Re: Don't use GMF for a form based diagram ? [message #189287 is a reply to message #188921] |
Sat, 24 May 2008 16:06  |
If you are using GEF, and if you find EMF useful, there is no reason not to
use GMF, in my opinion. At a minimum, GMF will help you manage your code,
by providing a good package and class structure.
As I see it, GMF is oriented on making the XY layout work well, and offers
some support for the List layout, though not full support.
The form and table layouts will need to be implemented by you, which will be
a hard task, in my opinion, as you have to do it all by hand. However, if
you started implementing it in GEF, you could port it in GMF easily, once
you get used to the new project structure.
Lucian
FUDForum. Page generated in 0.05157 seconds
