Home » Language IDEs » ServerTools (WTP) » Europa WST 1.6.0
Europa WST 1.6.0 [message #188210] Sun, 18 February 2007 23:54 Go to next message
I installed the webtools from the Europa staging directory. Everything
installed correctly, I see the features installed. When I try to switch to
the J2EE Perspective it is not there, I also cannot create a web project.
The options do not show up?
Anyone have any Idea?
I'm running Eclipse 3.3.M5 on Windows XP Machine. The europa staging update
site address is.
http://download.eclipse.org/releases/europa/staging
Thanks for any help.
Re: Europa WST 1.6.0 [message #188262 is a reply to message #188210] Mon, 19 February 2007 22:55 Go to previous messageGo to next message
> site address is.
There's probably messages in your log that describes what's going wrong, BUT
the 'staging' area is pretty unstable. Right now for example, it has some M5 code
(from the platform) mixed with some M4 code (from WTP, for exmaple). That staging area
is just for the projects to test the upload and update functions. End users should
only use code from
http://download.eclipse.org/releases/europa/releases
Re: Europa WST 1.6.0 [message #188300 is a reply to message #188262] Tue, 20 February 2007 07:56 Go to previous messageGo to next message
"David Williams" <david_williams@us.ibm.com> wrote in message
news:op.tn03t2acac05ss@dmw2t23.ibm.com...
>> to
>> update
>> site address is.
> BUT
> M5 code
> staging area
> users should
> only use code from
I had done that Originally with the same effect so I installed the stagign
area thinking that is may have newer code that might solve this problem
still with no Avail.
I have tried on both fedora and XP.
If I get a chance I will go back and try on 3.3.M4 and see if that solves
the issue.
Adam
Re: Europa WST 1.6.0 [message #188317 is a reply to message #188300] Tue, 20 February 2007 08:49 Go to previous messageGo to next message
I have tried this with a clean 3.3.M4 install on fedora core 5 still with
the same effect.
I did not use the staging directory I used the default europa discovery site
that was installed with 3.3.M4
adam
"Adam Carbone" <acarbs12@yahoo.com> wrote in message
news:erer5o$h40$1@utils.eclipse.org...
>>> to
>>> project.
>>> update
>>> site address is.
>> BUT
>> M5 code
>> staging area
>> users should
>> only use code from
> the issue.
> Adam
Re: Europa WST 1.6.0 [message #188333 is a reply to message #188317] Tue, 20 February 2007 10:17 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
WTP is composed of two components WST and JST. Did you get both? If you
only got WST, then you will only get tooling for non-Java web
technologies. You need to have JST installed in order to do J2EE
development.
- Konstantin
Re: Europa WST 1.6.0 [message #188767 is a reply to message #188333] Wed, 28 February 2007 08:33 Go to previous messageGo to next message
Yes I got both There was nothing
I have tried on
3.3.M4
3.3.M5
3.3.M5eh
using both the releases and the staging
"Konstantin Komissarchik" <kosta@bea.com> wrote in message
news:erf3er$i78$1@utils.eclipse.org...
> development.
> - Konstantin
Re: Europa WST 1.6.0 [message #188790 is a reply to message #188767] Wed, 28 February 2007 12:05 Go to previous messageGo to next message
Did your read the thread "Re: Compatible with Eclipse 3.3M5?"
I had similar problems.
Re: Europa WST 1.6.0 [message #188844 is a reply to message #188790] Wed, 28 February 2007 22:30 Go to previous message
Yes I did please see my comment there giving my setup...
I have tried this on both my windows machine at home and my linux machine at
work.
"Etienne" <etiennel@scientology.net> wrote in message
news:413c1c2094db50acc72418f3b1f4d5e1$1@www.eclipse.org...
Previous Topic:Generate XML from XSD library/class
Next Topic:Unable to find setter method for attribute: xCoord
Current Time: Sat Jul 19 20:49:36 EDT 2025
Powered by FUDForum. Page generated in 0.05300 seconds
