Home » Eclipse Projects » GEF » Deleting connections in the standalone GEF sample
Deleting connections in the standalone GEF sample [message #188559] Thu, 21 July 2005 10:36 Go to next message
Originally posted by: ahn.iie.cnam.Fr
I am trying to reuse this sample for my work :
http://www13.plala.or.jp/observe/GEF/GEF_Tool_StandAlone.htm l
You may have see this Japanese page if you tried to make your own GEF
standalone application.
The source is here :
http://www13.plala.or.jp/observe/GEF/standGEFToolExample.zip
I am trying to implement the deleting command (and also the connection
deleting command); Could someone help me if he managed to ? It must be
possible since on the same page (http://www13.plala.or.jp/observe/GEF/)
, there is a tutorial showing the Hello_World plug in application where
the deleting command is implemented.
Thanks !
Re: Deleting connections in the standalone GEF sample [message #188580 is a reply to message #188559] Thu, 21 July 2005 11:20 Go to previous message
I must precise my request.
I know why my try to implement this deleting command doesn't work.
Indeed here my main class extends an ApplicationWindow and in this
application a part of it uses GEF and a CanvasModel to build a diagram.
But I use a ScrollingGraphicalviewer to receive all the commands. Thus I
ca only create nodes and connect them.
How could I implement deleting ( in fact how could i set keyHandlers ?)
You will find the beginning of my "CreateContents" method of my
ApplicationWindow.
protected Control createContents(Composite parent)
Composite composite = new Composite(parent, SWT.BORDER);
composite.setLayout(new FormLayout());
parent.getShell().setText("OGEAR");
Composite arbre = new Composite(composite, SWT.BORDER | SWT.HORIZONTAL);
arbre.setLayout(new FillLayout());
viewer = new ScrollingGraphicalViewer();
viewer.setEditDomain(editDomain);
viewer.createControl(arbre);
viewer.setEditPartFactory(new MyEditPartFactory());
CanvasModel model = new CanvasModel();
viewer.setContents(model);
FormData formArbre= new FormData();
formArbre.top = new FormAttachment(0,10);
formArbre.left = new FormAttachment(0,10);
formArbre.right = new FormAttachment(100,-10);
formArbre.bottom = new FormAttachment(50,-10);
arbre.setLayoutData(formArbre);
Previous Topic:Gradient
Next Topic:scripting an editor in a JUnit test
Current Time: Sun Jul 20 02:30:32 EDT 2025
Powered by FUDForum. Page generated in 0.02759 seconds
