Block comments in XML broken in latest I-build? [message #191820] |
Thu, 26 April 2007 17:28  |
Originally posted by: shad_lane.hotmail.com
In the latest I-build, when I try to apply a block comment to some elements
in an XML file, nothing happens. If I invoke the same command using the
menu, the following exception is thrown:
org.eclipse.core.commands.NotHandledException: There is no handler to
execute for command org.eclipse.wst.sse.ui.add.block.comment
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:480)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:424)
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:165)
at
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
at
at
at
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:178)
at
org.eclipse.ui.actions.ContributedAction.runWithEvent(Contri butedAction.java:186)
at
org.eclipse.ui.internal.actions.CommandAction.run(CommandAct ion.java:192)
at
org.eclipse.ui.texteditor.RetargetTextEditorAction.run(Retar getTextEditorAction.java:237)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3673)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3284)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2365)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2329)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 04)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 480)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:419)
at org.eclipse.equinox.launcher.Main.run(Main.java:1145)
Is this a known issue?
Using Eclipse 3.3 (I20070424-0930), WTP 2 ( I200704192149), Windows XP
Adrian
FUDForum. Page generated in 0.05509 seconds
