Home » Archived » XML Schema Definition (XSD) » Find an XSD element
Find an XSD element [message #18732] Wed, 16 April 2003 08:38 Go to next message
Originally posted by: brc35.mailcity.com
I have a schema file (xsd) which I loaded into a XSDSchemaImpl object.
Starting from instance, I want to get information about an element that I
specify it by name, but I don't know where is into the schema tree. I try
to use resolveElementDeclaration method for the schema object, but the
test "if(element.getContainer() != null)" tell me that required element is
not the valid element from the xsd file, even into the schema exist an
element with the this name.
There is somebody that can help me?
Thank you....
Radu B.
Re: Find an XSD element [message #18817 is a reply to message #18732] Wed, 16 April 2003 12:08 Go to previous message
Radu,
Is it a global element declaration? Only global element declarations can be
looked up directly from the schema.
Radu Bretean wrote:
> Thank you....
> Radu B.
Re: Find an XSD element [message #567997 is a reply to message #18732] Wed, 16 April 2003 12:08 Go to previous message
Radu,
Radu Bretean wrote:
> Thank you....
> Radu B.
Previous Topic:Help needed analysing a XSD schema w/ complex types
Next Topic:Help needed analysing a XSD schema w/ complex types
Current Time: Sat Jul 19 19:46:36 EDT 2025
Powered by FUDForum. Page generated in 0.05437 seconds
