Home » Language IDEs » ServerTools (WTP) » Tomcat Server fails to start in profile mode.
Tomcat Server fails to start in profile mode. [message #190714] Thu, 29 March 2007 10:58 Go to next message
Hi I can't start tomcat server in profiling mode.
eclipse 3.2.2
TPTP 4.3.2
WST 1.5.3
!ENTRY org.eclipse.core.jobs 4 2 2007-03-29 10:12:55.645
!MESSAGE An internal error occurred during: "Starting server - Tomcat v5.5
Server @ localhost".
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 0
at
org.eclipse.jst.server.tomcat.core.internal.TomcatLaunchConf igurationDelegate.launch(TomcatLaunchConfigurationDelegate.j ava:68)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:558)
at org.eclipse.wst.server.core.internal.Server.start(Server.jav a:1229)
at
org.eclipse.wst.server.core.internal.Server.synchronousStart (Server.java:1614)
at
org.eclipse.wst.server.core.internal.StartServerJob.run(Star tServerJob.java:34)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
I can't get the command line parameters if I runt the server as profiling
mode.
Running the server as non profiling mode
"C:\Program Files\Java\jre1.5.0_06\bin\javaw.exe"
-XrunpiAgent:server=enabled
-Dcatalina.base=C:\workspace\.metadata\.plugins\org.eclipse. wst.server.core\tmp0
"-Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 5.5"
"-Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat
5.5\common\endorsed"
-classpath "C:\Program Files\Apache Software Foundation\Tomcat
5.5\bin\bootstrap.jar" org.apache.catalina.startup.Bootstrap start
Please help, thanks
Re: Tomcat Server fails to start in profile mode. [message #190722 is a reply to message #190714] Thu, 29 March 2007 11:41 Go to previous messageGo to next message
This looks like the error you get when Profile on Server is run without
TPTP being installed. Assuming some of TPTP is working, you might try
starting your Eclipse with "-clean -debug" arguments included and
examine the Error Log view for TPTP bundles that aren't resolving due to
missing requirements.
Larry
> eclipse 3.2.2
> TPTP 4.3.2
> WST 1.5.3
> v5.5 Server @ localhost".
> !STACK 0
> at
> at
> at
> at
> at
> at
> profiling mode.
> Please help, thanks
Re: Tomcat Server fails to start in profile mode. [message #190729 is a reply to message #190722] Thu, 29 March 2007 11:59 Go to previous messageGo to next message
Forgot to mention that after you get Tomcat starting, you will still
have problems due to Bug 174863, you will still have problems. The fix
is currently in the approval process for WTP 1.5.4. This issue is
already fixed for Eclipse 3.3M6/ WTP 2.0M6. If you aren't ready to try
M6, you will have to drop back to WTP 1.5.2 or grab the SDK version of
TPTP and apply a simple fix to the
org.eclipse.tptp.platform.profile.server.wst plug-in.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=174863
> Cheers,
> Larry
>> eclipse 3.2.2
>> TPTP 4.3.2
>> WST 1.5.3
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> profiling mode.
>> 5.5" "-Djava.endorsed.dirs=C:\Program Files\Apache Software
>> Foundation\Tomcat 5.5\common\endorsed"
>> Please help, thanks
Re: Tomcat Server fails to start in profile mode. [message #190753 is a reply to message #190729] Thu, 29 March 2007 14:08 Go to previous messageGo to next message
Thanks Larry, I have done that and I don't see any errors. I can profile
java application(does that mean I don't have problem with TPTP), but I
would like to profile a web application.
I have tried all kind of stuff(reinstalling TPTP, eclipse, tomcat, Passing
different argument to the VM etc), but all in vain.
I keep getting
"An internal errror occured during "Starting server-Tomcat v5.5 Server @
localhost""
Re: Tomcat Server fails to start in profile mode. [message #190760 is a reply to message #190753] Thu, 29 March 2007 14:56 Go to previous message
Assuming you get past the ArrayIndexOutOfBoundsException, a second easy
way to to cause this error is not to have the piAgent library available
to the launch configuration. If not available, you will see something
like the following in the Console view:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: piAgent
You can look in Bug 174863[1] for the steps I use to make it available
if you encounter this problem.
Larry
> profile java application(does that mean I don't have problem with TPTP),
> but I would like to profile a web application.
> Passing different argument to the VM etc), but all in vain.
> I keep getting
> @ localhost""
Previous Topic:old project not "Dynamic"
Next Topic:SSE & XML Catalog binding
Current Time: Sat Jul 19 12:44:01 EDT 2025
Powered by FUDForum. Page generated in 0.03658 seconds
