis-aligned from
where I am typing. It seems random.
> 3.1.1.
>>Hi,
>>way?
>>example runs on?
>>Regards,
>>Evon
Re: WYSIWYG Text example added to GEF [message #194970 is a reply to message #194758] |
Tue, 06 September 2005 17:13   |
No, it's not random. We're very systematic in introducing bugs ;-)
Yes, the text example has several problems (there are bugzillas open about
it that you can search for), but that's because it's not completely done
yet. Still lots of things to fix and add.
What you say should work, however, so long as you're only typing on the same
line without going past the width of the viewer. Are you seeing problems
with that?
"Kevin Chiu" <kevin@cs.washington.edu> wrote in message
news:dfihoe$gg$1@news.eclipse.org...
> > 3.1.1.
> >>Hi,
> >>way?
> >>example runs on?
> >>Regards,
> >>Evon
Re: WYSIWYG Text example added to GEF [message #195077 is a reply to message #194970] |
Wed, 07 September 2005 15:41  |
Hopefully its the scrolling problem.
"Pratik Shah" <none@unknown.com> wrote in message
news:dfl0pe$8j3$1@news.eclipse.org...
> same
> with that?
Current Time: Sat Jul 19 10:34:44 EDT 2025
Powered by FUDForum. Page generated in 0.05043 seconds
