Home » Language IDEs » ServerTools (WTP) » Problem creating simple Session Bean under Eclipse 3.2.2
Problem creating simple Session Bean under Eclipse 3.2.2 [message #189527] |
Fri, 09 March 2007 18:22  |
Originally posted by: kmg.NOSPAM_merseymail.com
I have created an EJB project in Eclipse 3.2.2 and now want to
generate a simple Session Bean. I have created and EJB Module and I then
tried to create an EJB bean by right-clicking the module, and trying to
select New->Other->EJB Bean. Except there was no EJB Bean option to
select! The only options I have are 'EJB Project' (which doesn't make
sense as I have done this already) and 'XDoclet Enterpreise JavaBean '.
This is at odds with the tutorial here:
http://www.eclipse.org/webtools/community/tutorials/ejbtutor ial/buildingejbs.html
and so I am now confused and concerned that my installation is incorrect.
I'd be grateful if anyone can point me in the right direction.
I am running Eclipse 3.2.2 and my configuration is as follows:
*** Date: Fri Mar 09 23:22:08 GMT 2007
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
catalina.base=/C:/eclipse/plugins/org.eclipse.tomcat_4.1.130 .v20060601/
catalina.home=/C:/eclipse/plugins/org.eclipse.tomcat_4.1.130 .v20060601/
catalina.useNaming=true
eclipse.buildId=M20070212-1330
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
1c0_50
-vmC:\Sun\AppServer\jdk\bin\javaw.exe
-clean
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1173480405234
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\Program Files\Java\j2re1.4.2_03\lib\endorsed
java.ext.dirs=C:\Program Files\Java\j2re1.4.2_03\lib\ext
java.home=C:\Program Files\Java\j2re1.4.2_03
java.io.tmpdir=C:\DOCUME~1\kmg\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;c:\sun\appserver\jdk\jre;C:\XEClient\bin;C:\oracl exe\app\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32 ;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\ATI Technologies\ATI Control Panel;C:\PHP;C:\Program
Files\QuickTime\QTSystem\;C:\Sun\AppServer\bin;C:\Sun\AppSer ver\lib\ant\bin\;
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_03-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_03
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_03-b02
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,javax.imageio.metadata,javax.imageio .plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.n aming,javax.naming.directory,javax.naming.event,javax.naming .ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,j avax.print.attribute,javax.print.attribute.standard,javax.pr int.event,javax.rmi,javax.rmi.CORBA,javax.security.auth,java x.security.auth.callback,javax.security.auth.kerberos,javax. security.auth.login,javax.security.auth.spi,javax.security.a uth.x500,javax.security.cert,javax.sound.midi,javax.sound.mi di.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parse
r,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,jav ax.transaction,javax.transaction.xa,javax.xml.parsers,javax. xml.transform,javax.xml.transform.dom,javax.xml.transform.sa x,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingConte
xt,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax .ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.clean=true
osgi.configuration.area=file:/C:/eclipse/configuration/
osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.2 .2.R32x_v20070118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/C:/eclipse/
osgi.instance.area=file:/C:/javadev/eclipse33workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/kmg/workspace/
osgi.logfile=C:\javadev\eclipse33workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\eclipse\plugins\org.eclipse.platform_ 3.2.2.r322_v20070117b\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\j2re1.4.2_03\lib\rt.jar;C:\Program
Files\Java\j2re1.4.2_03\lib\i18n.jar;C:\Program
Files\Java\j2re1.4.2_03\lib\sunrsasign.jar;C:\Program
Files\Java\j2re1.4.2_03\lib\jsse.jar;C:\Program
Files\Java\j2re1.4.2_03\lib\jce.jar;C:\Program
Files\Java\j2re1.4.2_03\lib\charsets.jar;C:\Program
Files\Java\j2re1.4.2_03\classes
sun.boot.library.path=C:\Program Files\Java\j2re1.4.2_03\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipse
user.home=C:\Documents and Settings\kmg
user.language=en
user.name=kmg
user.timezone=Europe/London
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.2.2.v200702131851) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data
Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.2.1.v200702131851) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.2.1.v200702131851) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.source (2.2.2.v200702131851) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.2.2.v20070208) "Graphical Editing Framework
Developer Resources"
org.eclipse.gef.source (3.2.2.v20070208) "Graphical Editing Framework
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse
Java Development Tools SDK"
org.eclipse.jem (1.2.3.v20070130_R----6zXJK-L2U8VZ) "Java EMF Model"
org.eclipse.jem.sdk (1.2.3.v20070130_R-G95EUlhcE39c_dh) "Java EMF Model SDK"
org.eclipse.jem.source (1.2.3.v20070130_R----6zXJK-L2U8VZ) "Java EMF
Model Source"
org.eclipse.jst (1.5.3.v200701251935-kW-NqztJbMj98Vy) "J2EE Standard
Tools (JST)"
org.eclipse.jst.common_core.feature.source
(1.5.3.v200701251934--0842282_363739) "J2EE Standard Tools - Common Core
Source"
org.eclipse.jst.enterprise_core.feature.source
(1.5.3.v200701251934--2PD88R9BCIAEJ8) "J2EE Standard Tools - Enterprise
Core Source"
org.eclipse.jst.enterprise_ui.feature.source
(1.5.3.v200701251934-pEBqJhM9w8QnUf6) "J2EE Standard Tools - Enterprise
UI Source"
org.eclipse.jst.sdk (1.5.3.v200701251935-dnUTzpmRSVGy2Rb) "J2EE Standard
Tools (JST)"
org.eclipse.jst.server_adapters.feature.source
(1.5.3.v200701251934--87cMN9O2Ru4WKU) "J2EE Standard Tools - Server
Adapters Source"
org.eclipse.jst.server_core.feature.source
(1.5.3.v200701251934--2PD88Q8NBHx787) "J2EE Standard Tools - Server Core
Source"
org.eclipse.jst.server_ui.feature.source
(1.5.3.v200701251934-PGIEUCdEgCIEO8I) "J2EE Standard Tools - Server UI
Source"
org.eclipse.jst.web_core.feature.source
(1.5.3.v200701251934--87cMNBMrUpUYda) "J2EE Standard Tools - Web Core
Source"
org.eclipse.jst.web_ui.feature.source
(1.5.3.v200701251934--2PD88P8T_IB_EI) "J2EE Standard Tools - Web UI Source"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse
Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse
RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) "Eclipse Project SDK"
org.eclipse.wst (1.5.3.v200701251935-X3Tn7ug44nfs8AE) "Web Standard
Tools (WST)"
org.eclipse.wst.common_core.feature.source
(1.5.3.v200701251933--AXrVWeX7d4hX-D) "Web Standard Tools - Common Core
Source"
org.eclipse.wst.common_ui.feature.source
(1.5.3.v200701251933-qKHiXJOPpbWGm-L) "Web Standard Tools - Common UI
Source"
org.eclipse.wst.rdb_adapters.feature.source
(1.5.3.v200702061839--Cq0bcrlqoamowX) "Web Standard Tools SDK - RDB
Component"
org.eclipse.wst.rdb_core.feature.source
(1.5.3.v200702061839--3YIAAaCICSEGIY) "Web Standard Tools SDK - RDB
Component"
org.eclipse.wst.rdb_ui.feature.source
(1.5.3.v200701251933-FTMjzaAe7oC0NoZ) "Web Standard Tools SDK - RDB
Component"
org.eclipse.wst.sdk (1.5.3.v200701251935-O2U9h5tjqRzyXdC) "Web Standard
Tools (WST)"
org.eclipse.wst.server_core.feature.source
(1.5.3.v200701251933-----1G955H5E5Fp) "Web Standard Tools - Server Core
Source"
org.eclipse.wst.server_ui.feature.source
(1.5.3.v200701251933-PGIEZcmNrOLaLXL) "Web Standard Tools - Server UI
Source"
org.eclipse.wst.web_core.feature.source
(1.5.3.v200701251933--4hNDDhFfKVFaSL) "Web Standard Tools - Web Core Source"
org.eclipse.wst.web_ui.feature.source
(1.5.3.v200701251933-zjf2UqCw_33Ffur) "Web Standard Tools - Web UI Source"
org.eclipse.wst.ws_core.feature.source
(1.5.3.v200612062151--4hNDDlDTFVITTc) "Web Standard Tools - Web Service
Core Source"
org.eclipse.wst.ws_ui.feature.source
(1.5.3.v200701251933-hai7Hmzwm3L_T5K) "Web Standard Tools - Web Service
UI Source"
org.eclipse.wst.xml_core.feature.source
(1.5.3.v200701251933--3YIAAaBNHFDQIR) "Web Standard Tools - XML Core Source"
org.eclipse.wst.xml_ui.feature.source
(1.5.3.v200701251933-zkiCfz_49IUPp-O) "Web Standard Tools - XML UI Source"
org.eclipse.xsd (2.2.2.v200702131851) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.2.1.v200702131851) "XML Schema Infoset Model
(XSD) Programmers Guide"
org.eclipse.xsd.source (2.2.2.v200702131851) "XML Schema Infoset Model
(XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.4.5.20061213) "International Components for
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.3.0.v200608161946) "Apache Axis 1.3.0" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in" [Resolved]
org.apache.commons_logging (1.0.4.v200608011657) "Apache commons logging
Plug-in" [Resolved]
org.apache.geronimo.common.deployment.model (1.0.0) "Geronimo-security-1
Model" [Active]
org.apache.geronimo.common.deployment.model.edit (1.0.0)
"Geronimo-security-1 Edit Support" [Resolved]
org.apache.geronimo.deployment.model (1.0.0) "Geronimo-web-1 Model"
[Resolved]
org.apache.geronimo.deployment.model.edit (1.0.0) "Geronimo-web-1 Edit
Support" [Resolved]
org.apache.geronimo.runtime.common (1.0.0) "Geronimo Common Runtime
Plug-in" [Resolved]
org.apache.geronimo.runtime.v1 (1.0.1) "Geronimo V1 Runtime Plug-in"
[Resolved]
org.apache.geronimo.runtime.v11 (1.0.0) "Geronimo V11 Runtime Plug-in"
[Resolved]
org.apache.geronimo.st.core (1.0.0) "Geronimo Server Tools Core Plug-in"
[Active]
org.apache.geronimo.st.ui (1.0.0) "Geronimo Server Tools UI Plug-in"
[Resolved]
org.apache.geronimo.st.v1.core (1.0.0) "Geronimo V1 Server Tools Core
Plug-in" [Resolved]
org.apache.geronimo.st.v1.ui (1.0.0) "Geronimo Server Tools V1 UI
Plug-in" [Resolved]
org.apache.geronimo.st.v11.core (1.0.0) "Geronimo v11 Server Tools Core
Plug-in" [Active]
org.apache.geronimo.st.v11.ui (1.0.0) "Geronimo Server Tools V11 UI
Plug-in" [Active]
org.apache.geronimo.v11.deployment.model (1.0.0) "Geronimo-web-1 Model"
[Active]
org.apache.geronimo.v11.deployment.model.edit (1.0.0) "Geronimo-web-1
org.apache.jakarta_log4j (1.2.8.v200607172048) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200608161946) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) "Debug UI" [Active]
org.eclipse.draw2d (3.2.2.v20070208) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.2.0.v20060626) "Draw2D Documentation"
[Resolved]
org.eclipse.emf (2.2.0.v200702131851) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200702131851) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.cheatsheets (2.2.0.v200702131851) "EMF Cheat Sheets"
[Resolved]
org.eclipse.emf.codegen (2.2.2.v200702131851) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.2.v200702131851) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200702131851) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200702131851) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200702131851) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200702131851) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.1.0.v200702131851) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200702131851) "EMF Model Convert
Support" [Resolved]
(EMF) Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.2.2.v200702131851) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.1.v200702131851) "EMF Ecore Change
Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200702131851) "EMF Ecore
Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200702131851) "EMF Ecore Edit
Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200702131851) "Sample Ecore Editor"
[Resolved]
Objects (SDO)" [Resolved]
Objects (SDO) Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Editor" [Resolved]
Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.2.v200702131851) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.2.v200702131851) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.2.1.v200702131851) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.2.0.v200702131851) "EMF Model Export
Support" [Resolved]
org.eclipse.emf.importer (2.2.2.v200702131851) "EMF Model Import
Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200702131851) "EMF Ecore
Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.1.v200702131851) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.2.0.v200702131851) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200702131851) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200702131851) "Ecore to
Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851) "Ecore
to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200702131851) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200702131851) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200702131851) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200702131851) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200702131851) "XSD to
(EMF) Source" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.equinox.servlet.api (1.0.0.v20060601) "Servlet API" [Resolved]
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.2.0.v20060626) "Graphical Editing Framework
Documentation" [Resolved]
Developer Resources" [Resolved]
org.eclipse.help (3.2.2.R322_v20061213) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Active]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Active]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Active]
org.eclipse.help.webapp (3.2.2.R322_v20061114) "Help System Webapp" [Active]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Installed]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Installed]
org.eclipse.jdt.core (3.2.3.v_686_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.2.1.r322_v20070109) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java
Development User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools
JUnit support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Installed]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) "Java Development Tools
Launching Support" [Active]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.2.v20061027_M) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Resolved]
org.eclipse.jem.sdk (1.2.0.v20060918_M) "Java EMF Model SDK" [Resolved]
Model Source" [Resolved]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Active]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.2.3.v20070130_R) "Java EMF Model Workbench
Support" [Active]
org.eclipse.jface (3.2.2.M20061214-1200) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data
Binding" [Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) "JFace Text" [Resolved]
org.eclipse.jst (1.0.1.v200605040115) "J2EE Standard Tools (JST)" [Resolved]
Source" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.1.v200609132124)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.1.v200609132124)
"Annotation Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.1.v200609132124) "Annotations
UI Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.1.4.v200702021430) "Integration
Plug-in" [Resolved]
org.eclipse.jst.common.project.facet.core (1.1.0.v200608141517) "Project
Facet Core (Java Support)" [Active]
org.eclipse.jst.doc.isv (1.0.201.v200606130315) "JST ISV Documentation"
[Resolved]
org.eclipse.jst.ejb.doc.user (1.0.203.v200609221649) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.1.1.v200609132124) "WTP EJB UI Plug-in" [Active]
Core Source" [Resolved]
UI Source" [Resolved]
org.eclipse.jst.j2ee (1.1.3.v200702071605) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.1.52.v200701241140) "J2EE Core Component"
[Active]
org.eclipse.jst.j2ee.doc.user (1.0.203.v200609182036) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.3.v200701241140) "EJB component Plug-in"
[Active]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.1.v200609140551) "EJB
Annotation Model Plug-in" [Active]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.1.v200609140551) "EJB
Emitter Plug-in" [Active]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.1.v200609070230) "EJB
Annotations Ui Plug-in" [Active]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.1.v200609141515)
"Xdoclet Annotations Plug-in" [Active]
org.eclipse.jst.j2ee.infopop (1.0.202.v200609150300) "J2EE tools
infopops" [Resolved]
org.eclipse.jst.j2ee.jca (1.1.3.v200701241140) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.1.1.v200609132124) "WTP JCA UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.navigator.ui (1.1.2.v200702021430) "J2EE Extensions
to Common Navigator" [Active]
org.eclipse.jst.j2ee.ui (1.1.2.v200702071605) "WTP J2EE UI Plug-in" [Active]
org.eclipse.jst.j2ee.web (1.1.3.v200701242244) "Web Plug-in" [Active]
org.eclipse.jst.j2ee.webservice (1.1.3.v200612131540) "Web Service
Plug-in" [Active]
org.eclipse.jst.j2ee.webservice.ui (1.1.2.v200610162137) "WTP Webservice
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.1.v200609140551)
"XDocletRuntime Plug-in" [Resolved]
org.eclipse.jst.jsp.core (1.1.102.v200701252050) "Structured Source JSP
Model" [Active]
org.eclipse.jst.jsp.ui (1.1.100.v200608142042) "SSE JSP Source Editor"
[Resolved]
org.eclipse.jst.jsp.ui.infopop (1.0.2.v200605040115) "JSP tools
Adapters Source" [Resolved]
Source" [Resolved]
Source" [Resolved]
org.eclipse.jst.server.core (1.0.105.v20070202b) "Java Server Support"
[Active]
org.eclipse.jst.server.generic.core (1.0.101.v200608301011) "Generic
Server Plugin" [Active]
org.eclipse.jst.server.generic.jboss (1.5.2.v200702030302) "JBoss
Generic server definitions" [Resolved]
org.eclipse.jst.server.generic.jonas (1.5.0.v200606130315) "JOnAS
Generic Server definitions" [Resolved]
org.eclipse.jst.server.generic.oc4j (1.5.0.v200606130315) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.100.v200608221634) "Generic
Server Plugin UI" [Resolved]
org.eclipse.jst.server.generic.weblogic (1.5.1.v200609141504) "Weblogic
generic server definitions" [Resolved]
org.eclipse.jst.server.installable (1.5.2.v20061018) "Installable
servers" [Resolved]
org.eclipse.jst.server.tomcat.core (1.0.104.v20070202b) "Apache Tomcat
Support" [Active]
org.eclipse.jst.server.tomcat.ui (1.0.103.v20060906) "Apache Tomcat UI
Support" [Resolved]
org.eclipse.jst.server.ui (1.0.103.v20060809) "Java Server UI Support"
[Resolved]
org.eclipse.jst.server.ui.doc.user (1.0.203.v200609221649) "Server Tools
documentation for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.ui.infopop (1.0.2.v200605040115) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.101.v200609140551) "WebSphere
org.eclipse.jst.servlet.ui (1.1.2.v200702021430) "WTP Servlet UI
Plug-in" [Active]
org.eclipse.jst.servlet.ui.infopop (1.0.201.v200606130315) "Servlet
infopop" [Resolved]
Source" [Resolved]
Source" [Resolved]
org.eclipse.jst.ws (1.0.103.v200701230512) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (1.0.103.v200701152245) "Web
service Axis Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (1.0.102.v200608301709)
"Webservice Axis Consumption UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (1.0.104.v200702061836) "Webservice
Axis Creation UI" [Resolved]
org.eclipse.jst.ws.axis.infopop (1.0.201.v200605152241) "Web services
Axis UI" [Resolved]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.203.v200609221649) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.103.v200701241747) "Web Services
Consumption" [Resolved]
org.eclipse.jst.ws.consumption.infopop (1.0.202.v20070131) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.104.v200701301546) "Web Services
Consumption Graphical User Interface" [Resolved]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.202.v200609221649) "Web
service consumption documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200606130315) "Web Services
Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.104.v200702021949) "Web Services
Creation Graphical User Interface" [Resolved]
org.eclipse.jst.ws.doc.user (1.0.203.v200609221649) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.201.v200605162034) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.100.v200608221651) "Web Services
Universal Description Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (1.0.101.v200608302120) "Web Services Graphical
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) "Refactoring UI"
[Active]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Resolved]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development
Environment Runtime" [Resolved]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.2.R32x_v20070115) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse
Workbench User Guide" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.2.r322_v20070212) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.2.v3236b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.2.v3236) "Standard Widget Toolkit
org.eclipse.team.core (3.2.2.M20061114) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.2.M20061121) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Active]
org.eclipse.ui (3.2.1.M20061108) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Active]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Resolved]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) "Welcome Framework" [Active]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal
Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View"
[Active]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Active]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21
Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.2.M20070119-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.2.R32x_v20070111) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.3.R32x_v20070118) "Install/Update Core"
[Active]
org.eclipse.update.core.win32 (3.2.2.R32x_v20061214) "Install/Update
Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.2.R32x_v20061214) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) "Install/Update UI" [Active]
org.eclipse.wst (1.0.1.v200605040144) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.103.v200702021949) "Environment Command
Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.102.v200702021949) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.0.v20060831345) "Web services
Axis Ant task documentation" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services
UI" [Resolved]
org.eclipse.wst.command.env.ui (1.0.102.v200608222020) "Environment
Command Framework (GUI)" [Resolved]
Source" [Resolved]
Source" [Resolved]
org.eclipse.wst.common.core (1.1.100.v200608220540) "WST Common Core
Plug-in" [Resolved]
org.eclipse.wst.common.emf (1.1.3.v200612061436) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (1.1.4.v200702021430)
"EMF Workbench Edit Plug-in" [Active]
org.eclipse.wst.common.environment (1.0.100.v200608251934) "Enviornment
Plug-in" [Active]
org.eclipse.wst.common.frameworks (1.1.3.v200702071605) "Common
Frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (1.1.2.v200702071605) "WTP UI
Plug-in" [Active]
org.eclipse.wst.common.infopop (1.0.1.v200605270041) "Common WST
org.eclipse.wst.common.modulecore (1.1.52.v200701251700) "Modulecore
Plug-in" [Active]
org.eclipse.wst.common.project.facet.core (1.1.1.v200608112156) "Project
Facet Core" [Active]
org.eclipse.wst.common.project.facet.ui (1.1.2.v200701192142) "Project
Facet UI" [Active]
org.eclipse.wst.common.snippets (1.1.1.v200609140550) "Snippets View"
[Resolved]
org.eclipse.wst.common.ui (1.1.101.v200702021750) "Eclipse Base UI
extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.101.v200609140551) "Common
Properties UI" [Resolved]
org.eclipse.wst.common.uriresolver (1.1.101.v200702021717) "Common URI
Resolver Framework" [Active]
org.eclipse.wst.css.core (1.1.1.v200609140550) "Structured Source CSS
Model" [Resolved]
org.eclipse.wst.css.ui (1.0.101.v200609140550) "SSE CSS Source Editor"
[Resolved]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.203.v200608310305)
"Data documentation" [Resolved]
org.eclipse.wst.datatools.data.ui.doc.user (1.0.203.v200608310305) "Data
tools data user interface documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.203.v200608310305) "Data
org.eclipse.wst.datatools.server.ui.doc.user (1.0.203.v200608310305)
"Database Explorer documentation" [Resolved]
org.eclipse.wst.doc.isv (1.0.203.v200702030234) "WST ISV Documentation"
[Resolved]
org.eclipse.wst.doc.user (1.0.203.v200608231821) "Master User Doc TOC"
[Resolved]
org.eclipse.wst.dtd.core (1.1.1.v200609210600) "Structured Source DTD
Core" [Active]
org.eclipse.wst.dtd.ui (1.0.102.v200702021750) "SSE DTD Source Editor"
[Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200605040131) "DTD Editor
org.eclipse.wst.dtdeditor.doc.user (1.0.203.v200609221649) "DTD Editor
org.eclipse.wst.html.core (1.1.2.v200612200820) "Structured Source HTML
Model" [Resolved]
org.eclipse.wst.html.standard.dtds (1.0.1.v200608220315) "Known DTDs"
[Resolved]
org.eclipse.wst.html.ui (1.0.102.v200702021750) "HTML UI Source Editor"
[Active]
org.eclipse.wst.html.ui.infopop (1.0.1.v200605040131) "HTML editor
org.eclipse.wst.internet.cache (1.0.103.v200612070353) "Cache URI
Resolver Plug-in" [Active]
org.eclipse.wst.internet.monitor.core (1.0.103.v20060809) "Monitor"
[Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.103.v20060809) "TCP/IP Monitor"
[Resolved]
org.eclipse.wst.internet.proxy (1.0.101.v200702021949) "Internet Proxy
Preferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200605070230) "Internet
Proxy Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.1.v200609140550) "Structured Source
JavaScript Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.2.v200701250230) "SSE JavaScript
Source Editor" [Resolved]
org.eclipse.wst.javascript.ui.infopop (1.0.1.v200605040131) "Javascript
infopop" [Resolved]
Component" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.106.v200701032244) "RDB
Connection.ui" [Active]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0.v200605040131) "New
Connection wizard infopops" [Resolved]
org.eclipse.wst.rdb.core (1.1.119.v200702062139) "RDB Core" [Active]
org.eclipse.wst.rdb.core.ui (1.0.108.v200701032153) "Core UI plugin"
[Resolved]
org.eclipse.wst.rdb.data.core (1.0.107.v200612130213) "Data Core Plugin"
[Resolved]
org.eclipse.wst.rdb.data.ui (1.0.110.v200612130213) "Data UI Plugin"
[Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.105.v200610161941)
"DB2 UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.107.v200702021852) "DB2
UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.104.v200610161905)
"DB2 UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.derby (1.0.104.v200610161905) "Derby
Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.generic.jdbc (1.0.101.v200605040131)
"DBDefinition Generic JDBC Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.104.v200610261819)
"Informix Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.101.v200610161905)
"DBDefinition Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.103.v200702062139) "Oracle
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.105.v200610161905) "SQL
Server Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.106.v200610261819) "Sybase
org.eclipse.wst.rdb.derby (1.0.106.v200612130213) "RDB Derby Plug-in"
[Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.103.v200612130213) "RDB Derby Ui
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.104.v200612130213) "FE UI Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (1.0.103.v200612130213) "FE Ui Actions
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0.v200605040131) "Generate DDL
org.eclipse.wst.rdb.models.dbdefinition (1.0.103.v200702062139)
"DBDefinition Model" [Resolved]
org.eclipse.wst.rdb.models.sql (1.0.104.v200612130213) "SQLModel
Plug-in" [Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.103.v200612130213) "SQLModel
Edit Plug-in" [Resolved]
org.eclipse.wst.rdb.mysql (1.0.104.v200612130213) "RDB Mysql Plug-in"
[Resolved]
org.eclipse.wst.rdb.outputview (1.0.107.v200612130213) "Data Output
Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0.v200605040131) "Data
Output view infopops" [Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.105.v200612130213) "Server
Explorer Extensions Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.110.v200701242205) "Server Explorer
plugin" [Resolved]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0.v200605040131) "Server
Explorer view infopops" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.106.v200612130213) "SQL Source Editor
Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0.v200605040131) "SQL
org.eclipse.wst.rdb.sqlscrapbook (1.0.103.v200612130213) "Sqlscrapbook
Plug-in" [Resolved]
Source" [Resolved]
Source" [Resolved]
org.eclipse.wst.server.core (1.0.105.v20070202b) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.105.v20070124b) "Server UI" [Active]
org.eclipse.wst.server.ui.doc.user (1.0.203.v200609221649) "Server Tools
documentation for Web Standard Tools" [Resolved]
org.eclipse.wst.server.ui.infopop (1.0.3.v200609140551) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sqleditor.doc.user (1.0.2.v200608310308) "SQL Editor
org.eclipse.wst.sse.core (1.1.101.v200611210021) "Structured Text Model"
[Active]
org.eclipse.wst.sse.doc.user (1.0.203.v200608300230) "Structured text
editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.202.v200701252330) "Structured Source
Editor" [Active]
org.eclipse.wst.sse.ui.infopop (1.0.101.v200605040131) "SSE infopops"
[Resolved]
org.eclipse.wst.validation (1.1.3.v200702021430) "Validation Framework"
[Active]
org.eclipse.wst.validation.infopop (1.0.201.v200606130645) "WST
validation infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.2.v200612061436) "Validation
Framework UI" [Resolved]
org.eclipse.wst.web (1.1.2.v200610182223) "Simple Web Plug-in" [Active]
Source" [Resolved]
Source" [Resolved]
org.eclipse.wst.web.ui (1.1.1.v200609132124) "Simple Web UI Plug-in"
[Active]
org.eclipse.wst.web.ui.infopop (1.0.201.v200605070230) "Static Web
infopop" [Resolved]
org.eclipse.wst.webtools.doc.user (1.0.203.v200609221649) "Web tools
org.eclipse.wst.ws (1.0.102.v200702021949) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (1.0.104.v200701250524) "Web Services
Explorer" [Resolved]
org.eclipse.wst.ws.infopop (1.0.202.v20070131) "Web Services UI" [Resolved]
org.eclipse.wst.ws.parser (1.0.101.v200609062128) "Web Services
Description Parser" [Resolved]
org.eclipse.wst.ws.ui (1.0.102.v200702021555) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (1.0.103.v200702021033) "WSDL Model" [Active]
org.eclipse.wst.wsdl.ui (1.1.101.v200702082034) "WSDL UI" [Resolved]
org.eclipse.wst.wsdl.ui.doc.user (1.0.203.v200609221649) "WSDL Editor
org.eclipse.wst.wsdl.validation (1.1.101.v200701260245) "WSDL Validator"
[Active]
org.eclipse.wst.wsi (1.0.104.v200702021430) "WSI Conformance Tools"
[Resolved]
org.eclipse.wst.wsi.ui (1.0.101.v20060850312) "Soap Monitor" [Active]
org.eclipse.wst.wsi.ui.doc.user (1.0.202.v200609221649) "WS-I Validation
Source" [Resolved]
Source" [Resolved]
org.eclipse.wst.xml.core (1.1.100.v200702021717) "Structured Source XML
Model" [Active]
org.eclipse.wst.xml.ui (1.0.201.v200702021717) "XML UI Plugin" [Resolved]
org.eclipse.wst.xml.ui.infopop (1.0.1.v200605040131) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.203.v200609221649) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.1.101.v200701312359) "XSD Core Plugin" [Active]
org.eclipse.wst.xsd.ui (1.1.102.v200701312359) "XML Schema Editor"
[Resolved]
org.eclipse.wst.xsdeditor.doc.user (1.0.203.v200609221649) "XML schema
editor" [Resolved]
[Active]
org.eclipse.xsd.cheatsheets (2.2.0.v200702131851) "XML Schema Infoset
Model (XSD) Cheat Sheets" [Resolved]
(XSD) Programmers Guide" [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.1.v200702131851) "XML Schema
Exporter for EMF" [Resolved]
org.eclipse.xsd.ecore.importer (2.2.0.v200702131851) "XML Schema
Importer for EMF" [Resolved]
org.eclipse.xsd.edit (2.2.1.v200702131851) "XML Schema Edit Framework"
[Resolved]
org.eclipse.xsd.editor (2.2.0.v200702131851) "XML Schema Editor" [Resolved]
(XSD) Source" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Installed]
org.uddi4j (2.0.5.v200608231542) "UDDI4J 2.0.5" [Resolved]
org.wsdl4j (1.4.0.v200702061629) "WSDL4J 1.4" [Resolved]
system.bundle (3.2.2.R32x_v20070118) "OSGi System Bundle" [Active]
*** User Preferences:
#Fri Mar 09 23:22:08 GMT 2007
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.indent_parameter_description=true
@org.eclipse.ui.editors=3.2.1.r321_v20060721
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_at_in_annotation_type_declaration=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_enum_constant=next_line
@org.eclipse.jst.j2ee.ejb.annotations.xdoclet=1.1.1.v2006091 41515
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_binary_operator=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_method_invocation_arguments=in sert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_prefix_operator=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_if=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_type_arguments=insert
/project/CabinProject/org.eclipse.jst.common.project.facet.c ore/classpath.helper/org.eclipse.jdt.launching.JRE_CONTAINER /owners=jst.java\:5.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_method_declaration_throws=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_enum_constants=0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_annotation_type_decla ration=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_bracket_in_array_allocation_exp ression=do
not insert
/project/CabinProject/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.codegen.targetPlatform=1.5
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_switchstatements_compare_to_cases=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_synchronized=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_question_in_conditional=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_else_statement_on_same_line=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_paren_in_parenthesized_expressi on=do
not insert
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/project/CabinProject/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.compliance=1.5
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_for_increments=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_angle_bracket_in_parameterized _type_reference=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_multiple_field_declarations=d o
not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.clear_blank_lines=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_constructor_declarati on=do
not insert
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/XDOCL ETBUILDERACTIVE=true
/instance/org.eclipse.jdt.ui/formatter_profile=_kmgprofile
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_conditional_expression=80
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.format_header=false
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_angle_bracket_in_parameterized _type_reference=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_parens_in_enum_constant=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.insert_new_line_before_root_tags=insert
@org.eclipse.ui=3.2.1.M20061108
/instance/org.eclipse.help.base/bookmarks=,/org.eclipse.jst. ejb.doc.user/topics/ceover.html|EJB
application development
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_compact_if=16
@org.eclipse.wst.server.core=1.0.105.v20070202b
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_before_else_in_if_statement=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_bracket_in_array_reference=do
not insert
Re: Problem creating simple Session Bean under Eclipse 3.2.2 [message #189750 is a reply to message #189701] |
Mon, 12 March 2007 16:44  |
Thanks for that, Wolfgang. That's saved me hours of research: I
appreciate it!
Wolfgang Knauf wrote:
> Hi !
> Yes, you have to select "XDoclet Enterprise JavaBean", it was renamed in
> the 1.0 or 1.5 build. Your installation is correct, the tutorial seems
> to be quite outdated. You can use JBoss 4.0 now, don't have to stick to
> the olde 3.2.3 mentioned in the tutorial
> Best regards
> Wolfgang
> kmg wrote:
>> Hi
Current Time: Sat Jul 19 10:14:37 EDT 2025
Powered by FUDForum. Page generated in 0.09299 seconds
