Home » Language IDEs » ServerTools (WTP) » xml Error processing dirty region
xml Error processing dirty region [message #190381] Fri, 23 March 2007 12:37 Go to next message
Any time I edit an xml file, I get this error message:
java.lang.IncompatibleClassChangeError: Class
org.apache.xerces.parsers.SAXParser does not implement the requested
interface org.xml.sax.XMLReader
... org.eclipse.wst.sse.ui.internal.reconcile.DirtyRegionProcess or.run(DirtyRegionProcessor.java:636)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
pllugin: org.wst.xml.core feature
Version: 1.5.3.v200701251933--3YIAAaBNHFDQIR
Build id: 200702082048
Should I upgrade a feature or else?
Re: xml Error processing dirty region [message #190395 is a reply to message #190381] Fri, 23 March 2007 17:33 Go to previous message
Check your JRE or JDK's lib/ext directory to see if there any extra
jars there such as another version of Xerces. This would interfere
with the version provided for use with WTP.
Nitin Dahyabhai
Structured Source Editor
Previous Topic:Looking for Simple Eclipse-WTP JSP Tutorial
Next Topic:removing a jar
Current Time: Sat Jul 19 22:04:57 EDT 2025
Powered by FUDForum. Page generated in 0.04359 seconds
