Home » Eclipse Projects » GEF » bug in DragEditPartsTracker?
bug in DragEditPartsTracker? [message #190461] Wed, 03 August 2005 19:45 Go to next message
I stumbled across what looks like a problem in DragEditPartsTracker. It
only happens when the grid is visible.
To reproduce the problem in the Logic example, modify
LogicXYLayoutEditPolicy.createChildEditPolicy(). Right after the policy
is created, add the line
policy.setDragAllowed(false);
Now try dragging an element in the Logic editor; you should encounter a
NullPointerEx in DragEditPartsTracker.updateTargetRequest().
With the SnapToHelper enabled, the drag tracker tries to use the
variable 'compoundSrcRect'. This variable is set based on any selected
editparts that understand the move request. However, the
setDragAllowed(false) call means that the editpolicy doesn't understand
the request, so the variable in question is never set.
Re: bug in DragEditPartsTracker? [message #190546 is a reply to message #190461] Thu, 04 August 2005 11:58 Go to previous message
Originally posted by: none.unknown.com
Seems like a genuine bug. Please open a bug report (and attach a patch if
you'd like to contribute to GEF).
"Thuc" <tqnguyen@ca.ibm.com> wrote in message
news:dcrku6$rtd$1@news.eclipse.org...
Previous Topic:Adding ruler to Canvas!!!
Next Topic:Problem with command line update manager
Current Time: Sat Jul 19 21:15:03 EDT 2025
Powered by FUDForum. Page generated in 0.03033 seconds
