Listen to any modyfication of the diagram [message #187722] |
Mon, 19 May 2008 09:15  |
I'm using the stp.bpmn modeler and I want to be notified about any
change in the diagram itself. If something is added, removed, changed, etc.
But where do I have to register my listener and what listener do I have
to implement?
Till
Re: Listen to any modyfication of the diagram [message #187779 is a reply to message #187771] |
Mon, 19 May 2008 11:48   |
Originally posted by: atoulme.intalio.com
Hey, just for the next folk reading this to feel smarter, would you mind
giving away the secret ? ;)
Till Essers wrote:
> Nevermind, I found it and feel stupid :D
> Till Essers schrieb:
>> Sorry for bugging you again...
>> Writing my own EContentAdapter and adding it to the Diagram object
>> would be the way it should work. My only left problem is... where to
>> get the Diagram object for the active editor?
>> Thanks
>> Till
>> PS: I wrote a small tutorial on hiding the advanced tab, you might
>> review it and then link it to your component, Antoine.
>> http://wiki.eclipse.org/STP/BPMN_Component/Hiding_property_t abs
>> Antoine Toulme schrieb:
>>> Look for the EMF EContentAdapter class. That should give you a gread
>>> head start.
>>> Thanks,
>>> Antoine
>>> Till Essers wrote:
>>>> Hi
>>>> changed, etc.
>>>> have to implement?
>>>> Thanks
>>>> Till
Re: Listen to any modyfication of the diagram [message #187795 is a reply to message #187779] |
Mon, 19 May 2008 11:53  |
How to add the ContentAdapter:
After opening the editor call the getDiagram() method and add your
EContentAdapter to the eAdapters list.
An Action for opening the editor will look like this:
IEditorPart editorpart =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(new
FileEditorInput(file), MyBpmnDiagramEditor.ID);
Diagram
((EexBpmnDiagramEditor)editorpart).getDiagram().eAdapters(). add(new
MyContentAdapter());
Thats it ;)
Next step is to understand the Notification passed around ;)
>>> Thanks
>>> Till
>>>> head start.
>>>> Thanks,
>>>> Antoine
>>>> Till Essers wrote:
>>>>> Hi
>>>>> changed, etc.
>>>>> have to implement?
>>>>> Thanks
>>>>> Till
FUDForum. Page generated in 0.05071 seconds
