Home » Language IDEs » ServerTools (WTP) » JSP validation and Struts tags
JSP validation and Struts tags [message #189381] Wed, 07 March 2007 09:47 Go to next message
I use WTP to develop a struts application.
I often use the bean:define tag that creates a reference with an object in
any scope.
for exemple :
<bean:define id="foo" name="fooKey" type="java.lang.String" />
<% foo = "another foo" %>
This works as the bean:define tag actually creates a foo reference in the
page scope.
The problem is that the WTp JSP validator issues an error with "foo can
not be resolved".
Does anyone have an idea of how to avoid this error ?
Re: JSP validation and Struts tags [message #189575 is a reply to message #189381] Sun, 11 March 2007 06:17 Go to previous messageGo to next message
> not be resolved".
I have this same problem, its with a custom tag I wrote my own, but it
actually is with any tag.
Example, of my JSP:
<dh:mytag id="myvar" .../>
then in my JSP after the tag I put the snippet
<%= myvar %>
the code actually WORKS, but the JSP editor in eclipse says theres an error:
cannot resolve "myvar"
My eclipse version is:
Version: 3.2.2
Build id: M20070212-1330
Web Standard Tools - Web Core
Version: 1.5.3.v200701251933--4hNDDhFfKVFaSL
Build id: 200702082048
Re: JSP validation and Struts tags [message #189611 is a reply to message #189575] Mon, 12 March 2007 05:53 Go to previous messageGo to next message
>> not be resolved".
> Example, of my JSP:
> <%= myvar %>
In both of these cases a TagExtraInfo class needs to be declared
that returns information stating that the id/name attributes end up
creating local Java variables along with the correct scopes. The
JSP editor will attempt to load that class and talk to it, but it
has limitations when doing so, among them that the VM running
Eclipse must be able to read the class file--no running Eclipse with
1.4 and using a tag library compiled for 1.5.
Nitin Dahyabhai
Structured Source Editor
Re: JSP validation and Struts tags [message #189789 is a reply to message #189611] Thu, 15 March 2007 04:41 Go to previous messageGo to next message
Originally posted by: nomail.xxxxxxxx.com
I doesnt depend on the JVM version.
I tested this on another IDE with JVM 1.4 and it works correctly.
I think it's some sort of bug or misconfiguration of Eclipse WTP.
Re: JSP validation and Struts tags [message #190064 is a reply to message #189381] Sat, 17 March 2007 11:32 Go to previous messageGo to next message
no one knows ?
Re: JSP validation and Struts tags [message #190217 is a reply to message #189789] Tue, 20 March 2007 22:36 Go to previous messageGo to next message
Actually, in WTP it does depend on the JVM version somewhat--I can't
tell you how other IDEs manage it. Glamoute, is your project's
directory directly under the workspace folder or is it elsewhere?
You might be affected by bug 178443.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178443
Nitin Dahyabhai
Re: JSP validation and Struts tags [message #190524 is a reply to message #190217] Wed, 28 March 2007 03:38 Go to previous message
nevertheless it is a bug, since the wtp jsp editor reports an error
whereas the code acually works correctly.
thank you
Previous Topic:Dali plugin (JPA)
Next Topic:No editor descriptor for id
Current Time: Sat Jul 19 21:16:53 EDT 2025
Powered by FUDForum. Page generated in 0.24350 seconds
