Home » Language IDEs » ServerTools (WTP) » Content assist not consistently working in detail pane and display view during debugging.
Content assist not consistently working in detail pane and display view during debugging. [message #190117] Mon, 19 March 2007 21:09 Go to next message
--------------030500040203010504030403
I pasted below a copy of a short thread in the eclipse.platform list. It
was suggested that I file a bug report about the content assist problem
in the detail pane. I attached the attachment that reproduced this behavior.
Should I do that or am I doing something wrong?
Shahim
> Reproduced.
> I believe its webtools issue, and you should fulfill a bug report https://bugs.eclipse.org/bugs/.
> Chris
> I attached a zip of a dynamic web project (and a war file exported from that project) that I just tried. It has one servlet that has a url of /TestContentAssist/TestCA
> I created this project quickly without changing any of the default settings for a dynamic web project.
> I put a breakpoint on line 26 of TestCA.java and launched my debug server (Tomcat 5.5). In the debug view, if I highlight the request object or one of its children and try to use content assist in the detail pane I get a beep. Same thing in the display view.
> I can execute code typed in without using the content assist. The content assist sub menu in the edit menu is all grayed out.
> Eclipse SDK
> Version: 3.2.2
> Build id: M20070212-1330
> Does this help?
> Do you need my eclipse configuration? (I wasn't sure if the configuration details have any private information that I need to be careful about.)
> Let me know what else you need.
> Thanks Chris,
> Shahim
> Krzysztof Daniel wrote:
>> It would be nice if you could provide reproduction steps...
>> Chris
Content-Type: application/x-zip-compressed;
name="TestContentAssist.zip"
Content-Disposition: inline;
filename="TestContentAssist.zip"
UEsDBBQAAAAAAMZdcDYlHuMsBgoAAAYKAAAVAAAAVGVzdENvbnRlbnRBc3Np c3Qud2FyUEsD
BBQACAAIAMVdcDYAAAAAAAAAAAAAAAAUAAAATUVUQS1JTkYvTUFOSUZFU1Qu TUbzTczLTEst
LtENSy0qzszPs1Iw1DPg5XLOSSwu1g1ILMmwUuDl4uUCAFBLBwjimG3WKQAA ACcAAABQSwME
FAAIAAgAS1twNgAAAAAAAAAAAAAAAAkAAABNRVRBLUlORi8DAFBLBwgAAAAA AgAAAAAAAABQ
SwMEFAAIAAgASltwNgAAAAAAAAAAAAAAAAgAAABXRUItSU5GLwMAUEsHCAAA AAACAAAAAAAA
AFBLAwQUAAgACABzW3A2AAAAAAAAAAAAAAAADwAAAFdFQi1JTkYvd2ViLnht bJWS0U/CMBDG
nzXxf1j63hYmD4ZsEKIxMcEnMfq2lO2Akq5rdoXN/96OsbmBEXxrvv7u++4u F0zLVHl7yFFm
OiRDNiAe6DhLpF6H5H3xTB/IdHJ3GxSwpMIYTyYh+YDlzJjo5Yn8VPpsRDzn pTEkG2vNmPOt
2AuGO83iLOXui2vkWx/gyI1LlC1bFAUr7lmWr7k/GAz55+v8Ld5AKqjUaIWO qyqUYzyI8ywW
9hB7Icq78M+PY0V+NGIlJsSNehMkEo0SX1SLFCphAWgfM21B2xmiRBvwUyRA yPcKbPV2BoBx
Lk3VYi3wM+XUoA6ZnTu31rXSYD2xh8VKIB4kNywDRCETdlrWQq3UnYKmbifu Av6Vv8sVNcJa
yPWEN1hX7KZ1E9xtKdcq0JVUQJXbb23YlSdSJ1CyjU1VwHsff6BXkls0F8kE VmKn7HUNdOCr
2V+b6CvNaoLmat37G1BLBwiUrvTwWQEAAMADAABQSwMEFAAIAAgA1VtwNgAA AAAAAAAAAAAA
ACcAAABXRUItSU5GL2NsYXNzZXMvY29tL2Vzc2FpZC9UZXN0Q0EuY2xhc3ON Ul1PE1EQPdNu
e9tlFSgWFBQBPyho3BgfazCG+BU3SijhfWlv6DXbvXX3luDP0gdJeOAH+KMM c3eXWsWID3tn
7syZMzNn74+fp2cAnuKxQIkw29UDX6ZpqHr+nkzN9ksBh7D8KTwKj/1UJkeR NH7fmKH/lo9O
HhCoEpq/Y4oUofpcxcpsEcqtjX2Cs6170kUZUx4EaoTpQMXyw2hwIJO98CCS hEagu2G0HybK
3ougY/oqJcwFlyZsEyo9/cb22m0F/550V34ecVH7Slg61HEq23Zi99VxVw6N 4oDAjUtiFCVj
kMA8j2kxvtL+u4/jRB03sShwizCTZaMwPvQ7X1IjBx6WcJsV0iNeohlcFO8k KjYdk8hw0K5h
mffsyyjSLlawJrA60WYC6eEe7hPE0IaimPlyUYp+hsOH2V4iycUgrP+naoRa UihDuFrqQkN+
Aj29o20jt6NHSVe+VvaPTuW/74mlwSp4ff4q/Bit5afBZ51vz9gS28rmCdyv 7JTg8emyBWbh
oIFr7Hk5CNcxzdbBDOdKnAOqbOfQzMjes19mW/+Ghcad77j7J+Ei913KCFdy YEFovQd4mDWp
Yx0tRjvY+GuTF9kOAP0ir2aFaxPENCamMTEVxITNrPLROVBLBwgtpJ843AEA AJ4DAABQSwME
FAAIAAgA1VtwNgAAAAAAAAAAAAAAACYAAABXRUItSU5GL2NsYXNzZXMvY29t L2Vzc2FpZC9U
ZXN0Q0EuamF2YbVSTU/DMAw9t1L/gzUuXbWld3ZhAsTHZYjtD2StWQttHBJ3 DKH9d9KlE2Mg
DWmjSuNIfvZ7eraW2YtcIGRUC7RWlvkoCqOwrDUZhme5lKIkcTe5XmWouSQ1 +pZcCYtmWSGL
qY8HcQWzFrfu6goe8bVBy3+HW03K4kZlmiRRCAl0OXAdKqxRsWwVQFZJa+GJ zBZwDjNHdTlu
i9o/dZdu5lWZdVifBlwxqtwekPJFt4/cAj5cf/elCcSK1PDegYY5Zf0oDJzq C4t4gOJs5x37
Mqc56DR7tXG/5QkC22g0cd8ZE6wdaeCiO0dw53TjWH+OCoyPA/hlLi7pHztq DTFmjDksqczh
yLbAhaE3C/v7NoCdJfWOpCnMJlcTGDdMwwUqNLJVUSMXlIPlZu7nA7CN03fL WAtqWGhTKq5U
3Cuwqqi39fUUtj6Q/Rdfj+t7YmP9Em5O6+/6E1BLBwi/GSi1VgEAAGkEAABQ SwMEFAAIAAgA
SltwNgAAAAAAAAAAAAAAAAwAAABXRUItSU5GL2xpYi8DAFBLBwgAAAAAAgAA AAAAAABQSwME
FAAIAAgAc1twNgAAAAAAAAAAAAAAABQAAABXRUItSU5GL2NsYXNzZXMvY29t LwMAUEsHCAAA
AAACAAAAAAAAAFBLAwQUAAgACABzW3A2AAAAAAAAAAAAAAAAGwAAAFdFQi1J TkYvY2xhc3Nl
cy9jb20vZXNzYWlkLwMAUEsHCAAAAAACAAAAAAAAAFBLAwQUAAgACABzW3A2 AAAAAAAAAAAA
AAAAEAAAAFdFQi1JTkYvY2xhc3Nlcy8DAFBLBwgAAAAAAgAAAAAAAABQSwEC FAAUAAgACADF
XXA24pht1ikAAAAnAAAAFAAAAAAAAAAAAAAAAAAAAAAATUVUQS1JTkYvTUFO SUZFU1QuTUZQ
SwECFAAUAAgACABLW3A2AAAAAAIAAAAAAAAACQAAAAAAAAAAAAAAAABrAAAA TUVUQS1JTkYv
UEsBAhQAFAAIAAgASltwNgAAAAACAAAAAAAAAAgAAAAAAAAAAAAAAAAApAAA AFdFQi1JTkYv
UEsBAhQAFAAIAAgAc1twNpSu9PBZAQAAwAMAAA8AAAAAAAAAAAAAAAAA3AAA AFdFQi1JTkYv
d2ViLnhtbFBLAQIUABQACAAIANVbcDYtpJ843AEAAJ4DAAAnAAAAAAAAAAAA AAAAAHICAABX
RUItSU5GL2NsYXNzZXMvY29tL2Vzc2FpZC9UZXN0Q0EuY2xhc3NQSwECFAAU AAgACADVW3A2
vxkotVYBAABpBAAAJgAAAAAAAAAAAAAAAACjBAAAV0VCLUlORi9jbGFzc2Vz L2NvbS9lc3Nh
aWQvVGVzdENBLmphdmFQSwECFAAUAAgACABKW3A2AAAAAAIAAAAAAAAADAAA AAAAAAAAAAAA
AABNBgAAV0VCLUlORi9saWIvUEsBAhQAFAAIAAgAc1twNgAAAAACAAAAAAAA ABQAAAAAAAAA
AAAAAAAAiQYAAFdFQi1JTkYvY2xhc3Nlcy9jb20vUEsBAhQAFAAIAAgAc1tw NgAAAAACAAAA
AAAAABsAAAAAAAAAAAAAAAAAzQYAAFdFQi1JTkYvY2xhc3Nlcy9jb20vZXNz YWlkL1BLAQIU
ABQACAAIAHNbcDYAAAAAAgAAAAAAAAAQAAAAAAAAAAAAAAAAABgHAABXRUIt SU5GL2NsYXNz
ZXMvUEsFBgAAAAAKAAoAmAIAAFgHAAAAAFBLAwQUAAAACABNW3A28mjs6vYA AAANAgAAHAAA
AFRlc3RDb250ZW50QXNzaXN0Ly5jbGFzc3BhdGidkU1LAzEQhs8K/oeQu4kK BQ9bS9EKVqxQ
V6+STYZtanayTCbV/nvX1bIi1EMvYT6emXlnUkw+miA2QMlHHMtzdSYFoI3O Yz2Wz+Xt6aWc
XJ0cFzaYlFrDq845GjxApq148+jGMpGV4iv4ber9pI24IyPVCmzwbQK1dqyC yWhX3XQ1X85e
rx8X5fRuMVvqv5xHBkITlIMq1yr7n0og9cQGnSH38lBuW9Dzm/tDtCRWCai7 jLKRoHuQjUcg
vYfi2FjDijKyb6A0VAPraWs6SaLsc2IzUqMDpawvAIad36EaBP3XMWZuM++a VtkHp3sQUl9W
6N//+glQSwMEFAAAAAgAS1twNnSNiWgTAQAAXgMAABoAAABUZXN0Q29udGVu dEFzc2lzdC8u
cHJvamVjdL1TwU4DIRA9a+I/NHsX9OaBbmO27cGkXqwfQGG6UhdmA+zWzxco q900JmtivL33
Mm/ewABbfOhm1oN1Cs28uCd3xQyMQKlMPS9et+vbh2JR3lyz1uIBhF+CE1a1 PlQH9YoZrqHc
gvMVGg/GPzqnnGc06bFAoNZBLxkdUFRzN5cIHbFdpxr50oKILNMqWLmRScmZ aGsColGtA3KQ
ngi0AfCeJwPY7xGCg9u6i9kuczoWGL1ImZR7dDFXazQkH4HsuYA8zD8P0vNG SR4Xcwb/ZIas
DDsJ8b6zkKtP5BfXcjLEiZLxpyajnU70nAVrlF0DqcEmwSrA54nRoMkR7fsu fIQ38hTyV5v1
pXfA8SK+3vD4f3wCUEsDBBQAAAAIAEtbcDZMpvXylQAAAEoBAAA2AAAAVGVz dENvbnRlbnRB
c3Npc3QvLnNldHRpbmdzL29yZy5lY2xpcHNlLmpkdC5jb3JlLnByZWZzlY69 CoMwAIR3wXcI
dA8mUAuCWyl0KDj0BVI9JSV/XGKfvy7Otctxw/dxd7rRioehUK1QqtNtpxsx XJ9CN82lrjA6
mzJkImYQYUSWHzDbGHpVV5GL3JH3VOQYiS18sg7cyoQFQRbDBWVwpsyRvlfy /Nv0yVmzzR2h
E+PLwUuTM1juE0KxswV7kJFHbYTV/+vmuHL/+AVQSwMEFAAAAAgATVtwNo4b 1iXnAAAAZAEA
AEsAAABUZXN0Q29udGVudEFzc2lzdC8uc2V0dGluZ3Mvb3JnLmVjbGlwc2Uu anN0LmNvbW1v
bi5wcm9qZWN0LmZhY2V0LmNvcmUucHJlZnOFjkFLw0AQRu+B/IcF79MkNBUW eii2gpVWqcHT
gkw3Y7Ih3SyzmxT/vVtRFD14mcu87/GubtmIHbLIFyLPZbGQxVw8ritRZNl1 mugevXcYWmip
d8SzgRsg3RvnCbo6QI+j1a2xDWwPm5ebh321uttvDkoq+Rs1NhBb7KGm49jA aD7HxPAU0NbI
9fOuenN0GW/X97PhbIn9svMBOpxQyRKy/5Ii64mn6NQDUzw2oImaP0HfYBhO GgPwaIM5UYXc
ULjgK4cxTonq46/EVEL5s+lMRyULmKfJl9QxvRKT1eQhmr0Z7DJPk3dQSwME FAAAAAgATFtw
Nrxh5uzZAAAApgEAADwAAABUZXN0Q29udGVudEFzc2lzdC8uc2V0dGluZ3Mv b3JnLmVjbGlw
c2Uud3N0LmNvbW1vbi5jb21wb25lbnR9kEFPwzAMhe9I/IfI91A4IHFYmWBi 0i6chnZOE4tl
SuModsr27+natULTxM223vf87MXy2AbVYWZPsYanh0dQGC05H79r+Nqu9Qss X+/vFinTAa3o
llwJyMq7GsZ6RRk3DtSk+GP23Nud4Z/mwimHKdBJR9NiDVtkWVEUjPLG7Fkm cUamku0sT0b2
NVSgxvHU77C54FD9T+4+3vXmc13ZYJiRr40429GhvyFhlpMaA9qz+1F0JhJQ nQnlZupb6MF0
RlORVGTYMuNN8cHNQQa0mv8zdFev7me/UEsDBBQAAAAIAE1bcDZ0LswKlQAA AA0BAABJAAAA
VGVzdENvbnRlbnRBc3Npc3QvLnNldHRpbmdzL29yZy5lY2xpcHNlLndzdC5j b21tb24ucHJv
amVjdC5mYWNldC5jb3JlLnhtbH2PzQ6CMBCE7ya+w2bvFDWSeGglXnwCfIC1 LFrSHwIVeXwR
YzgQvc58M5mR+eAs9Nx2JniFW7FBYK9DafxN4aU4JwfMj+uVrEhz5DJp2lCz jqMEINuHj8Yx
eHKs8NSQvjMUwWmK0Gciw/TDVWbgEqYKhXUXxZOvP72aevqaxneRrF2G58k7 sf9LT3Uzno0P
37hMl49eUEsDBBQAAAAIANZbcDYtpJ843AEAAJ4DAAA3AAAAVGVzdENvbnRl bnRBc3Npc3Qv
YnVpbGQvY2xhc3Nlcy9jb20vZXNzYWlkL1Rlc3RDQS5jbGFzc41SXU8TURA9 025722UVKBYU
FAE/KGjcGB9rMIb4FTdKKOF9aW/oNdu9dfeW4M/SB0l44Af4owxzd5daxYgP e2fuzJkzM2fv
j5+nZwCe4rFAiTDb1QNfpmmoev6eTM32SwGHsPwpPAqP/VQmR5E0ft+Yof+W j04eEKgSmr9j
ihSh+lzFymwRyq2NfYKzrXvSRRlTHgRqhOlAxfLDaHAgk73wIJKERqC7YbQf Jsrei6Bj+iol
zAWXJmwTKj39xvbabQX/nnRXfh5xUftKWDrUcSrbdmL31XFXDo3igMCNS2IU JWOQwDyPaTG+
0v67j+NEHTexKHCLMJNlozA+9DtfUiMHHpZwmxXSI16iGVwU7yQqNh2TyHDQ rmGZ9+zLKNIu
VrAmsDrRZgLp4R7uE8TQhqKY+XJRin6Gw4fZXiLJxSCs/6dqhFpSKEO4WupC Q34CPb2jbSO3
o0dJV75W9o9O5b/viaXBKnh9/ir8GK3lp8FnnW/P2BLbyuYJ3K/slODx6bIF ZuGggWvseTkI
1zHN1sEM50qcA6ps59DMyN6zX2Zb/4aFxp3vuPsn4SL3XcoIV3JgQWi9B3iY NaljHS1GO9j4
a5MX2Q4A/SKvZoVrE8Q0JqYxMRXEhM2s8tE5UEsDBBQAAAAIANZbcDa/GSi1 VgEAAGkEAAAs
AAAAVGVzdENvbnRlbnRBc3Npc3Qvc3JjL2NvbS9lc3NhaWQvVGVzdENBLmph dmG1Uk1PwzAM
PbdS/4M1Ll21pXd2YQLEx2WI7Q9krVkLbRwSdwyh/XfSpRNjIA1po0rjSH72 e3q2ltmLXCBk
VAu0Vpb5KAqjsKw1GYZnuZSiJHE3uV5lqLkkNfqWXAmLZlkhi6mPB3EFsxa3 7uoKHvG1Qct/
h1tNyuJGZZokUQgJdDlwHSqsUbFsFUBWSWvhicwWcA4zR3U5bovaP3WXbuZV mXVYnwZcMarc
HpDyRbeP3AI+XH/3pQnEitTw3oGGOWX9KAyc6guLeIDibOcd+zKnOeg0e7Vx v+UJAttoNHHf
GROsHWngojtHcOd041h/jgqMjwP4ZS4u6R87ag0xZow5LKnM4ci2wIWhNwv7 +zaAnSX1jqQp
zCZXExg3TMMFKjSyVVEjF5SD5Wbu5wOwjdN3y1gLalhoUyquVNwrsKqot/X1 FLY+kP0XX4/r
e2Jj/RJuTuvv+hNQSwMEFAAAAAAATFtwNuKYbdYnAAAAJwAAADEAAABUZXN0 Q29udGVudEFz
c2lzdC9XZWJDb250ZW50L01FVEEtSU5GL01BTklGRVNULk1GTWFuaWZlc3Qt VmVyc2lvbjog
MS4wDQpDbGFzcy1QYXRoOiANCg0KUEsDBBQAAAAIAHRbcDaUrvTwWQEAAMAD AAAsAAAAVGVz
dENvbnRlbnRBc3Npc3QvV2ViQ29udGVudC9XRUItSU5GL3dlYi54bWyVktFP wjAQxp818X9Y
+t4WJg+GbBCiMTHBJzH6tpTtgJKua3aFzf/ejrG5gRF8a77+7vvuLhdMy1R5 e8hRZjokQzYg
Hug4S6Reh+R98UwfyHRydxsUsKTCGE8mIfmA5cyY6OWJ/FT6bEQ856UxJBtr zZjzrdgLhjvN
4izl7otr5Fsf4MiNS5QtWxQFK+5Zlq+5PxgM+efr/C3eQCqo1GiFjqsqlGM8 iPMsFvYQeyHK
u/DPj2NFfjRiJSbEjXoTJBKNEl9UixQqYQFoHzNtQdsZokQb8FMkQMj3Cmz1 dgaAcS5N1WIt
8DPl1KAOmZ07t9a10mA9sYfFSiAeJDcsA0QhE3Za1kKt1J2Cpm4n7gL+lb/L FTXCWsj1hDdY
V+ymdRPcbSnXKtCVVECV229t2JUnUidQso1NVcB7H3+gV5JbNBfJBFZip+x1 DXTgq9lfm+gr
zWqC5mrd+xtQSwECFAAUAAAAAADGXXA2JR7jLAYKAAAGCgAAFQAAAAAAAAAB ACAAAAAAAAAA
VGVzdENvbnRlbnRBc3Npc3Qud2FyUEsBAhQAFAAAAAgATVtwNvJo7Or2AAAA DQIAABwAAAAA
AAAAAQAgAAAAOQoAAFRlc3RDb250ZW50QXNzaXN0Ly5jbGFzc3BhdGhQSwEC FAAUAAAACABL
W3A2dI2JaBMBAABeAwAAGgAAAAAAAAABACAAAABpCwAAVGVzdENvbnRlbnRB c3Npc3QvLnBy
b2plY3RQSwECFAAUAAAACABLW3A2TKb18pUAAABKAQAANgAAAAAAAAABACAA AAC0DAAAVGVz
dENvbnRlbnRBc3Npc3QvLnNldHRpbmdzL29yZy5lY2xpcHNlLmpkdC5jb3Jl LnByZWZzUEsB
AhQAFAAAAAgATVtwNo4b1iXnAAAAZAEAAEsAAAAAAAAAAQAgAAAAnQ0AAFRl c3RDb250ZW50
QXNzaXN0Ly5zZXR0aW5ncy9vcmcuZWNsaXBzZS5qc3QuY29tbW9uLnByb2pl Y3QuZmFjZXQu
Y29yZS5wcmVmc1BLAQIUABQAAAAIAExbcDa8Yebs2QAAAKYBAAA8AAAAAAAA AAEAIAAAAO0O
AABUZXN0Q29udGVudEFzc2lzdC8uc2V0dGluZ3Mvb3JnLmVjbGlwc2Uud3N0 LmNvbW1vbi5j
b21wb25lbnRQSwECFAAUAAAACABNW3A2dC7MCpUAAAANAQAASQAAAAAAAAAB ACAAAAAgEAAA
amVjdC5mYWNldC5jb3JlLnhtbFBLAQIUABQAAAAIANZbcDYtpJ843AEAAJ4D AAA3AAAAAAAA
AAEAIAAAABwRAABUZXN0Q29udGVudEFzc2lzdC9idWlsZC9jbGFzc2VzL2Nv bS9lc3NhaWQv
VGVzdENBLmNsYXNzUEsBAhQAFAAAAAgA1ltwNr8ZKLVWAQAAaQQAACwAAAAA AAAAAQAgAAAA
TRMAAFRlc3RDb250ZW50QXNzaXN0L3NyYy9jb20vZXNzYWlkL1Rlc3RDQS5q YXZhUEsBAhQA
FAAAAAAATFtwNuKYbdYnAAAAJwAAADEAAAAAAAAAAQAgAAAA7RQAAFRlc3RD b250ZW50QXNz
aXN0L1dlYkNvbnRlbnQvTUVUQS1JTkYvTUFOSUZFU1QuTUZQSwECFAAUAAAA CAB0W3A2lK70
8FkBAADAAwAALAAAAAAAAAABACAAAABjFQAAVGVzdENvbnRlbnRBc3Npc3Qv V2ViQ29udGVu
dC9XRUItSU5GL3dlYi54bWxQSwUGAAAAAAsACwALBAAABhcAAAAA
--------------030500040203010504030403--
Re: Content assist not consistently working in detail pane and display view during debugging. [message #190127 is a reply to message #190117] Mon, 19 March 2007 21:18 Go to previous messageGo to next message
On Windows XP and java build 1.5.0_11-b03
> behavior.
> Shahim
>> Reproduced.
>> Chris
>> Eclipse SDK
>> Version: 3.2.2
>> Does this help?
>> careful about.)
>> Thanks Chris,
>> Shahim
>>> Chris
Version: 1.5.3.v200701251935-X3Tn7ug44nfs8AE__Re: Content assist not consistently working in detail [message #190136 is a reply to message #190127] Mon, 19 March 2007 21:22 Go to previous message
Web Standard Tools
Build id: 200606281211
>> It was suggested that I file a bug report about the content assist
>> problem in the detail pane. I attached the attachment that reproduced
>> this behavior.
>> Thanks,
>> Shahim
>>> Reproduced.
>>> Chris
>>> Eclipse SDK
>>> Version: 3.2.2
>>> Does this help?
>>> careful about.)
>>> Thanks Chris,
>>> Shahim
>>>> Chris
Previous Topic:servlet api docs/sources
Next Topic:Processing/filtering resources when deploying
Current Time: Sat Jul 19 07:09:33 EDT 2025
Powered by FUDForum. Page generated in 0.03452 seconds
