Home » Eclipse Projects » GEF » BUG: Graphics.drawImage and Graphics.drawPoint w/ Graphics.setClip(Path path)
BUG: Graphics.drawImage and Graphics.drawPoint w/ Graphics.setClip(Path path) [message #190948] |
Sun, 07 August 2005 15:32  |
--------------050504000002080701060006
I believe I have found a bug within the Graphics class. The bug may
actually be in SWT, but since I'm working through the Draw2D Graphics
class, I thought this would be the best place to start. If need be, I
can open a bug report against SWT.
Problem:
I have a figure that needs a texture or pattern drawn on it. The
texture is defined in a GIF file and is much smaller than the figure.
To accomodate this, the image is repeatedly tiled over the figure. The
figure is irregularly shaped; defined by a PointList. I have found a
way to accomplish the task on both Linux and Windows, but it requires
two separate approaches due to inconsistencies between implementations
on each platform.
I've attached the relevant code from my Figure subclass.
The crux of the problem is that Graphics.drawImage and
Graphics.drawPoint seem to perform inconsistently on different platforms
when using Graphics.setClip(Path path).
For Windows, Graphics.drawImage honors the path such that sections of
the tiled image that are outside the path are not drawn. However,
Graphics.drawPoint doesn't seem to honor the path clip. So when you
iterate over the clip, the pixels are drawn outside the clip set. There
is a secondary problem with the Image and pulling pixels out of it, but
this is not a problem with GEF or Draw2d.
For Linux, Graphics.drawImage does not honor the path clip. The image
is tiled over the entire rectangular bounds of the image, even outside
of the path clip. Graphics.drawPoint honors the path clip so that the
pattern only appears inside the path clip.
Am I approaching the tiled image problem incorrectly, or is the
inconsistent behavior indeed a bug?
A cursory glance at GEF's bugzilla revealed this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=76571
which appears to be related. It talks about the setClip(Path path) but
not the drawing aspects.
I'd appreciate any help. If it needs to be sent on over to SWT, let me
know and I'll do that.
Josh Reed
Content-Type: text/x-java;
name="snippet.java"
Content-Disposition: inline;
filename="snippet.java"
protected void paintFigure(Graphics g) {
PointList points = getOutline();
g.setForegroundColor(ColorConstants.black);
g.setBackgroundColor(fillColor);
g.fillPolygon(points);
g.drawPolygon(points);
fillPolygon(g, points, fillPattern);
private void fillPolygon(Graphics g, PointList points, Image img) {
ImageData imgData = img.getImageData();
// get the bounds of the clip so we don't waste time
// painting the whole bounds, even parts that aren't
// visible
Rectangle r = g.getClip(new Rectangle());
// The path should be built properly because I can get it to work
// with one of the two approaches below, depending on platform.
Path p = pointListToPath(points);
g.setClip(p);
// Tile the image over the whole bounds
// Works on Windows
// Fails on Linux
// -- The pattern is not clipped to the path. It fills the whole
// rectangular region. During scrolling, the pattern moves down
// so that there are uncovered regions near the top of the diagram.
for (int y = r.y; y < r.y + r.height; y += imgData.height) {
for (int x = r.x; x < r.x + r.width; x += imgData.width) {
g.drawImage(fillPattern, new Point(x, y));
// Loop through the image data and draw out all the black pixels
// Works on Linux
// Fails on Windows
// -- The region is not clipped to the path. The whole rectangular
// region is filled with black. No non-black pixels are recognized.
int pixel = -1;
for (int y = r.y; y < r.y + r.height; y++) {
for (int x = r.x; x < r.x + r.width; x++) {
pixel = imgData.getPixel((x-r.x)%imgData.width, (y-r.y)%imgData.height);
// this is a simple hack
if (pixel == 0) {
g.drawPoint(x, y);
private Path pointListToPath(PointList points) {
Path path = new Path(null);
Point start = points.getFirstPoint();
path.moveTo(start.x, start.y);
for (int i = 1; i < points.size(); i++) {
Point p = points.getPoint(i);
path.lineTo(p.x, p.y);
if (!points.getLastPoint().equals(start)) {
path.lineTo(start.x, start.y);
path.close();
return path;
--------------050504000002080701060006--
Re: Graphics.drawImage and Graphics.drawPoint w/ Graphics.setClip(Path path) [message #191092 is a reply to message #190948] |
Mon, 08 August 2005 15:38  |
Please complete the snippet so that it is runnable and contains the minimum
needed to show the problem and attach it to a bugzilla. We will investigate
for 3.1.1 or reroute to SWT.
"Josh Reed" <jareed@iastate.edu> wrote in message
news:dd5nl9$ifb$1@news.eclipse.org...
> Problem:
> on each platform.
> Josh Reed
> // visible
> g.setClip(p);
> // Works on Windows
> // Fails on Linux
> // Works on Linux
> // Fails on Windows
> int pixel = -1;
> if (pixel == 0) {
> g.drawPoint(x, y);
> path.close();
> return path;
Current Time: Sat Jul 19 21:12:10 EDT 2025
Powered by FUDForum. Page generated in 0.05623 seconds
