Home » Modeling » GMF (Graphical Modeling Framework) » GMF editor menu
GMF editor menu [message #187972] Tue, 20 May 2008 10:13 Go to next message
Originally posted by: fbanica.soluta.net
Hi all,
I have some questions. I made a GMF editor and I want to understand/manage
the menu. More precisely, the generator produces some "extra menu items"
which I can not see in the "extensions" section of the "plugin.xml". For
example the "Diagram" menu which only shows up when a diagram is open into
the editor. BUT, there is no "org.eclipse.ui.editorActions" extension
declared into the plugin.xml... Where does it come from???
Second, there is a menu item "Open File..." into the "New" menu. Also for
this one I can not find anything into the "plugin.xml". Where does it come
from??? (I want to remove it)
Third, in the "Help" menu, there is the "Software updates" sub-menu which I
would like to manage, but, again, I can not say where is it coming from,
so...
Please, help me with this. Thanks,
Floppy
Re: GMF editor menu [message #188018 is a reply to message #187972] Tue, 20 May 2008 11:18 Go to previous messageGo to next message
P.S. The menu items I have talked about aren't in the makeActions(),
fillMenuBar() or fillCoolBar() methods either...
"Florin Banica" <fbanica@soluta.net> wrote in message
news:g0umb9$imh$1@build.eclipse.org...
> Hi all,
> I would like to manage, but, again, I can not say where is it coming from,
> so...
> Floppy
Re: GMF editor menu [message #188034 is a reply to message #187972] Tue, 20 May 2008 11:48 Go to previous messageGo to next message
Hello FLORIN,
> section of the "plugin.xml". For example the "Diagram" menu which only
I think this menu came from org.eclipse.gmf.runtime.diagram.ui.providers
plugin.
It looks like a standatd Eclipse menues. If you'd like to remove it try working
in RCP mode.
Same with this - eclipse standard menu..
Alex Shatalin
Re: GMF editor menu [message #188041 is a reply to message #188034] Tue, 20 May 2008 12:03 Go to previous messageGo to next message
Thanks for your answer, Alex.
I am in RCP. My application is an RCP... See the attachments, please...
Other hints?
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e6226938ca88b8e39bf220@news.eclipse.org...
> Hello FLORIN,
> plugin.
> working
> in RCP mode.
> Alex Shatalin
Re: GMF editor menu [message #188141 is a reply to message #188041] Wed, 21 May 2008 05:43 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Eclipse comes with sources; if you know action or class name you can
always find it. Ctrl+H opens the search dialog.
> Other hints?
>> Hello FLORIN,
>> plugin.
>> working
>> in RCP mode.
>> Alex Shatalin
Re: GMF editor menu [message #188280 is a reply to message #188141] Wed, 21 May 2008 11:54 Go to previous messageGo to next message
Sorry, I don't get it... My questions were how to get rid of the "Open
File..." into the "File" menu (my mistake if I said "New" in the previous
message) and how to find the "implementation" of the "Software updates"
sub-menu in the "Help" menu...
What are you trying to tell me? To look for what with Ctrl+H?
"Dmitry Stadnik" <5d5@mail.ru> wrote in message
news:g10qrq$oma$1@build.eclipse.org...
>> Other hints?
>>> Hello FLORIN,
>>> plugin.
>>> working
>>> in RCP mode.
>>> Alex Shatalin
Re: GMF editor menu [message #188391 is a reply to message #188280] Thu, 22 May 2008 03:12 Go to previous messageGo to next message
Can anyone help me with the answers to these questions, please?
news:g11gj9$ro2$1@build.eclipse.org...
>>> Other hints?
>>>> Hello FLORIN,
>>>> plugin.
>>>> working
>>>> in RCP mode.
>>>> Alex Shatalin
Re: GMF editor menu [message #652266 is a reply to message #187972] Thu, 03 February 2011 06:56 Go to previous messageGo to next message
Hello!
I know that the post is very old... but i've the same problem. Do you remember how you solved it?
Thank you
[Updated on: Thu, 03 February 2011 06:57] by Moderator
Re: GMF editor menu [message #653070 is a reply to message #187972] Tue, 08 February 2011 05:58 Go to previous message
see hint here: http://www.eclipse.org/forums/index.php?t=msg&th=204010& amp;start=0&S=2f627bf2d47c743c0bc992192b939508#msg_num_1
Previous Topic:Links disappear in initialised diagram - a bug?
Next Topic:Spell checking in diagrams
Current Time: Sun Jul 20 10:15:12 EDT 2025
Powered by FUDForum. Page generated in 0.05108 seconds
