Making Connections [message #188005] |
Mon, 18 July 2005 14:58  |
Originally posted by: rmeschi.us.ibm.com
Hi guys,
I want the user of my application to be able to click on anoutput anchor
(which starts the connection tool)...then connect it to another anchor
(which stops the connection tool -> goes to default tool). The last part
is simple, but I'm wondering what is the best way to implement the first
part. Should I have the edit part of the figure listen to mouse clicks,
then check if the user clicked on the area in which the port is drawn,
then set the current tool the the connection tool and set the source to
the selected node? Is there perhaps a better way to do this?
thanks in advance,
-R
Re: Making Connections [message #188791 is a reply to message #188005] |
Fri, 22 July 2005 12:09  |
Use an anchor whose drag tracker is the connection drag creation tracker.
"Rouben" <rmeschi@us.ibm.com> wrote in message
news:48f0f487a14944f6a7e0ed8e1ba8f234$1@www.eclipse.org...
> Hi guys,
> thanks in advance,
> -R
FUDForum. Page generated in 0.06244 seconds
