Home » Newcomers » Newcomers » Automatic activation of plug-ins
Automatic activation of plug-ins [message #190954] Wed, 31 January 2007 05:22 Go to next message
Originally posted by: dirk.reinelt.mb.uni-magdeburg.de
How do I realise an automatic activation of a plug-in right after the
start of the Eclipse application?
I have created a plug-in with an editor and I have put some required steps
in the start method of the Activator class. But this will only be executed
by clicking on the editor file manually.
Is there any way to activate the plugin automatically?
Greetings
Dirk Reinelt
Re: Automatic activation of plug-ins [message #190961 is a reply to message #190954] Wed, 31 January 2007 07:27 Go to previous messageGo to next message
> steps in the start method of the Activator class. But this will only be
> executed by clicking on the editor file manually. Is there any way to
> Greetings
> Dirk Reinelt
Look here:
http://download.eclipse.org/eclipse/downloads/documentation/ 2.0/html/plugins/org.eclipse.platform.doc.isv/reference/exte nsion-points/org_eclipse_ui_startup.html
Let me know if this answers your question.
regards,
Jakub Jurkiewicz
Re: Automatic activation of plug-ins [message #191008 is a reply to message #190961] Wed, 31 January 2007 08:46 Go to previous messageGo to next message
>> Greetings
>> Dirk Reinelt
> Look here:
> regards,
> Jakub Jurkiewicz
Thanks a lot,
that works like a charm :)
The interesting fact is, that with adding this extension point to the
plug-in, the 'start' method from the Activation class is called already
and prior to the 'earlyStartup' method of the Startup class. So there is
no need for me to create such a Startup class and put all needed
functionality in the 'start' class, like I already did. :)
regards
Dirk Reinelt
Re: Automatic activation of plug-ins [message #191131 is a reply to message #191008] Wed, 31 January 2007 11:49 Go to previous message
Originally posted by: wharley.bea.com
"Dirk" <dirk.reinelt@mb.uni-magdeburg.de> wrote in message
news:6376c8877b09b566c423191a2e30f61e$1@www.eclipse.org...
>> [...early startup extension...]
Three things.
First, you should be aware that using earlyStartup is very discouraged.
It's best used when you're writing an RCP application that users will not be
extending, as opposed to when you're writing plug-ins intended to be used in
the context of Eclipse. By using earlyStartup, you're forcing users to pay
the cost of loading your plug-in (and any other plug-ins it depends on)
every time they start Eclipse for any reason. There is almost always a
better solution, even though it may involve some compromise - if you look at
how other plug-ins have solved the problem, you can get ideas.
If you say a bit more about why you think you need earlyStartup, people on
this list may be able to give you suggestions on how to avoid using it.
Second, you should NOT implement earlyStartup in your Activator class; you
should use a separate class. Doing it in the Activator can cause all sorts
of load-time problems, like endless load loops and deadlocks. Let OSGi
separate the tasks of loading your bundle and doing the earlyStartup work.
Third, try to avoid any lengthy operations (and any operations that require
calls to UI code) in your plug-in's startup() method. They may result in
the plug-in failing to load, and they will definitely interfere with Eclipse
loading.
These topics are frequently discussed here and on eclipse.platform, so you
may want to spend some time browsing the newsgroup archives before
proceeding.
Previous Topic:Redirect actions with a MultiPageEditorActionBarContributor
Next Topic:How do I combine programs from various projects?
Current Time: Sun Jul 20 13:24:36 EDT 2025
Powered by FUDForum. Page generated in 0.07348 seconds
